sjm autoprod
Old 09-26-2011, 06:00 PM   #1
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Wavetrac Diff, Fluid compatibility
I am running a Wavetrac Diff in my 9". For now I just have some elcheapo 80/90 Walmart gear oil in there. Would like to replace it with some nice synthetic in about 250 more miles. They state not to run Redline Shockproof or any similar oil as it will void the warranty. Any of the other Redline oils are approved. Everything I can find in the local parts stores says its for limited slip which is not reccomended for this diff. Just wondering if anyone has had experience with this diff and running a nice oil in it. Thanks in advance!
Brad
Squintz Palladoris is offline   Reply With Quote
Old 09-26-2011, 07:55 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
from what i understand the gear driven differentials don't seem to work as well will the synthetic lubricants, for some reason they dont let the system work correctly and you will get single wheel engagement.Dana from Wavetrac is a friend of mine ill send an email and ask about the other oils.
Driveshaftshop is offline   Reply With Quote
Old 09-26-2011, 08:04 PM   #3
Squintz Palladoris
Thanks Frank, the info paper that came with the diff said that synthetics are fine. Just want to run whats best though. Even if its a high quality dino oil.
Old 09-26-2011, 10:13 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
be careful, because small changes are the difference to working or not, ask the right people, with the same diff, or the manufacturer of the diff.
Parag is offline   Reply With Quote
Old 09-27-2011, 11:26 AM   #5
Driveshaftshop
this is right from them
Hi Frank,
We actually tell people to avoid all Redline products, especially Shockproof.
Shockproof reduces any gear diff's ability to function by eliminating any chance of friction.
In a rear end, oil should be 75/90 or 80/140 or whatever is close to that.
We like:
Synergyn Syngear II 80w140 http://www.xentxsynergyn.com/synergyn/gear-lubricants/syngear-ii-case-of-12-1-qt-bottles.html
Motul Gear 300 75w90, or Gear Competition 75w140
Fuchs Silkolene/TITAN SYN5 75w90
Mobil1, etc.
Transaxles are different - customers should use the factory fill or equivalent performance oil.
Regards,
Dana
Old 09-27-2011, 12:13 PM   #6
Squintz Palladoris
Kick Ass Frank! Exactly what I needed
Thankyou very much!
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 09:10 AM
Diff Fluid and Tranny Fluid jagan323 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 03-15-2011 06:45 PM
Diff Fluid question adub Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 09-03-2010 09:07 AM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 08:21 AM
Rear Diff and Tranny Fluid Change Meet? Infern0 USA - Mid-Atlantic 5 04-08-2010 10:34 PM
