Cold Air Inductions
Old 09-22-2011, 12:39 AM   #1
jatt5ab1soorma
Drives: Camaro 2011 LS
alignment questionn
is alignment needed if i get ss springs on the v6? i already got the ss sways on the v6, just wondering if alignment is needed after i get ss springs installed
jatt5ab1soorma is offline   Reply With Quote
Old 09-22-2011, 02:11 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Getting a performance alignment is a good idea even if you haven't lowered it. That being said, I doubt there's enough height difference to make it a absolute necessity.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-22-2011, 06:34 AM   #3
pRodigy
pRodigy's Avatar
Drives: 2011 black 2ss/rs M6 "hayley"
does anyone have a performance alignment spec for v8 stock suspension? its a dd and is theres anyway i can tweak it to perform better that would be awesome.
trying to get the most out of life... & then some more..
pRodigy is offline   Reply With Quote
Old 09-22-2011, 07:13 AM   #4
Brian@AirLift
Drives: AirLifted Camaro
Any time you remove the struts, you need to get your alignment checked. Any change to the relationship of the strut at the knuckle causes camber and thus toe change. No way to tell that it is all OK unless you measure it.
Brian
Brian@AirLift is offline   Reply With Quote
Old 09-22-2011, 08:27 AM   #5
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
you also need an alignment because your ride hight is changing due to the ss ride high is lower than the ls ride hight so the easy answer to your question is yes
camaro4mybday is offline   Reply With Quote
Old 09-22-2011, 10:00 AM   #6
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Just as Brian mentioned earlier, when you remove the strut it's a great idea to get an alignment... coupled with the small change in ride height with the spring change I would take this opportunity to get a quality alignment done.
Here is a link to our alignment specs. I would start by using the Performance Street spec, that should give you good tire wear and a good improvement in handling over the stock alignment. Pfadt Race Engineering Alignment specs!
Old 09-22-2011, 01:48 PM   #7
jatt5ab1soorma
thanks for the sheet alignment sheet you provided PFADT, so i just print it out and give that sheet to the guy im getting my alignment done from after i get the ss springs installed on the v6 right and ask him to do it accordingly to the first one?
Old 09-22-2011, 02:22 PM   #8
PfadtRacing
Yep! Exactly. Those alignment specs are definitely attainable with the stock adjustment bolts.
Alignment Help Thread Hotchkis Suspension / Brakes / Chassis 739 10-12-2017 10:15 PM
2010 camaro RS wheel alignment eap0108 Wheels and Tires Talk Sponsored by The Tire Rack 14 06-17-2011 06:07 PM
Alignment Special & Other Services Offered Drew@Speedware USA - Northwest / Pacific Northwest 0 06-15-2011 05:22 PM
Alignment kit needed for lowering springs? gm2376 Suspension / Brakes / Chassis 3 04-11-2011 12:16 PM
Wheel Alignment Questions OldSchool Suspension / Brakes / Chassis 2 09-17-2010 11:07 AM
