Solo Performance
Old 09-25-2011, 08:18 AM   #1
B Mccue
Drives: 2011 1ss ls3
Tools needed for high flow cats install
Can someone help me out with a tool list for installing my high flow cats? I want to make sure I have everything I need before I start.
Socket and wrench sizes?
how long of an extension to reach the manifold flange bolts
Do I need a swivel?
I'm going to borrow an o2 socket from the parts store, so that shouldn't be an issue.
I hate making trips to the store for that one wrench I don't have while in the middle of a job.
Any help, tips, and cautions will be greatly appreciated.
RX catchcan, Vmax tb, Sullivan Racing billet pedals, Magnaflow 4" bullets. Solo High Flow Cats, Dyno tuned by ARD Houston, 390 RWHP 394 RWTQ,
B Mccue is offline   Reply With Quote
Old 09-25-2011, 08:22 AM   #2
IROCanSS
Drives: 89 IROC 350
People have a hard time removing one of the O2 sensors. Just FYI. Not sure on sizes... My guess is 15mm. I forget and my car is too low to go check.
I'd have a 6" and 12" extension. Good tools to have. I never mind buying tools.
Old 09-25-2011, 08:27 AM   #3
B Mccue
Thanks, I'll buy both extensions, I'm guessing as long as I have a range of 14 to 18 mm shallow sockets, the extensions, the o2 socket, that should be it?
Old 09-25-2011, 09:16 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
I believe the bolts on the back end of the cats are 13mm.
Click to view my build thread
Old 09-25-2011, 09:26 AM   #5
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
Probably a good idea to soak all the bolts and O2's with penetrating oil for a while before you get started.
I prefer
bucketobolts is offline   Reply With Quote
Old 09-25-2011, 09:47 AM   #6
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Post up your gains when you get some after the install. Thanks
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-25-2011, 09:55 AM   #7
IROCanSS
Drives: 89 IROC 350
BUY DEEP WELL!!! The shank is pretty long and a shallow probably wont work!!! I had to go buy a deep well.
Maybe...
I prefer
GREAT IDEA!
Old 09-25-2011, 10:03 AM   #8
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
I bought an O2 sensor socket from my Snap-On guy,Its 22mm.
Also,make sure the exhaust is hot,I know it would be easier if it was cool,thats what me and my buddy thought,but it will make taking the O2 sensors out a lot easier and will help prevent stripping the threads like I did on one of mine when we removed it :(
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 09-25-2011, 10:10 AM   #9
B Mccue
Thanks guys, looks like I need a couple of extensions and a 15 and 16 deep socket. Do I need a swivel to get the back manifold nut? Do I need someone under the car or can I do this myself?
Old 09-25-2011, 10:15 AM   #10
MS3DALE
MS3DALE's Avatar
No,no swivel was needed for mine.
It would help to have someone under the car,thats how we did mine,we actually removed the manifolds and cats together,but I was installing my LT headers,hi-flow cats,and CORSA all at the same time.
Are you just doing cats? or do you have headers too?
Old 09-25-2011, 10:16 AM   #11
B Mccue
just cats, I don't have anyone to help me today and don't want to wait.
Old 09-25-2011, 10:17 AM   #12
MS3DALE
MS3DALE's Avatar
OK,are you planning on removing your exhaust manifolds,or are you just trying to remove the cats only?
Old 09-25-2011, 10:18 AM   #13
B Mccue
cats only
Old 09-25-2011, 10:19 AM   #14
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I did my whole exhaust system by myself. Just get her as high as you can. So you are just changing the cats? I installed headers so the manifolds came off with the cats but you do need a deep 15 mm socket. Spray the bolts real good the day before will help.
Good luck.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Solo Performance LS3 and L99 High Flow Cats GOINGSOLO2 V8 Bolt-Ons & Tunes 169 04-20-2015 06:15 PM
Doug thorley shorty headers, JBA midpipes and high flow midpipes with cats $600.00 camaro5o Local Marketplace 2 07-03-2011 11:55 AM
F/S Solo Performance high flow cats ssmike V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 18 06-20-2011 02:03 PM
CAMARO NEEDED FOR DROP COIL INSTALL IN SF BAY AREA Info@PeddersUSA.com USA - California 46 04-23-2010 01:33 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
