Solo Performance
Old 09-25-2011, 11:22 AM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
Exclamation Kooks LT: Steering wheel shaft clearance
I just finished the installation of my Kooks LTs. I had to disconnect the steering wheel column to get enough room. After putting everything back together I notice that the rubber boot of the steering wheel column touches the headers. I dont see a way to get some room between. Did you remove this boot? Any suggestions are highly appreciatet.
mike.nite is offline   Reply With Quote
Old 09-25-2011, 11:37 AM   #2
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Hmm,I also removed my I-shaft for clearance,but I had no issues with the boot afterwards
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 09-25-2011, 11:39 AM   #3
mike.nite
mike.nite's Avatar
hm - this is so strange. So it does not touch anything? Is there a possibility you can take a pic of your installation?
Old 09-25-2011, 11:40 AM   #4
mike.nite
mike.nite's Avatar
... I don't see a possibility to move/turn the steering wheel column to get more space...
Old 09-25-2011, 11:51 AM   #5
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Bad header. Have them send you a new one.
DietCoke is offline   Reply With Quote
Old 09-25-2011, 11:54 AM   #6
mike.nite
mike.nite's Avatar
The headers seem absolutely fine.
Did you keep the rubber boot or did you remove it?
Old 09-25-2011, 11:56 AM   #7
MS3DALE
MS3DALE's Avatar
Now after looking at mine I'm wondering...what boot? There is a boot up in the firewall,but its way up high,its no where close to the headers.
Old 09-25-2011, 12:01 PM   #8
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
My went in with out having to remove the steering column and the rubber boot is high away from the headers.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 09-25-2011, 01:11 PM   #9
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
I them on my SS with no clearance problems. Probably a V6/V8 difference. I didn't even know Kooks make headers for the 6.
RxDoc08 is offline   Reply With Quote
Old 09-25-2011, 01:14 PM   #10
mike.nite
mike.nite's Avatar
No I have a 2011 2SS (will update avatar asap)...
I now removed the rubber boot. Seems the only way to avoid melting.
Old 09-25-2011, 01:15 PM   #11
MS3DALE
MS3DALE's Avatar
OK,well that clears that up. But I'm still wondering what boot your having issues with.
Old 09-25-2011, 01:28 PM   #12
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
There is no boot anywhere on my steering shaft.
Old 09-25-2011, 01:28 PM   #13
RxDoc08
Jason
RxDoc08's Avatar
Is this the boot you're talking about?
Old 09-25-2011, 01:31 PM   #14
MS3DALE
MS3DALE's Avatar
Thats the only thing I see on mine,and its no where close to my headers.
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
LT Leather Steering Wheel - Black mauricioaglr Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 01-26-2011 05:57 PM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
