Cold Air Inductions
Old 09-21-2011, 09:48 AM   #1
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
High volume oil pump.
I have heard arguments both ways, so lets get a consensus. Having a cam done next week. Most builders have to ld me that our stock oil pump is great and more than adequate for a cam job. A few builders highly recommend a high volume oil pump. Is it worth replacing the oil pump? Just trying to keep the cost a little lower, if its not necessary. Thanks guys
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 09-21-2011, 09:58 AM   #2
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
I was curious as well, through my research it seems the general consensus here is to go after market... I think Marylandspeed had a failure on their stock pump??
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 09-21-2011, 10:05 AM   #3
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I've also heard that it's wise to at least upgrade the existing pump or replace with an aftermarket one. There's possible issues with some of the stock pumps that fail.
Not a Camaro but it works for now!
Old 09-21-2011, 10:05 AM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
do your installers know there's a service bulletin out on the stock pump and there's been some issues with it failing?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 09-21-2011, 10:14 AM   #5
Synner
Drives: not stock
There won't be consensus on it.
At the very least I'd look at it and check its operation and debur it if you see casting imperfections. But if you're paying for labor that route may be no cheaper than buying one where its already been done. I don't think a high volume pump is necessary and the melling pump comes with a stock pressure spring. If you do sustained high rpm driving like on a road course some ppl have noted low oil pressure because the high volume emptied the pan. So you're just trading one risk for another.
Old 09-21-2011, 10:28 AM   #6
Pollock
LS3 M6
Pollock's Avatar
Drives: 2011 2SS/RS
I reused my stock timing chain and oil pump when I did my cam swap. Whos to say the aftermarket one wont fail too.
Maggy Charged, Cam, Kooks 1 7/8 Headers w/high flow cats, PCV catch can, Black CAI, ADM racing Scoop, VMax TB, 630 rwhp, BMR Trailing Arms, Toe links and Cradle bushings.
Pollock is offline   Reply With Quote
Old 09-21-2011, 10:30 AM   #7
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
there is a tsb with the ls3 oil pumps
i'd change it in a heartbeat.
we believe this is partially the cause of my last engine grenading.
Nvincent4708 is offline   Reply With Quote
Old 09-21-2011, 11:13 AM   #8
BLACK10
BLACK10's Avatar
I changed it out. It's $140 peice of mind.....
Old 09-21-2011, 11:15 AM   #9
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I would also change the pump.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-21-2011, 11:39 AM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
never had a problem here with the factory pumps if you shim the pressure spring
Old 09-21-2011, 11:47 AM   #11
5thGenCamaroKid
No fat chix, car scrapes.
Drives: 2014 GMC Sierra 1500
Caveating your response with "if you do this" lends itself to changing the pump.
FWIW, I'm having mine replaced when the cam swap occurs this week.
5thGenCamaroKid is offline   Reply With Quote
Old 09-21-2011, 03:59 PM   #12
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
I have heard that the stock pumps have had issues. I upgraded to a ported oil pump from TSP. IMO its cheap insurance, your spending all that money whats another 150 bucks. My oil pressure seems to be more responisve with it and the pressure is higher.
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 09-21-2011, 04:13 PM   #13
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
A ported pump is no different than a stocker... If you want to move more oil you get a melling hi volume pump... only one we use in our builds
CC Performance is offline   Reply With Quote
Old 02-07-2012, 08:48 PM   #14
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
Someone tell my why it is better to move more volume as far as the enginer oil goes? Why is this better?
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 289 08-26-2017 11:29 AM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
NEW! KATECH High capacity LS oil pump Katech Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 07-16-2011 01:32 AM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
