JDP Motorsports
Old 09-21-2011, 01:04 PM   #1
azvren
Drives: Camaro 2SS RS IBM
Oil temperature?
Is it normal for the oil temp to be slightly higher after cam swap?
azvren is offline   Reply With Quote
Old 09-21-2011, 01:43 PM   #2
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Can be...depends on how much of a change in temp you are talking about.
Remember oil temp is going to change a lot depends on use of the car. Also the more HP the car makes, generally the more heat it creates so water and oil temps both generally increase.
What are you seeing for an increase?
Anthony @ LG Motorsports is offline   Reply With Quote
Old 09-21-2011, 04:24 PM   #3
azvren
This is how high it goes on a hot day 96-105 degrees.
Old 09-21-2011, 05:57 PM   #4
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
2 EDGE PERFORMANCE has a Custom Oil Cooler just for this situation. These are on sale now for $599.99. Professional installation available.
MRGOODWRENCH3 is offline   Reply With Quote
Old 09-21-2011, 06:29 PM   #5
Parag
Drives: 2010 camaro 2SS LS3
wouldnt worry about it until it hits 250, which you are close to. put in a 160 degree thermostat. added performance too
Parag is offline   Reply With Quote
Old 09-22-2011, 02:44 AM   #6
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
My cammed car runs about the same on hot days...around 220...It has never gotten any higher
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 09-22-2011, 10:36 AM   #7
EFI
EFI's Avatar
Drives: something faster than you
Oh yeah, how much hp?
EFI is offline   Reply With Quote
Old 09-22-2011, 11:08 AM   #8
On the endurance cars like our GrandAm GT or ALMS GT2 car if we could see on track oil temps of 230-250 degree's that car will go 24 hrs on track no problem at all. Limited time above 270-290 is ok, given the car still has good oil pressure but the oils most certainly start to break down at that point. Of course I am talking about quality synthetic oils, not the standard dino stuff.
Old 09-22-2011, 11:20 AM   #9
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
Do you have online installation instructions by chance?
Pollock is offline   Reply With Quote
Old 09-22-2011, 11:40 AM   #10
MRGOODWRENCH3
The kit comes with detailed instructions including pictures.
Old 09-22-2011, 02:23 PM   #11
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Is this only designed to go out front of the radiator?
EDIT: Some of us have a "stack" of stuff up front already and don't need/want anything else up there dumping heat into the other systems....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 09-22-2011, 03:02 PM   #12
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
how accurate is the oem gage?
CC Performance is offline   Reply With Quote
Old 09-22-2011, 04:46 PM   #13
MRGOODWRENCH3
It bolts to the steel bumper behind the front facia. It is positioned in the lower grille opening to get direct air flow.
Old 09-22-2011, 05:50 PM   #14
Parag
probably none, but motors always run better on the cold side
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
