Old 09-22-2011, 02:58 PM   #1
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
TSP Small bore LS7 heads
Since there aren't any numbers anywhere on the web, I figured I'd just let everyone know that I'm going to flow them myself just so there's something out there, and get some good pictures. Very excited to have Texas Speed doing my 429 build, should make outstanding power. Should see these heads in two weeks or so, iplaced my order this morning.
DietCoke is offline   Reply With Quote
Old 09-22-2011, 04:27 PM   #2
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
I'd like to know how these stack up against Mast heads.
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
SilverSS3108 is offline   Reply With Quote
Old 09-22-2011, 05:09 PM   #3
Jason 98 TA
Drives: Camaro
Great to hear you have a set going!
These heads are a little bit different compared to the MAST heads. These heads were built specifically for the LS3 bore sizing where the MAST uses a 2.1" valve & goes on a much smaller bore. The PRC LS7 small bores are configured specifically for ls3 strokers in minds. It gives a proven port that has time & time shown to be one of the most powerful out there the ability to run on a LS3 bore.
Jason 98 TA is offline   Reply With Quote
Old 09-22-2011, 06:19 PM   #4
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
GMHTP magazine needs to do a CNC/hand ported GM heads VS Mast heads VS PRC LS7 small bore heads shoot out. It would be interesting to not only see how they stack up Hp wise but money wise. "Are aftermarket cast heads worth the money"?
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 09-23-2011, 02:55 AM   #5
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
congrats man. I need a set of heads myself. Sounds like your gunna have a rippin car for sure!!!
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 09-23-2011, 12:27 PM   #6
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
At Jason, how well do these heads wok on the stock shortblock with the 231-236 cam, a fast intake and full exhaust? Are they too much for a stock block, are they meant only to run on strokers? My mods are in my sig, pm me if you think they will work with my set up!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 09-24-2011, 08:43 AM   #7
SilverSS3108
Check out the fast list and find Texas Speed on the modified with no power adder and got to their post... PRC LS7s on stock bottom end
Question: can these heads be used on a L99 with DOD delete and keep the VVT?
Old 09-24-2011, 01:45 PM   #8
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
I'm pretty sure the car that set the record was an L99....
Kyle2k is offline   Reply With Quote
Old 09-24-2011, 06:16 PM   #9
scottywheels
Drives: 2010 A6 SS/RS
a light l99
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built
scottywheels is offline   Reply With Quote
Old 09-24-2011, 07:05 PM   #10
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
What intake manifold are you going to run with these Coke?
Squintz Palladoris is offline   Reply With Quote
Old 09-24-2011, 09:00 PM   #11
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
I'd really really like to run a big plenum ram like the holley or edelbrock but they only make them for cathedral and ls3 ports, so since I can't afford $2500 for a sheet metal, it's going to be a fast 102/102 for now.
Old 09-24-2011, 09:39 PM   #12
Squintz Palladoris
Thats why I asked. I would like to run the Holley intake on mine. Have you looked at the MAST Intakes? A bit spendy but definately cheaper than sheetmetal. If I go with an ls7 style head its probably the route I will take.
Old 09-24-2011, 11:04 PM   #13
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Mast intakes are just as much as a sheetmetal. Still looking at $3000. I'd just have a lower fabbed to mate to the holley 105mm hi ram top. At any rate, i expect to beat tsp's time by at least 5 tenths and claim the #1 spot all motor. We'll see.
Old 09-24-2011, 11:21 PM   #14
Squintz Palladoris
I just checked their site. The 2 piece CNCd intakes are 1750.00 for LS3 or LS7 heads for either a 4150 or 4500 style TB.
Let me know what you find on making the Holley intake work on the LS7s. If that is an option then I may be interrested as well. I'm no where near starting on motor stuff right now. Just kickin some ideas around. Building the rest of the car 1st. Hopefully will be able to get on top of the "Bolton" list before I do any motor work
Brad
My First Hot Rod Darin Morgan Member Car Journals 123 12-07-2011 08:49 PM
SEMA CAMARO: LS7 Camaro Tran Camaro Photos | Spyshots | Video | Media Gallery 157 10-16-2009 10:26 AM
LS7 Camaro....some assembly required Txturbo 5th Gen Camaro SS LS LT General Discussions 11 11-03-2008 01:17 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
