sjm autoprod
Old 04-01-2009, 03:42 PM   #1
Camaro ss 2001
Camaro ss 2001's Avatar
Drives: 2001 CAMARO SS # 846
Possible to put LS3 in place of LS1??
Hi
Is it possible to put LS3 engine on my LS1 CAMARO SS ?? or the gear need to be changed also??
cauz im thinking to replace my current LS1 to LS3 engine
any advice and tips??
Camaro ss 2001 is offline   Reply With Quote
Old 04-01-2009, 03:43 PM   #2
ponycrusher21
ponycrusher21's Avatar
Drives: the passenger seat
anything is possible.
they put LS7s in solstices.
Ponycrusher 21
ponycrusher21 is offline   Reply With Quote
Old 04-01-2009, 03:49 PM   #3
josh1147
Delivered 29June09
josh1147's Avatar
Drives: Early Order Camaro
Or put an LSX....any reason why you settled on the LS3 crate?
2SS/RS, VR, Blk hockeys, Blk leather, MN6, sunroof, GFX
Delivered: 29 June 09 !!!
Current:
'57 BelAir 2Dr Post
'07 Avalanche LTZ (daily driver)
'10 Traverse (wife's demo)
'99 Harley FLHTC
josh1147 is offline   Reply With Quote
Old 04-01-2009, 03:53 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
with this it is basically a bolt in swap:
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Old 04-01-2009, 04:14 PM   #5
Camaro ss 2001
I know bro but do i've to change the transmation with it or no that will e the question
Old 04-01-2009, 04:17 PM   #6
Camaro ss 2001
cauz the LS3 engine is avalible around 6500 USD and my current engine its mixing oil with water AGIAN!! ,i did overhaul for it before monthe's but unfortunately this time is decreasing the amount of oil in the engine and im finding them in the radiator agian
where i can find LSX engine??
Old 04-01-2009, 04:20 PM   #7
camaro1
camaro1's Avatar
no you do not have to change the transmission, the LS3 engine will bolt in place of any LSx engine,,
Old 04-01-2009, 04:21 PM   #8
Camaro ss 2001
i didnt get it,so do i have purchase this thing when im installing the new LS3 engine in my LS1 camaro??
Old 04-01-2009, 04:24 PM   #9
Camaro ss 2001
thanx bro,it helped a lot,it less i've to buy the engine only w/o suffering to pay for the transmation
thanx
Old 04-01-2009, 04:42 PM   #10
Vash
Drives: 00 Blazer
Probably just a head gasket blown. Who did the last one? Use Fel pro and make sure you torque it with a torque wrench.
Old 04-02-2009, 01:41 AM   #11
Camaro ss 2001
i didnt understand why it happend anyway cauz the gasket's are new from the dealer also the temp is normal the weather is nice here during this time of the year and I use it around 2000 mile after the overhauling and agian it started mixing oil with water
btw there's no Fel Pro gasket for 1997-1998 engine cauz this engine in my car is replaced with c5 engine (from 01 ss engine to 97-98 c5 engine)
Old 04-02-2009, 05:05 AM   #12
The_Blur
Rock Chalk
The_Blur's Avatar
Drives: Demon Super Sport
It will fit very well. The LS3 is a great motor. I would recommend, however, having some fun before the install. Make sure to upgrade some internals in case you want a beast in your garage.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 144:153 ban
Old 04-02-2009, 05:36 AM   #13
ADM PERFORMANCE
Drives: 2016 CAMARO SS
We will be selling our brand new Ls3 from our 2010
Just wanted to let you know we will have our 2010 LS3 available .
I will even throw in our ADM cam with it .
You can see the dyno here - http://www.camaro5.com/forums/showthread.php?t=11299
Call me and I will make you a hell of a deal.
214-228-8782
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 04-02-2009, 05:40 AM   #14
spd98
Drives: had a goat
yes it is doable. I would think for the price you could build an ls1 with simular or better performance for much much less. A set of heads and a cam on an ls1 will go a long way and be cheaper. If you build an ls1 stroker you can get the same displacment or better than the ls3.
spd98 is offline   Reply With Quote
LS3 vs L99? SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 09-18-2010 03:55 PM
Let me get this straight....LS3 vs. L99 MPG JMAN311 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 03-18-2009 05:27 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 09:21 AM
LS376/480 EFI LS3 Gen IV V-8 NOODLESgoneWILD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-04-2008 08:14 AM
Question for anyone that has actually put a down.... well down MerlinZero Camaro Price | Ordering | Tracking | Dealers Discussions 5 07-20-2008 11:26 PM
