SDTW Custom Wheels & Tires
Old 09-21-2011, 05:44 PM   #1
Parag
Drives: 2010 camaro 2SS LS3
Question line lock function
i am looking into line locks and want to do some custom work with them. if you push the line lock button then push the brakes, is the petal just rock solid and does nothing, or does it feel fine and just rear brakes work?
Parag is offline   Reply With Quote
Old 09-21-2011, 06:17 PM   #2
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
you first turn on the line lock, then push brakes real hard and hold them down while holding in line lock button...release brake pedal while continuing to hold in line lock...as long as you hold button , the front brakes will be held..rear wheels are free to spin...release button and all brakes are off... a lot of people don,t push the brake hard and it can roll when giving gas,, your line lock will hold the amount of pressure you applied when pushing down brake pedal....if you only push lightly while holding in button, the brakes will only hold the front brakes lightly...that is why you must push brake pedal hard then hold in lock , to hold the hard pressure to brake,hope that helps.
mikepage0007 is offline   Reply With Quote
Old 09-21-2011, 06:26 PM   #3
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I had a switch that you turned on and stayed until you flipped the switch.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-21-2011, 06:28 PM   #4
Parag
thanks guy that helps, they work as a one way valve, i thought they were solid valve.
Old 09-21-2011, 06:34 PM   #5
mikepage0007
Drives: 2010 camaro
if you want more info , look up steve @ sjm...sjm search and you will find him..he will answwer all line lock questions you may have...real good vendor..
Old 09-21-2011, 07:00 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
you don't need to hold the button down. Usually there is one button that arms the system and then a second switch that activates the line lock.
Click to view my build thread
Old 09-21-2011, 07:06 PM   #7
mikepage0007
Drives: 2010 camaro
yeah, different ways, mine is hooked into cruise control.i turn on cruise-hit brakes hard-hold in cancel button -melt tires and release cancel button..but can be done diff ways
Line Lock Loc Launch Control Kit? SLO RYDE Suspension / Brakes / Chassis 28 11-29-2011 11:17 PM
tci line lock jam3 Dragstrip and Launch Techniques Discussion 22 08-23-2011 12:22 AM
Show Off Your Line Lock Switches HufferSS Dragstrip and Launch Techniques Discussion 16 06-30-2011 12:10 AM
line lock problems carbon8 5th Gen Camaro SS LS LT General Discussions 14 05-28-2011 01:53 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 11:58 AM
