| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
Boston Subs that will DESTROY
I'm going with 2 of these in the trunk of my Camaro
http://mobile.bostonacoustics.com/ca...product_id=374 They are 12" subs with tuned passive radiators...each one puts out the power and db of a 15" sub. Two of these babies is going to be just ridiculous. I'll have 400 watts RMS per sub going to them for now and if that's not enough I'll upgrade. I figure these are perfect for the Camaro considering the small trunk opening. I'll put one in at a time and position them in the best sounding spot.
We are the early orderers...we are GM's voluntary guinea pigs and their free source of feedback. How will we be thanked?
2G1FT1EWXA9103351
Drives: 2SS RS, SIM, 6pd, 20"Alum Join Date: Oct 2008
400 watts? Which amplifier?
You going to hook it up straight to the battery in the trunk or get a 2nd battery? |
![]() ![]() ![]() ![]() ![]() Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
I bought this one already i think i need only one though its the most powerful sub Boston acoustics are selling. 1000 watt rms at 2ohms
http://mobile.bostonacoustics.com/ca...product_id=373 |
Yeah I looked at the SPG, but honestly in my experience those monster type subs require too much power to sound good. The D5 is much more efficient and besides I'll be sticking with the stock sound system inside the car so I don't want to overpower it too much anyhow.
And the amp I'm going to use is an Akai ACA-2104 http://www.akai.com/product_detail.a...id2=24&id3=161 This is a low price amp that puts out a good 800 watts RMS at 4 ohms in bridged 2 channel mode. I've seen reviews that put it on par with 1200 watt RMS Audiobahn amps. But still I'm not positive it will be enough for the D5's so if it doesn't hit hard or clean I'm going to man up and get a proper Earthquake amp. I haven't decided if I'm going to go with a 2 fared capacitor or run a 2nd battery. I really hate adding a ton of weight so I'm leaning towards the cap....either that or get a lightweight battery for my primary and use the stock battery as the amp power. In fact I'm so concerned about adding weight I'm considering making my own custom enclosures from fiberglass instead of the mdf Boston boxes.
i have already matched it with an amp, its a little on the pricy side am not buying it from here though i know their items are way over priced
http://www.crutchfield.com/p_500PDX1...owAll=Y&tp=115 And i know its alot of extra weight but i doubt i will be racing too much......unless i see a mustang |
#6 |
Nice amp...that'll do the trick. I used to rock this Earthquake D2 http://ampguts.realmofexcursion.com/Earthquake_PH-D2/ until I had a flat tire and let the speaker wires touch the trunk lid of my Lexus. POOF it went.
#7 |
you have to be careful when buying a amp because they will advertise that you are getting 1000 watts and you are really getting 400 rms at 2 ohm and 150 rms at 4 ohm and you drive up to someone thinking you have the best shit in the world, and come to find out my tweeters are louder than your subwoofers.
#8 |
![]() Drives: 2002 mercury mountaineer Join Date: Apr 2009
look at ohm ratings when buying a amp if its 1000 at 1 ohm what is it at 2 or 4... it will decrease but will sound better in the long run...
#9 | |||
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
A lot of amps are that way. Most will be rated for 1000 watts x 1 at 2-ohms but go down to 500 watts x1 at 4-ohms. That Alpine somehow is rated for 1000 watts x1 at both 2 and 4 ohms, which is handy. |
#10 |
Delivered 29June09
You're on the right track here!!
I'm running 2 of the SPG-555 in my 07 Avalanche. Each one has a dedicated PDX-1000 and the rest of the components(BA Pros) running on a PDX-4.150. The subs hit hard and everything is sonically correct. The amps get very hot, which is a concern, and they suck a LOT of power. I'm running 2 yellow tops with an isolator and I still have problems with lights dimming.
2SS/RS, VR, Blk hockeys, Blk leather, MN6, sunroof, GFX
Delivered: 29 June 09 !!! Current: '57 BelAir 2Dr Post '07 Avalanche LTZ (daily driver) '10 Traverse (wife's demo) '99 Harley FLHTC |
#11 | |
#12 | |
a .5 Farad capacitor for systems up to 500 watts a 1 Farad capacitor for systems up to 1,000 watts a 2 Farad capacitor for systems up to 2,000 watts |
#13 |
Yeah the yellow tops will only provide reserve power and rundown protection...they probably can't discharge as fast as a capacitor to prevent dimming.
I was thinking of maybe building a custom enclosure in the spare tire well. I saw some photos of that opening today and it's very large and deep and since I'm getting an SS it won't have a spare anyways....also the battery is right there so talk about easy hook up. Would there be a downside to connecting the amp ground directly to the negative post of the battery?
#14 |
how do you plan on connecting the amp ground to the battery post, seem like the mat wouldn't sit flush might be wrong though.
#15 | |
AND NEVER EVER EVER connect the amps neg to the batt's neg all the way upfront.. thats asking for a fire... run a 150amp fuse from the power wire off the batt to the amp about 18 inchs from the batt. then ground off the amp as soon as possible to the body of the car.. sand down to bare metal.. http://www.kinetikaudio.com/default.asp batts they will save you in the long run... caps are just a bandaid to the rest of your system..
#16 |
![]() Drives: 2500 hd Join Date: Jan 2009
best way to hook up a big system is to take it to pro
#17 |
Or just really do your research as some shops do not do great work...
this is from a shop in IL ![]() ![]() Big Steve strippn shit ![]() ![]() ![]() ![]() ![]() Amps are held on the headliner by zip ties......lol ![]() speakers punched thru ![]() ![]() This pic really is not funny.... but what you don't realize is that the door has been made out of construction styrofoam and was even carved to make the speakers look like they are fiberglassed in. wow
#18 |
nice subs how much
#19 |
those subs arnt that great lol.. walmart subs. probably 100 bucks a pop..
if you want some really good and cheap subs go with dc sound lab.. http://dcsoundlab.com/specs.html contact them for some really good subs and the dustcaps can be special ordered any color..
#20 |
Delivered 29June09
I've never been a fan of caps...like another post said, just masks the problem. I drive my system hard too so not too surprised this is happening.
My A/V guy wants to redo the system but of course that takes money which is all going towards my new SS/RS. Besides, anytime he touchs my vehicles the bill has never been less than a $1K. I'm using the BA Pro components in my Avy now...tweets are just a bit "bright" but sounds good. If you want a system that will just blow your mind, sonically correct, and just sounds incredible you should listen to the DynAudio component setup....it is by far the best I've ever heard....but a bit pricy for most folks.
#21 | |
And since the battery for the Camaro is in the trunk right next to where his amps are going to be, he's not really risking a fire by connecting the ground to the battery's negative terminal because the ground wire won't be that long. I don't know if that'll harm the battery at all, though, because I'm not familiar with that kind of situation. I've never had a battery that close to my amps before to even try attaching the ground wire directly to the battery. |
#22 |
Well if you want to start talking sounds i have alot to say. yes alot of people are right that amps will say 2000watts but really only 500 watts on a good day. now it all depends on what you want do you want clarity or ghetto base. now clarity i am talking rooling down the street with your windows up system cranked to 25 and you hear the lyrics and the base clearly. or you can go with just windows up and car rattiling and muffled sound. go check out www.hertzaudiovideo.com now these two brands are insane. pricey but worth it. i only have one 12" hertz es 300 running off a 6.900 arc audio amp and at 4 ohms i am only putting out 155 watts rms and people can't belive how loud it is. i hit 127dbs and you can also hear the lyrics clearly. like a home theater with out a sub clear and i am running avi components for that. check it out. also check out sightwaves.com for ordering any of the stuff
#23 | |
batt is the only safe way to go.. and it doesnt matter if the batt is 10 inchs away from the amp you always want the best possible ground you can get... and where do you get that... The body itself... and read the little note on the site i posted... it will take 100 farads to equal ONE 600cell batt.. so you will spend 100 dollars on a 1 farad cap or 200 on a batt??? that is 100 times as powerfull i just bought 4 of the hc16s and there great... and lots of power..
#24 |
A battery cannot discharge as fast as a capacitor.
But isn't it true that you can remove a car battery after the car has been starting? So headlight dimming wouldn't be a battery issue it would be an alternator issue.
#25 | |
and yes you can unhook them but you will most likely FRY the electric system.. the first tip is to run a bigger batt up front(or in back for this case) and a bigger one in the back.. then upgrade the alt to something like a 250amp (300 or above is way to hard to spin and keep cool)... or if you get h.i.ds you wont get that much of a dim because the hids require almost half the power (35 volts compared to 55) This is a team mates hhr and its load thats a hifonics TEN THOUSAND WATT RMS AMP.. look at how many batterys he needs.. NOT ONE SINGLE CAP. and he hits 149.9 db daily.. he is pushing 155db... ![]()
| Thread Tools | |
| Are the Boston Acoustics & base head unit the same? | hdhomer | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 34 | 01-19-2012 12:54 AM |
| BOSTON ACOUSTICS!!!!!! | TAG UR IT | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 126 | 03-12-2010 01:04 AM |
| Press release: 2010 Camaro Audio by Visteon and Boston Acoustics | Mike C | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 49 | 07-07-2009 02:11 PM |
| Subs | XAnimal | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 25 | 02-27-2009 11:44 AM |
| Pics from the Boston Auto Show | mmelson | Camaro Photos | Spyshots | Video | Media Gallery | 10 | 12-07-2008 02:26 PM |
