Emblempros
Old 09-23-2011, 02:18 PM   #1
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
V8 springs
Just replaced my stock.... have a buyer who has a V6. I just want to verify before I put us both through the hassle, will my V8 stock springs fit the V6?
Newbie question, I know, and I apologize... they may even be the exact same springs for all I know.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim.
Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C.
1100 7/02 Ordered
3800 8/09 Order produced
4200 8/13 Shipped
6000 8/24 HOME!
brantley847 is offline   Reply With Quote
Old 09-23-2011, 07:17 PM   #2
brantley847
v It bites.
+1 great post, brantley... keep up the good work
2011 2SS/RS
1100 7/02 Ordered
4200 8/13 Shipped
6000 8/24 HOME!
Old 09-23-2011, 07:46 PM   #3
Synner
Drives: 2011 2SS/RS M6
They'll fit and are a bit lower than the v6 springs and a bit stiffer
Old 09-23-2011, 09:23 PM   #4
brantley847
v It bites.
You sir... are a scholar and a gentleman.
2011 2SS/RS
1100 7/02 Ordered
4200 8/13 Shipped
6000 8/24 HOME!
Old 09-24-2011, 08:29 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What year V6 are you selling to? I know that aftermarket springs had to change for the later model 11 V6's. Might be worth waiting for someone that really knows.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-24-2011, 09:02 PM   #6
jatt5ab1soorma
Drives: Camaro 2011 LS
Hurrry brantleyyy lol
jatt5ab1soorma is offline   Reply With Quote
Old 09-24-2011, 10:30 PM   #7
Carriccp
Carriccp's Avatar
Drives: Sold
Would ride quality suffer by changing only the springs from the V8 to the V6? I am interested in doing this as well to get the stance of the V8, but am unsure if I need to purchase the springs only or if I will need the shocks and the springs. Great thread Brantley.
Carriccp is offline   Reply With Quote
Old 09-24-2011, 11:06 PM   #8
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
The combination of SS struts AND SS Springs will drop a V6 1/2 inch. Not sure if the springs by themselves will do it.
About a month ago, I installed the SS struts with Pfadt springs and dropped my V6 1.75". Pfadt advertises their springs at 1.25" so the SS struts make up the other 0.5".
I know another V6 owner did a complete SS strut/spring swap and his car dropped 0.5".
You do not need to change any other suspension parts when changing the struts or springs. I'm still using my stock V6 sways, end links, etc.
Oh, and I love the ride now.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 09-24-2011, 11:42 PM   #9
brantley847
v It bites.
I guess Jatt will let us know soon if they fit lol
2011 2SS/RS
1100 7/02 Ordered
4200 8/13 Shipped
6000 8/24 HOME!
Old 09-25-2011, 12:08 AM   #10
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by Comrando View Post
I imagined it would have more push with the higher rate springs in the front.
I just checked the Wiki and the V6 is 80 lbs. lighter than the 8. I thought it would be more.
I'm the other V6 owner, rides nice with SS suspension. Changed the sways, springs, struts and shocks. Got a set of brembos too. The rear toe links are different as well between FE2 and FE3. But ordering the RS package game me the FE3 rear toe links so there was no need to change them. Everything else is basically the same between the two.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 12-05-2011, 07:31 PM   #11
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
appreciate all the info
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
So let's set this straight on what gives it that v8 sound CamaroC-17 5th Gen Camaro SS LS LT General Discussions 112 01-03-2017 11:06 AM
F/S: 2010 Camaro Pfadt lowering springs (used) CharlSS Local Marketplace 16 08-23-2011 08:14 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
