JUICEDMOTORSPORTS
Old 09-25-2011, 11:19 AM   #1
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Talking How To Properly Clean And Re-oil An Oiled Filter
This is a very common question so we asked Bill Hylton, the V.P. of Sales and Marketing for Cold Air Inductions Inc. and the newest contributor to TheHorsepowerJunkies.com, to write a quick article. Hopefully you will find it helpful.
Added Sep 21, 2011, Under: General Automotive
One of the questions that Cold Air Inductions Inc. hears more frequently than almost any other question is how to properly clean and re-oil an oiled filter (this process is often referred to as “recharging” your filter). The answer is typically a lot simpler than most consumers expect to hear! By recharging the filter you can reduce air flow restriction caused by debris build up on the filter, as well as bring the filter closer to its original appearance. Recharging the filter prolongs the longevity of the filter, allowing you to re-use it rather than discarding it, thus making your oiled filter a lifetime use filter.
Although many oiled filters use the same recharge process, and sometimes the same type of filter oil, the process described below applies strictly for the Cold Air Inductions Inc. high performance oiled air filter, and is not intended to be followed or implied as proper recharge instructions for any other brand filters. Although most of the oiled filters on the market follow the same basic recharge steps, it is always recommended to follow the instructions provided by the manufacturer of your oiled filter. Here are the steps to recharge a CAI Inc. oiled filter:
**Before starting ensure to use the proper safety precautions such as gloves and safety glasses**
Step 1. Remove – Remove the filter from your vehicle and ensure that no dirt or other debris enters the intake tube while the filter is off.
Step 2. Pre-Clean – Using your hand and/or compressed air (no more than 100 psi using a standard air nozzle) remove the larger visible debris from the outside of the filter. When using compressed air keep the nozzle at least 6” from the filter media.
Step 3. Clean – Spray the outside of the filter with the supplied CAI Inc. cleaning solution until the entire outer filter media is evenly saturated. Allow the filter to rest so the solution can soak in for 15 minutes.
Step 4. Rinse – Rinse the Filter with warm water by running the water from the clean side of the filter thru to the dirty side of the filter, so that the water can flush the dirt out and off of the filter.
Step 5. Dry – Allow the filter to air dry naturally. (DO NOT use heat sources in attempt to dry the filter faster as this may damage the filter media fibers and/or shrink them.)
Step 6. Oil – Once dry, apply the supplied CAI Inc. oil solution to the outside of the filter media using 1 spray for every 2 square inches of filter media. DO NOT OVER OIL
Step 7. Dry – Allow oiled filter to dry for 30 minutes so that oil can soak into and “recharge” the filter media. You should be able to handle the filter without the oil coming off on your hands, once this is the case your filter is ready to be reinstalled.
Step 8. Reinstall – Properly reinstall your recharged filter and make sure all connections are tight.
Hopefully this article clears up some of the confusion surrounding how to properly “recharge” an oiled filter. For more information regarding oiled filters and cold air intakes, visit our website at www.ColdAirInductions.com I hope that you have found this information helpful, and look forward to bringing you more informative articles soon!
**The process described above applies strictly for the Cold Air Inductions Inc. high performance oiled air Filter, and is not intended to be followed or implied as proper recharge instructions for any other brand filters. Although most of the oiled filters on the market follow the same basic recharge steps, it is always recommended to follow the instructions provided by the manufacturer of your oiled filter.**
Old 09-26-2011, 10:17 AM   #2
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Hey that guy sounds like he knows his stuff HAHA.
Sales @ CAI Inc is offline   Reply With Quote
Old 09-26-2011, 10:53 AM   #3
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
This should have been posted and stickied when the oiled filter intakes first started being put on our cars. It's not hard to the people who do it regularly, and its overlooked just how easy it is to screw it up. Great job.
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
SilverSS3108 is offline   Reply With Quote
Old 09-26-2011, 11:12 AM   #4
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini
Thanks for the info and posting it.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X,Monster Triple,Alky Control Meth Inj Feb12th Install.
SSBUSDRVR is offline   Reply With Quote
Old 09-26-2011, 08:00 PM   #5
Apex Motorsports
Only about half of the time.
We get questions about filters constantly. That is why we turned to Bill to produce some articles to address some them. If you haven't already seen it, he posted a great article on oiled versus dry filters a few weeks ago.
Choosing A Dry Or Oiled Media Filter For Your Vehicle
Old 09-26-2011, 08:36 PM   #6
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
How often are you guys cleaning these?
I have no issues cleaning the filter, as it is rather easy... but do you guys ever clean the tube portion of the intake itself?
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 09-27-2011, 09:28 AM   #7
Sales @ CAI Inc
There should be no reason to clean the intake tube, the filter will collect any debris that actually matters. Cleaning the inside of the intake tube would not be of any added value that I can think of.
Old 09-28-2011, 06:59 PM   #8
Apex Motorsports
Most manufacturers recommend every 50,000 miles but you can do it more often if you like. I know some guys that do it every time they change their oil. That is excessive but to each his own.
Old 09-28-2011, 07:21 PM   #9
SC2150
Excelent Chase! Can't count how many come in soaked and all over the MAF as well.
Old 09-28-2011, 09:32 PM   #10
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
thanks for the info!!! gonna try cleaning it tomorrow
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 09-29-2011, 10:37 AM   #11
Sales @ CAI Inc
Sounds good, you should have no problems, its pretty simple!! Let us know how it goes!!
cai, oiled filter, recharge an oiled filter
