BORLA
Old 09-21-2011, 05:47 PM   #1
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
TechAFX Fuel Line
I am looking at the TechAFX hose relocation kit and have a question regarding the fuel line.
How hard is it to rotate the fuel rails 180 degrees? I haven't been able to find anything clear cut on the fuel hose installation.
Thanks in advance!
lsuguy is offline   Reply With Quote
Old 09-21-2011, 06:08 PM   #2
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
It does require that you remove the intake manifold complete. When you rotate the fuel rail the fuel pressure connection will now be on the right side against the firewall. There is a bracket that gets removed to clear the connection. It is all pretty easy. You will discard the long fuel line and install the short one. I have done many of these. I modify the evap line too. The kit comes with a long line. I have a way to make it only 12" long instead of 30+. The TechAFX website has a complete instruction kit that you can download.
Here are some pictures of mine.
http://www.camaro5.com/forums/showth...t=techafx+hose
MRGOODWRENCH3 is offline   Reply With Quote
Old 09-21-2011, 07:49 PM   #3
BLACK10
BLACK10's Avatar
its pretty straight forward. i used a corvette fuel line instead
Old 09-21-2011, 08:00 PM   #4
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Thanks guys. I will check yours out when I drop my car off tomorrow nick
Old 09-21-2011, 10:24 PM   #5
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Cool, where did you get that Corvette fuel line? Is it stock GM? Thanks
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 09-21-2011, 10:34 PM   #6
BLACK10
BLACK10's Avatar
its at Lethal Racing right now but i should have it back sat.
it is a stock 2004/C5 corvette braided fuel line
Old 09-22-2011, 09:49 AM   #7
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I would like to hear more about this please!!! I have the Tech AFX kit, and wish I could make the evap line shorter, seem ridiculous to wrap it all the way around the back of the cylinder head and route it up under the fuel injector harness!!! Can you PM me some info on how you did this??? Thanks.
blazzin1 is offline   Reply With Quote
Old 09-22-2011, 11:53 AM   #8
MRGOODWRENCH3
Here are some more pictures of my car. You can see how I routed the evap line. I cut the hose to length and reuse the fitting with a new clamp.
Old 09-22-2011, 11:56 AM   #9
blazzin1
blazzin1's Avatar
Thanks for the information!!! I will take a look at this and see what I can do. It looks like a special type of clamp...is that something that has to be bought at a dealership???
Old 09-22-2011, 12:22 PM   #10
MRGOODWRENCH3
The dealership will not have these type of clamps. I get them from a hardware wholesaler. They are crimped with special pliers. You can use a regular clamp and be ok.
Old 09-22-2011, 03:33 PM   #11
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Just curious...Why do you have to remove the manifold? It looks like there's enough room to get the fuel rail off. Thanks
Cam 427 is offline   Reply With Quote
Old 09-22-2011, 04:44 PM   #12
MRGOODWRENCH3
There is a bracket on the right rear of the intake manifold. One of the intake bolts go's through it. The bolts are long and it cannot be removed because it hits the sheet metal above it. So the intake must come out with the bolts and bracket still attached. After the fuel rail is rotated the bracket is no longer used. When the rail is rotated it puts the fuel pressure adapter in the rear. It will not fit with the bracket there. This is the best I can explain it. When you get in there you willl see what I trying to explain.
New Dual & Triple intank fuel set up IPS Brandon Forced Induction - V8 120 05-16-2012 06:56 AM
For the love of God, how do I get the fuel line disconnect tool to work?? blake-b Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 03-02-2011 05:53 PM
MPG for the Z28 OPP Camaro ZL1 Forum - ZL1 Specific Topics 71 12-08-2010 04:00 PM
Fuel vapor line not connected at the factory pennor Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 09-30-2010 04:58 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
