HeadlightArmor
Old 09-26-2011, 08:42 PM   #1
emsguy
Drives: 2012 2ss convertible
which bars?
no, not liquor bars. but I got your attention
for those of you with 1SS or 2SS convertibles, which sway bars did you get? did you also replace the end links?
also, did you lower the car? if you did, did you use the same manufacturer for the new springs and the bars?
please let me know the manufacturer and the vendor. also, are you a 1/4 mile person or a road race/autocross person?
thanks
emsguy is offline   Reply With Quote
Old 09-26-2011, 10:54 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
you can do pretty much anything, i know people that did each different thing you listed, and they all loved it. just keep in mind, that it sounds fun now to have race suspension, but not so much fun on those Illinois roads. all major brands have good parts, not many suspension problems out there. just do what you like, and you cant go wrong.
Parag is offline   Reply With Quote
Old 09-27-2011, 07:34 AM   #3
600hp-lpe
Drives: 2010
Pedders Sways.. They are adjustable.
No matter which away bar you go with, do the end links as well.. the stock ones are wimpy.
600hp-lpe is offline   Reply With Quote
Old 09-27-2011, 08:55 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
We have a ton of customers out there using our BMR sway bars with great success. The BMR sway bars are 3 way adjustable front and rear and can be used with either the stock endlinks or aftermarket endlinks like the BMR ones. You don't necessarily need to get the aftermarket endlinks, it just really depends on your driving style and what you want to do with the car. Either way you look at it aftermarket endlinks are considerably stronger than the factory endlinks. Here are some links to the BMR parts.
BMR 2010+ Camaro sway bars
BMR 2010+ Camaro sway bar end links
Old 09-27-2011, 09:13 AM   #5
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
BMR sways FTW.
Apex Chase is a wealth of knowledge on suspension questions you may have.
Drew10 is offline   Reply With Quote
Old 09-27-2011, 12:26 PM   #6
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
If I could only do one modification to a Camaro, it would be a matched set of sway bars. They really do change the entire attitude of these cars. You don't need to be a racer to feel an immediate improvement in the handling and balance of the Camaro. It's hard to remove 500 pounds from the car stock, but they do feel much lighter and easier to control after sway bars are installed.
Here is a video we took during some of our Camaro product development showing the differences before and after one of our sway bar installations.
We have packages that work on all V8 coupes and Convertibles, as well as spring and sway bar kits in one package.
Old 09-27-2011, 10:40 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
thanks
I don't drive the convertible, but my 2SS is lowered and running on Pfadt coilovers and sport sway bars. Don't bother changing sway bars without upgrading the endlinks and center links, you're just wasting your money IMHO. With Pfadt's latest endlinks there is no noise at all and you get the benefits and performance of solid heim joints.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 09-27-2011, 10:45 PM   #8
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Maybe that is why Pedders sway bars include endlinks
Old 09-28-2011, 11:06 AM   #9
Hotchkis
Drives: 1st through 5th gen Camaros
thanks
EMSGuy – What are you planning on doing with your Camaro? What else have you done to your car? Have you already lowered your convertible to improve handling with spring rate and lowered center of gravity? We just finished a 6 month R&D program on the Convertible platform and have achieved great results with bracing and our Hotchkis TVS kit. In fact, Trish Byrd has been competing in autocross events with her convertible with great success, winning her class at the last Super Chevy show in Vegas. Our kits are designed for maximum performance on the street, with a balance between a lowered stance, sports car handling and a comfy ride. They are tuned to work great on the autocross and road course as well, and our bracing radically improves traction in the ¼ mile, which is why Lingenfelter Performance puts our chassis brace on every Camaro they build, including the world’s fastest and quickest 5th Gen. But most importantly, our parts make good street cars into great street cars.
Hotchkis is offline   Reply With Quote
Old 09-28-2011, 11:36 AM   #10
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
i daily drive the pedders solution b sway bar kit with end links and i must say it has made the car more comfortable over bumpy roads. driving in nyc the roads are horrible i noticed a major improvement in the way the car rides over them. the performance aspect of them i can not say enough about. i have a problem going slow in the car because at high speeds the car is so agile and comfortable. another bonus is there gmpp and they come with great end links. not saying the other bars are not good i know the other companies have great reps but for me the only choice is Pedders!!!
camaro4mybday is offline   Reply With Quote
Old 09-28-2011, 11:38 AM   #11
JusticePete
VIR Specialist
And 3Js of course!
Old 09-28-2011, 12:43 PM   #12
camaro4mybday
"Camaro Joe"
thanks pete!
Old 09-28-2011, 02:00 PM   #13
emsguy
I am looking for a balanced and controlled street ride. I am coming out of a 2008 C6 Z51 vette and would like as close a setup to that as possible. I understand that the Camaro, with over 1000 lbs more curb weight and a higher center of gravity, will never be a corvette. I live in the Chicago area, so potholes are a problem. I used to race SCCA (IT) so I like a car that handles in all areas of the friction circle, not just accelleration.
to sum it up - I want a ride that is responsive but not punishing. I hope I am not asking for too much.
I searched the Hotchkis website but could not find a TVS kit for the Camaro. what am I missing?
thanks for your help
Old 09-28-2011, 02:20 PM   #14
camaro4mybday
"Camaro Joe"
@emsguy i owned a c5 vette my self so i know how you feel. if you are looking for a complete kit that will be as good if not better than your z06 check out the pedders pace car package that kit by far will please your needs and will handle the pot holes well and give you the race car feel too and be nice on the streets.
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Better Handling Tbanks Suspension / Brakes / Chassis 30 12-15-2010 11:50 AM
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 02:28 PM
