Cold Air Inductions
Old 09-22-2011, 01:46 PM   #1
busman721
busman721's Avatar
Drives: 2011 camaro 2ss/rs
Hotchkis spring question
Got my 1in lowering springs last night and was wondering about having to loosen the susp to allow the bushings to seat properly? Also has anyone installed drop springs and skipped the alignment? Or is it necessary to get an alignment?
Camaro>mustang
busman721 is offline   Reply With Quote
Old 09-22-2011, 01:55 PM   #2
faSSt
**Sold n' Sad**
faSSt's Avatar
Drives: 11 F150 Supercrew FX4 5.0
Some people call it "preloading" the bushings or "timing" them. It is required so that they don't twist/bind with the car being an inch lower. You will need to loosen all pivot point on the arms, lower car (an easy drive around the block is best) and retighten the bolts you had loosened. If you dont do this it will lead to premature wear on your bushings and also add a little more bounce to the ride.
I'm not real sure about the alignment, but I would guess your not making the most out of your springs and probably going to wear tires quicker as well.
Good luck and enjoy the springs!
2011 Camaro 2SS, SIM, 6M, HUD, 10% tint, black out lenses, SS emblems, TSP 304 LT's, Roto-Fab, MGW shifter, gto res, 8K BFXENON, HP Tuners, Redline Fluids. ***Sold*** Now in an 11' F150 supercrew FX4.
Still addicted to the this forum
faSSt is offline   Reply With Quote
Old 09-22-2011, 02:00 PM   #3
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
yes on the alignment.. if you lower it you change the geometry
CC Performance is offline   Reply With Quote
Old 09-22-2011, 02:07 PM   #4
busman721
busman721's Avatar
Ok, Thanks guys
Camaro>mustang
Old 09-23-2011, 01:49 PM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Any time the springs are removed from the car, an alignment is necesarry. To remove the front struts, you must remove the alignment bolts that retain them to the spindle (knuckle). These adjust Camber which also effects Toe.
In the rear, most people will unbolt the lower control arms to get the shock/spring assembly out of the car. This also requires removing the rear camber adjustment bolt making it necesarry to re-align the car afterwards.
As for re-clocking (indexing, timing, etc.) the bushings, it is a good idea to do this anytime a suspension link is unbolted. This issue is sometimes misunderstood but really is a simple (although time consuming) process. Fore more info on when, why, and how to re-clock the suspension bushings visit this link:
http://www.camaro5.com/forums/showthread.php?t=153188
BMR guy is offline   Reply With Quote
Old 09-26-2011, 12:14 PM   #6
Hotchkis
Drives: 1st through 5th gen Camaros
Busman721 – It’s always a great idea to perform final torque of suspension bushings with the vehicle on the ground or with the suspension loaded at ride height. Any time you unbolt a strut assembly and install lowering springs you should have your car realigned.
Hotchkis is offline   Reply With Quote
Old 09-26-2011, 03:00 PM   #7
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
it's been well stated already, but yes you will need an alignment.
Anytime you do any suspension work that involved loosening or changes in ride height an alignment is required.
Info@PeddersUSA.com is offline   Reply With Quote
Congratulations to H-Team member Rob Byrd for his Camaro5 Fest win! Hotchkis 2011 Camaro5 Fest (II) 24 04-22-2011 02:52 AM
SUSPENSION QUESTIONS ? 1969to2010 Suspension / Brakes / Chassis 23 11-05-2010 02:58 PM
spring installation question kozzmo49 Suspension / Brakes / Chassis 2 03-28-2010 08:50 PM
