SDPC
Old 09-25-2011, 08:30 PM   #1
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Factory A6 shifter bolts thru floorpan
What size is the thread on these? Need to get some nuts, the kit didn't come with any? I'm referring to the bolts on the A6 shifter assembly (4) that stick through the floorpan to under the car. Any tips for disabling the brake pedal park lock are also welcome. I'll probably just end up cutting the lock off of the gate, but if there's a simpler way to make it work in an M6 car, then I'm all ears. (4L80)
DietCoke is offline   Reply With Quote
Old 09-26-2011, 12:29 PM   #2
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
The threads are M6x1.0
The park interlock solenoid can be removed completely from the shifter and that would disable that safety feature. You just have to remove the retaining tab by squeezing the prongs and pulling up on the tab. The solenoid will then slide out.
Kenji is offline   Reply With Quote
Old 09-26-2011, 10:26 PM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Good man.
MTI Racing Six Shooter Shifter MTI Racing Kevin Transmission / Driveline 6 10-28-2011 05:48 PM
MTI Racing Six Shooter Shifter MTI Racing Kevin Transmission / Driveline 11 10-28-2011 11:29 AM
Hurst Factory Short Throw Shifter CamaroEnergy4Life V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 12-20-2010 10:38 PM
Help with the factory shifter install motor1 5th Gen Camaro SS LS LT General Discussions 2 06-07-2010 09:58 PM
MGW SHIFTER COMPLETE FIRST RUN OF 25 TO SHIP SOON...FULL SPECS AND PICS MGW V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 59 12-26-2009 01:49 PM
