BeckyD @ James Martin Chevy
Old 09-24-2011, 11:19 PM   #1
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
LFX Engine Oil Cooler
Just read that the LFX in the 2012 Impala has an engine oil cooler. Since the 2012 V6 is the LFX and the LLT shares largely the same components. Of course this is only speculation, but we may have an engine oil cooling option.
http://media.gm.com/media/us/en/chev..._ppv/2012.html
Impala Police performance
The new LFX3.6L V-6 becomes the standard engine in the 2012 Impala Police, replacing the previous 3.9L engine and delivering 31-percent more horsepower.
The 302-horsepower (225 kW) LFX is a 60-degree design, with the cylinder block and cylinder heads cast in aluminum for low weight. A forged steel crankshaft provides optimal strength in the bottom end, while the cylinder heads include four valves per cylinder, with a dual overhead camshaft design incorporating infinitely variable cam phasing.
Additionally, optimized-flow fuel injectors and the integrated exhaust manifolds/cylinder heads promote lower emissions. The LFX’s composite intake manifold also has a comparatively small radiated surface area to help it maintain excellent noise and vibration characteristics that are comparable to an aluminum manifold.
The 3.6L engine is backed by a new six-speed automatic transmission that is performance-calibrated for police duty.
Additional powertrain and vehicle system features include:
2.44 axle ratio.
170-amp high-output alternator.
Engine oil, transmission and power steering coolers.
Seventeen-inch wheels replace the 2011 models’ 16-inch wheels.
Goodyear P235/55R17 W rated tire
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 09-25-2011, 03:01 PM   #2
blackTT600
Drives: 2011 2LT M6 SC
that would be a great option. especially am OEM part
blackTT600 is offline   Reply With Quote
Old 09-25-2011, 03:27 PM   #3
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
good find. Lets see what this can do for our LLTs
CAMARO
Old 09-25-2011, 09:56 PM   #4
nak3dsnake
nak3dsnake's Avatar
I'm trying to get some more details, hopefully some part numbers. I'd assume the LFX on the caprice's has the same oil cooler.
Old 09-26-2011, 02:08 PM   #5
nak3dsnake
nak3dsnake's Avatar
Ok so nothing on the LFX PPV engine oil coolers but I'll probably have to go to a dealer to get the info since neither have been out long. I have however discovered that the 2.8 Trubo, which is also a member for the High Feature family, has an engine oil cooler. The parts blow up is below with the LLT below it. Looks like it will mount right up to the block, but the mounting location on the LP9/LAU oil pan is not on the LLT oil pan.
LP9/LAU with Engine oil cooler.
LLT
Old 09-26-2011, 02:13 PM   #6
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
so we might have a possibility to mount this. NIce work!
CAMARO
Old 09-26-2011, 06:47 PM   #7
nak3dsnake
nak3dsnake's Avatar
Here's another view showing hose running to the radiator. Parts 33 and 31. I have part numbers for anyone else who wants to experiment!
AC compressor also mounts up with a different bracket to allow room for the oil cooler. It also looks like the engine mounts would get in the way of the coolant lines from this view.
LP9/LAU
LLT
Old 09-26-2011, 08:50 PM   #8
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
What is gained by having an engine oil cooler?
JohnZ is offline   Reply With Quote
Old 09-26-2011, 09:11 PM   #9
nak3dsnake
nak3dsnake's Avatar
It has several benefits. Oil breaks down over time, the hotter the oil gets, the faster it breaks down. By lowering the working temperature of the oil, the quality of the oil lasts longer. Cooling and extending the life of the oil also extends the life of the engine. The cooler an engine runs, the longer it will last.
Old 09-28-2011, 10:14 AM   #10
bmorecam
My P71 crown vic used to have a oil cooler lol. Although it is a nice addition one thing you have to realize is that our engine oil is full of moisture. One of the reason why gm does not always let our motor stay cool is because the moisture need to be boiled out. The temp has to be 212F and over for this to occur. In a situation where massive heat is a concern like a police cruiser that stay idling over 12hrs per day, or in a race specific situation where taking the motor to the limit is a dalily job an oil cooler will be necessary. Just make sure whatever oil cooler you guys get it has a thermostat built in. You don't want the motor to stay to cool at all times keeping moisture in and causing corrosion and other problems in the long run.
Old 09-28-2011, 10:30 AM   #11
nak3dsnake
nak3dsnake's Avatar
That's why I'd prefer the OEM one. The one above uses the stock sensor to monitor the oil temp and pressure. The one for the RWD caprice however is not in the catalog yet.
Old 09-29-2011, 09:47 PM   #12
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
It's great that GM finally put a 6spd auto in the Impala and that they put the 300+ LFX in also, but a 2.44 axle ratio? Are you kidding me! At least put 2.92 in, or something. I know the6 spd has more advantageous gearing but in the real world these tranny shift up to the next higher gear so fast that you don't get a chance to use the extra power.
b4z is offline   Reply With Quote
Old 05-07-2013, 11:28 AM   #13
Skexies
Nobody of Interest
Skexies's Avatar
Drives: 2012 2LT/RS A6 'vert "Ra"
OEM fit and finish may be nice. In the meantime, has anyone installed an aftermarket oil cooler on the LFX yet? Details / Write-up?
Skexies is offline   Reply With Quote
Old 08-27-2013, 09:29 AM   #14
Skexies
Nobody of Interest
Skexies's Avatar
For those that may be interested, I found someone that is working on an aftermarket adapter to allow an oil cooler on some BMW motors that have a similar oil filter setup as we do (cartridge). He said he would be interested in designing and producing a quantity for the LFX if there was enough interest.
2012 2LT/RS A6 Convertible IOM "Ra"
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 166 05-23-2014 07:31 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 03:55 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 10:33 PM
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 07:50 AM
