| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles
GM OBD2 Module Trouble Code Comprehensive List
P0010 "A" Camshaft Position Actuator Circuit (Bank 1) P0011 "A" Camshaft Position - Timing Over-Advanced (Bank 1) P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1) P0013 "B" Camshaft Position - Actuator Circuit (Bank 1) P0014 "B" Camshaft Position - Timing Over-Advanced (Bank 1) P0015 "B" Camshaft Position - Timing Over-Retarded (Bank 1) P0020 "A" Camshaft Position Actuator Circuit (Bank 2) P0021 "A" Camshaft Position - Timing Over-Advanced (Bank 2) P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2) P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) P0024 "B" Camshaft Position - Timing Over-Advanced (Bank 2) P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1) P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1) P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1) P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2) P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2) P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2) P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3) P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3) P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3) P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1) P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1) P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1) P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2) P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2) P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2) P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3) P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3) P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3) P0100 Mass or Volume Air Flow Circuit P0101 Mass or Volume Air Flow Circuit Range/Performance P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0104 Mass or Volume Air Flow Circuit Intermittent P0105 Manifold Absolute Pressure/Barometric Pressure Circuit P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0110 Intake Air Temperature Circuit P0111 Intake Air Temperature Circuit Range/Performance P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature Circuit P0116 Engine Coolant Temperature Circuit Range/Performance P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0119 Engine Coolant Temperature Circuit Intermittent P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control P0126 Insufficient Coolant Temperature for Stable Operation P0127 Intake Air Temperature Too High P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) P0130 O2 Sensor Circuit (Bank 1 Sensor 1) P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1) P0136 O2 Sensor Circuit (Bank 1 Sensor 2) P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2) P0142 O2 Sensor Circuit (Bank 1 Sensor 3) P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3) P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3) P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3) P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3) P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3) P0150 O2 Sensor Circuit (Bank 2 Sensor 1) P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1) P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1) P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1) P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1) P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1) P0156 O2 Sensor Circuit (Bank 2 Sensor 2) P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2) P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2) P0162 O2 Sensor Circuit (Bank 2 Sensor 3) P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3) P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3) P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3) P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3) P0168 Fuel Temperature Too High P0170 Fuel Trim (Bank 1) P0171 System too Lean (Bank 1) P0172 System too Rich (Bank 1) P0173 Fuel Trim (Bank 2) P0174 System too Lean (Bank 2) P0175 System too Rich (Bank 2) P0176 Fuel Composition Sensor Circuit P0177 Fuel Composition Sensor Circuit Range/Performance P0178 Fuel Composition Sensor Circuit Low Input P0179 Fuel Composition Sensor Circuit High Input P0180 Fuel Temperature Sensor "A" Circuit P0181 Fuel Temperature Sensor "A" Circuit Range/Performance P0182 Fuel Temperature Sensor "A" Circuit Low Input P0183 Fuel Temperature Sensor "A" Circuit High Input P0184 Fuel Temperature Sensor "A" Circuit Intermittent P0185 Fuel Temperature Sensor "B" Circuit P0186 Fuel Temperature Sensor "B" Circuit Range/Performance P0187 Fuel Temperature Sensor "B" Circuit Low Input P0188 Fuel Temperature Sensor "B" Circuit High Input P0189 Fuel Temperature Sensor "B" Circuit Intermittent P0190 Fuel Rail Pressure Sensor Circuit P0191 Fuel Rail Pressure Sensor Circuit Range/Performance P0192 Fuel Rail Pressure Sensor Circuit Low Input P0193 Fuel Rail Pressure Sensor Circuit High Input P0194 Fuel Rail Pressure Sensor Circuit Intermittent P0195 Engine Oil Temperature Sensor Circuit P0196 Engine Oil Temperature Sensor Circuit Range/Performance P0197 Engine Oil Temperature Sensor Circuit Low P0198 Engine Oil Temperature Sensor Circuit High P0199 Engine Oil Temperature Sensor Circuit Intermittent P0200 Injector Circuit P0201 Cylinder 1 - Injector Circuit P0202 Cylinder 2 - Injector Circuit P0203 Cylinder 3 - Injector Circuit P0204 Cylinder 4 - Injector Circuit P0205 Cylinder 5 - Injector Circuit P0206 Cylinder 6 - Injector Circuit P0207 Cylinder 7 - Injector Circuit P0208 Cylinder 8 - Injector Circuit P0209 Cylinder 9 - Injector Circuit P0210 Cylinder 10 - Injector Circuit P0211 Cylinder 11 - Injector Circuit P0212 Cylinder 12 - Injector Circuit P0213 Cold Start Injector 1 P0214 Cold Start Injector 2 P0215 Engine Shutoff Solenoid P0216 Injection Timing Control Circuit P0217 Engine Coolant Over Temperature Condition P0218 Transmission Fluid Over Temperature Condition P0219 Engine Over speed Condition P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent P0230 Fuel Pump Primary Circuit P0231 Fuel Pump Secondary Circuit Low P0232 Fuel Pump Secondary Circuit High P0233 Fuel Pump Secondary Circuit Intermittent P0234 Turbo/Super Charger Over boost Condition P0235 Turbo/Super Charger Boost Sensor "A" Circuit P0236 Turbo/Super Charger Boost Sensor "A" Circuit Range/Performance P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low P0238 Turbo/Super Charger Boost Sensor "A" Circuit High P0239 Turbo/Super Charger Boost Sensor "B" Circuit P0240 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance P0241 Turbo/Super Charger Boost Sensor "B" Circuit Low P0242 Turbo/Super Charger Boost Sensor "B" Circuit High P0243 Turbo/Super Charger Wastegate Solenoid "A" P0244 Turbo/Super Charger Wastegate Solenoid "A" Range/Performance P0245 Turbo/Super Charger Wastegate Solenoid "A" Low P0246 Turbo/Super Charger Wastegate Solenoid "A" High P0247 Turbo/Super Charger Wastegate Solenoid "B" P0248 Turbo/Super Charger Wastegate Solenoid "B" Range/Performance P0249 Turbo/Super Charger Wastegate Solenoid "B" Low P0250 Turbo/Super Charger Wastegate Solenoid "B" High P0251 Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector) P0252 Injection Pump Fuel Metering Control "A" Range/Performance P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) P0256 Injection Pump Fuel Metering Control "B" (Cam/Rotor/Injector) P0257 Injection Pump Fuel Metering Control "B" Range/Performance P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector) P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector) P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector) P0261 Cylinder 1 Injector Circuit Low P0262 Cylinder 1 Injector Circuit High P0263 Cylinder 1 Contribution/Balance P0264 Cylinder 2 Injector Circuit Low P0265 Cylinder 2 Injector Circuit High P0266 Cylinder 2 Contribution/Balance P0267 Cylinder 3 Injector Circuit Low P0268 Cylinder 3 Injector Circuit High P0269 Cylinder 3 Contribution/Balance P0270 Cylinder 4 Injector Circuit Low P0271 Cylinder 4 Injector Circuit High P0272 Cylinder 4 Contribution/Balance P0273 Cylinder 5 Injector Circuit Low P0274 Cylinder 5 Injector Circuit High P0275 Cylinder 5 Contribution/Balance P0276 Cylinder 6 Injector Circuit Low P0277 Cylinder 6 Injector Circuit High P0278 Cylinder 6 Contribution/Balance P0279 Cylinder 7 Injector Circuit Low P0280 Cylinder 7 Injector Circuit High P0281 Cylinder 7 Contribution/Balance P0282 Cylinder 8 Injector Circuit Low P0283 Cylinder 8 Injector Circuit High P0284 Cylinder 8 Contribution/Balance P0285 Cylinder 9 Injector Circuit Low P0286 Cylinder 9 Injector Circuit High P0287 Cylinder 9 Contribution/Balance P0288 Cylinder 10 Injector Circuit Low P0289 Cylinder 10 Injector Circuit High P0290 Cylinder 10 Contribution/Balance P0291 Cylinder 11 Injector Circuit Low P0292 Cylinder 11 Injector Circuit High P0293 Cylinder 11 Contribution/Balance P0294 Cylinder 12 Injector Circuit Low P0295 Cylinder 12 Injector Circuit High P0296 Cylinder 12 Contribution/Balance P0298 Engine Oil Over Temperature P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0310 Cylinder 10 Misfire Detected P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0313 Misfire Detected With Low Fuel P0314 Single Cylinder Misfire (cylinder not specified) P0320 Ignition/Distributor Engine Speed Input Circuit P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance P0322 Ignition/Distributor Engine Speed Input Circuit No Signal P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor) P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor) P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor) P0330 Knock Sensor 2 Circuit (Bank 2) P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2) P0332 Knock Sensor 2 Circuit Low Input (Bank 2) P0333 Knock Sensor 2 Circuit High Input (Bank 2) P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2) P0335 Crankshaft Position Sensor "A" Circuit P0336 Crankshaft Position Sensor "A" Circuit Range/Performance P0337 Crankshaft Position Sensor "A" Circuit Low Input P0338 Crankshaft Position Sensor "A" Circuit High Input P0339 Crankshaft Position Sensor "A" Circuit Intermittent P0340 Camshaft Position Sensor Circuit P0341 Camshaft Position Sensor Circuit Range/Performance P0342 Camshaft Position Sensor Circuit Low Input P0343 Camshaft Position Sensor Circuit High Input P0344 Camshaft Position Sensor Circuit Intermittent P0350 Ignition Coil Primary/Secondary Circuit P0351 Ignition Coil "A" Primary/Secondary Circuit P0352 Ignition Coil "B" Primary/Secondary Circuit P0353 Ignition Coil "C" Primary/Secondary Circuit P0354 Ignition Coil "D" Primary/Secondary Circuit P0355 Ignition Coil "E" Primary/Secondary Circuit P0356 Ignition Coil "F" Primary/Secondary Circuit P0357 Ignition Coil "G" Primary/Secondary Circuit P0358 Ignition Coil "H" Primary/Secondary Circuit P0359 Ignition Coil "I" Primary/Secondary Circuit P0360 Ignition Coil "J" Primary/Secondary Circuit P0361 Ignition Coil "K" Primary/Secondary Circuit P0362 Ignition Coil "L" Primary/Secondary Circuit P0370 Timing Reference High Resolution Signal "A" P0371 Timing Reference High Resolution Signal "A" Too Many Pulses P0372 Timing Reference High Resolution Signal "A" Too Few Pulses P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses P0374 Timing Reference High Resolution Signal "A" No Pulses P0375 Timing Reference High Resolution Signal "B" P0376 Timing Reference High Resolution Signal "B" Too Many Pulses P0377 Timing Reference High Resolution Signal "B" Too Few Pulses P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses P0379 Timing Reference High Resolution Signal "B" No Pulses P0380 Glow Plug /Heater Circuit "A" P0381 Glow Plug /Heater Indicator Circuit P0382 Glow Plug /Heater Circuit "B" P0385 Crankshaft Position Sensor "B" Circuit P0386 Crankshaft Position Sensor "B" Circuit Range/Performance P0387 Crankshaft Position Sensor "B" Circuit Low Input P0388 Crankshaft Position Sensor "B" Circuit High Input P0389 Crankshaft Position Sensor "B" Circuit Intermittent P0400 Exhaust Gas Recirculation Flow P0401 Exhaust Gas Recirculation Flow Insufficient Detected P0402 Exhaust Gas Recirculation Flow Excessive Detected P0403 Exhaust Gas Recirculation Circuit P0404 EGR Open Valve Pintle Error P0404 Exhaust Gas Recirculation Circuit Range/Performance P0405 EGR Sensor Signal Low P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low P0406 Exhaust Gas Recirculation Sensor "A" Circuit High P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low P0408 Exhaust Gas Recirculation Sensor "B" Circuit High P0410 Secondary Air Injection System P0411 Secondary Air Injection System Incorrect Flow Detected P0412 Secondary Air Injection System Switching Valve "A" Circuit P0413 Secondary Air Injection System Switching Valve "A" Circuit Open P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted P0415 Secondary Air Injection System Switching Valve "B" Circuit P0416 Secondary Air Injection System Switching Valve "B" Circuit Open P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted P0418 Secondary Air Injection System Relay "A" Circuit P0419 Secondary Air Injection System Relay "B" Circuit P0420 Catalyst System Efficiency Below Threshold (Bank 1) P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1) P0422 Main Catalyst Efficiency Below Threshold (Bank 1) P0423 Heated Catalyst Efficiency Below Threshold (Bank 1) P0424 Heated Catalyst Temperature Below Threshold (Bank 1) P0425 Catalyst Temperature Sensor (Bank 1) P0426 Catalyst Temperature Sensor Range/Performance (Bank 1) P0427 Catalyst Temperature Sensor Low Input (Bank 1) P0428 Catalyst Temperature Sensor High Input (Bank 1) P0429 Catalyst Heater Control Circuit (Bank 1) P0430 Catalyst System Efficiency Below Threshold (Bank 2) P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2) P0432 Main Catalyst Efficiency Below Threshold (Bank 2) P0433 Heated Catalyst Efficiency Below Threshold (Bank 2) P0434 Heated Catalyst Temperature Below Threshold (Bank 2) P0435 Catalyst Temperature Sensor (Bank 2) P0436 Catalyst Temperature Sensor Range/Performance (Bank 2) P0437 Catalyst Temperature Sensor Low Input (Bank 2) P0438 Catalyst Temperature Sensor High Input (Bank 2) P0439 Catalyst Heater Control Circuit (Bank 2) P0440 Evaporative Emission Control System P0441 Evaporative Emission Control System Incorrect Purge Flow P0442 Evaporative Emission Control System Leak Detected (small leak) P0443 Evaporative Emission Control System Purge Control Valve Circuit P0444 Evaporative Emission Control System Purge Control Valve Circuit Open P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446 Evaporative Emission Control System Vent Control Circuit P0446 Evaporative Emission Control System Vent Control Circuit P0447 Evaporative Emission Control System Vent Control Circuit Open P0447 Evaporative Emission Control System Vent Control Circuit Open P0448 Evaporative Emission Control System Vent Control Circuit Shorted P0448 Evaporative Emission Control System Vent Control Circuit Shorted P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit P0450 Evaporative Emission Control System Pressure Sensor P0451 Evaporative Emission Control System Pressure Sensor Range/Performance P0452 Evaporative Emission Control System Pressure Sensor Low Input P0453 Evaporative Emission Control System Pressure Sensor High Input P0454 Evaporative Emission Control System Pressure Sensor Intermittent P0455 Evaporative Emission Control System Leak Detected (gross leak) P0456 Evaporative Emission Control System Leak Detected (very small leak) P0460 Fuel Level Sensor Circuit P0461 Fuel Level Sensor Circuit Range/Performance P0462 Fuel Level Sensor Circuit Low Input P0463 Fuel Level Sensor Circuit High Input P0464 Fuel Level Sensor Circuit Intermittent P0465 Purge Flow Sensor Circuit P0466 Purge Flow Sensor Circuit Range/Performance P0467 Purge Flow Sensor Circuit Low Input P0468 Purge Flow Sensor Circuit High Input P0469 Purge Flow Sensor Circuit Intermittent P0470 Exhaust Pressure Sensor P0471 Exhaust Pressure Sensor Range/Performance P0472 Exhaust Pressure Sensor Low P0473 Exhaust Pressure Sensor High P0474 Exhaust Pressure Sensor Intermittent P0475 Exhaust Pressure Control Valve P0476 Exhaust Pressure Control Valve Range/Performance P0477 Exhaust Pressure Control Valve Low P0478 Exhaust Pressure Control Valve High P0479 Exhaust Pressure Control Valve Intermittent P0480 Cooling Fan 1 Control Circuit P0481 Cooling Fan 2 Control Circuit P0482 Cooling Fan 3 Control Circuit P0483 Cooling Fan Rationality Check P0484 Cooling Fan Circuit Over Current P0485 Cooling Fan Power/Ground Circuit P0491 Secondary Air Injection System (bank 1) P0492 Secondary Air Injection System (bank 2) P0500 Vehicle Speed Sensor P0501 Vehicle Speed Sensor Range/Performance P0502 Vehicle Speed Sensor Circuit Low Input P0503 Vehicle Speed Sensor Intermittent / Erratic / High P0505 Idle Control System P0506 Idle Control System RPM Lower Than Expected P0507 Idle Control System RPM Higher Than Expected P0510 Closed Throttle Position Switch P0512 Starter Request Circuit P0520 Engine Oil Pressure Sensor/Switch Circuit P0521 Engine Oil Pressure Sensor/Switch Range/Performance P0522 Engine Oil Pressure Sensor/Switch Low Voltage P0523 Engine Oil Pressure Sensor/Switch High Voltage P0524 Engine Oil Pressure Too Low P0530 A/C Refrigerant Pressure Sensor Circuit P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 A/C Refrigerant Pressure Sensor Circuit Low Input P0533 A/C Refrigerant Pressure Sensor Circuit High Input P0534 A/C Refrigerant Charge Loss P0550 Power Steering Pressure Sensor Circuit P0551 Power Steering Pressure Sensor Circuit Range/Performance P0552 Power Steering Pressure Sensor Circuit Low Input P0553 Power Steering Pressure Sensor Circuit High Input P0554 Power Steering Pressure Sensor Circuit Intermittent P0560 System Voltage P0561 System Voltage Unstable P0562 System Voltage Low P0563 System Voltage High P0565 Cruise Control On Signal P0566 Cruise Control Off Signal P0567 Cruise Control Resume Signal P0568 Cruise Control Set Signal P0569 Cruise Control Coast Signal P0570 Cruise Control Accel Signal P0571 Cruise Control / Brake Switch "A" Circuit P0572 Cruise Control / Brake Switch "A" Circuit Low P0573 Cruise Control / Brake Switch "A" Circuit High P0574 Cruise Control System - Vehicle Speed Too High P0575 Reserved for Cruise Codes P0576 Reserved for Cruise Codes P0577 Reserved for Cruise Codes P0578 Reserved for Cruise Codes P0579 Reserved for Cruise Codes P0580 Reserved for Cruise Codes P0600 Serial Communication Link P0601 Internal Control Module Memory Check Sum Error P0602 Control Module Programming Error P0603 Internal Control Module Keep Alive Memory (KAM) Error P0604 Internal Control Module Random Access Memory (RAM) Error P0605 Internal Control Module Read Only Memory (ROM) Error P0606 ECM/PCM Processor P0608 Control Module VSS Output "A" P0609 Control Module VSS Output "B" P0615 Starter Relay Circuit P0616 Starter Relay Circuit Low P0617 Starter Relay Circuit High P0620 Generator Control Circuit P0621 Generator "L" Terminal Control Circuit P0622 Generator "F" Terminal Control Circuit P0630 VIN Not Programmed or Mismatch - ECM/PCM P0631 VIN Not Programmed or Mismatch - TCM P0645 A/C Clutch Relay Circuit P0650 Malfunction Indicator Lamp (MIL) Control Circuit P0654 Engine RPM Output Circuit P0655 Engine Hot Lamp Output Control Circuit P0656 Fuel Level Output Circuit P0700 Transmission Control System (will show up as PCM code, but is all TCM Related) P0701 Transmission Control System Range/Performance P0702 Transmission Control System Electrical P0703 Torque Converter/Brake Switch "B" Circuit P0704 Clutch Switch Input Circuit P0705 Transmission Range Sensor Circuit (PRNDL Input) P0706 Transmission Range Sensor Circuit Range/Performance P0707 Transmission Range Sensor Circuit Low Input P0708 Transmission Range Sensor Circuit High Input P0709 Transmission Range Sensor Circuit Intermittent P0710 Transmission Fluid Temperature Sensor Circuit P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance P0712 Transmission Fluid Temperature Sensor Circuit Low Input P0713 Transmission Fluid Temperature Sensor Circuit High Input P0714 Transmission Fluid Temperature Sensor Circuit Intermittent P0715 Input/Turbine Speed Sensor Circuit P0716 Input/Turbine Speed Sensor Circuit Range/Performance P0717 Input/Turbine Speed Sensor Circuit No Signal P0718 Input/Turbine Speed Sensor Circuit Intermittent P0719 Torque Converter/Brake Switch "B" Circuit Low P0720 Output Speed Sensor Circuit P0721 Output Speed Sensor Circuit Range/Performance P0722 Output Speed Sensor Circuit No Signal P0723 Output Speed Sensor Circuit Intermittent P0724 Torque Converter/Brake Switch "B" Circuit High P0725 Engine Speed Input Circuit P0726 Engine Speed Input Circuit Range/Performance P0727 Engine Speed Input Circuit No Signal P0728 Engine Speed Input Circuit Intermittent P0730 Incorrect Gear Ratio P0731 Gear 1 Incorrect Ratio P0732 Gear 2 Incorrect Ratio P0733 Gear 3 Incorrect Ratio P0734 Gear 4 Incorrect Ratio P0735 Gear 5 Incorrect Ratio P0736 Reverse Incorrect Ratio P0737 TCM Engine Speed Output Circuit P0738 TCM Engine Speed Output Circuit Low P0739 TCM Engine Speed Output Circuit High P0740 Torque Converter Clutch Circuit P0741 Torque Converter Clutch Circuit Performance or Stuck Off P0742 Torque Converter Clutch Circuit Stuck On P0743 Torque Converter Clutch Circuit Electrical P0744 Torque Converter Clutch Circuit Intermittent P0745 Pressure Control Solenoid "A" P0746 Pressure Control Solenoid "A" Performance or Stuck Off P0747 Pressure Control Solenoid "A" Stuck On P0748 Pressure Control Solenoid "A" Electrical P0749 Pressure Control Solenoid "A" Intermittent P0750 Shift Solenoid "A" P0751 Shift Solenoid "A" Performance or Stuck Off P0752 Shift Solenoid "A" Stuck On P0753 Shift Solenoid "A" Electrical P0754 Shift Solenoid "A" Intermittent P0755 Shift Solenoid "B" P0756 Shift Solenoid "B" Performance or Stuck Off P0757 Shift Solenoid "B" Stuck On P0758 Shift Solenoid "B" Electrical P0759 Shift Solenoid "B" Intermittent P0760 Shift Solenoid "C" P0761 Shift Solenoid "C" Performance or Stuck Off P0762 Shift Solenoid "C" Stuck On P0763 Shift Solenoid "C" Electrical P0764 Shift Solenoid "C" Intermittent P0765 Shift Solenoid "D" P0766 Shift Solenoid "D" Performance or Stuck Off P0767 Shift Solenoid "D" Stuck On P0768 Shift Solenoid "D" Electrical P0769 Shift Solenoid "D" Intermittent P0770 Shift Solenoid "E" P0771 Shift Solenoid "E" Performance or Stuck Off P0772 Shift Solenoid "E" Stuck On P0773 Shift Solenoid "E" Electrical P0774 Shift Solenoid "E" Intermittent P0775 Pressure Control Solenoid "B" P0776 Pressure Control Solenoid "B" Performance or Stuck Off P0777 Pressure Control Solenoid "B" Stuck On P0778 Pressure Control Solenoid "B" Electrical P0779 Pressure Control Solenoid "B" Intermittent P0780 Shift P0781 1-2 Shift P0782 2-3 Shift P0783 3-4 Shift P0784 4-5 Shift P0785 Shift/Timing Solenoid P0786 Shift/Timing Solenoid Range/Performance P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid High P0789 Shift/Timing Solenoid Intermittent P0790 Normal/Performance Switch Circuit P0791 Intermediate Shaft Speed Sensor Circuit P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance P0793 Intermediate Shaft Speed Sensor Circuit No Signal P0794 Intermediate Shaft Speed Sensor Circuit Intermittent P0795 Pressure Control Solenoid "C" P0796 Pressure Control Solenoid "C" Performance or Stuck Off P0797 Pressure Control Solenoid "C" Stuck On P0798 Pressure Control Solenoid "C" Electrical P0799 Pressure Control Solenoid "C" Intermittent P0801 Reverse Inhibit Control Circuit P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit P0805 Clutch Position Sensor Circuit P0806 Clutch Position Sensor Circuit Range/Performance P0807 Clutch Position Sensor Circuit Low P0808 Clutch Position Sensor Circuit High P0809 Clutch Position Sensor Circuit Intermittent P0810 Clutch Position Control Error P0811 Excessive Clutch Slippage P0812 Reverse Input Circuit P0813 Reverse Output Circuit P0814 Transmission Range Display Circuit P0815 Upshift Switch Circuit P0816 Downshift Switch Circuit P0817 Starter Disable Circuit P0820 Gear Lever X-Y Position Sensor Circuit P0821 Gear Lever X Position Circuit P0822 Gear Lever Y Position Circuit P0823 Gear Lever X Position Circuit Intermittent P0824 Gear Lever Y Position Circuit Intermittent P0825 Gear Lever Push-Pull Switch (Shift Anticipate) P0830 Clutch Pedal Switch "A" Circuit P0831 Clutch Pedal Switch "A" Circuit Low P0832 Clutch Pedal Switch "A" Circuit High P0833 Clutch Pedal Switch "B" Circuit P0834 Clutch Pedal Switch "B" Circuit Low P0835 Clutch Pedal Switch "B" Circuit High P0840 Trans Pressure Switch Solenoid C Circuit P0841 Trans Pressure Switch Solenoid C Circuit Stuck Open P0842 Trans Pressure Switch Solenoid C Circuit Stuck Closed P0843 Trans Pressure Switch Solenoid C Circuit High P0845 Trans Pressure Switch Solenoid D Circuit P0846 Trans Pressure Switch Solenoid D Circuit Stuck Open P0847 Trans Pressure Switch Solenoid D Circuit Stuck Closed P0848 Trans Pressure Switch Solenoid D Circuit High P1101 Induction Air Measurement - Cross-check Out of Range P1105 Secondary Vacuum Sensor Circuit P1106 MAP Sensor Signal Intermittent High P1107 MAP Sensor Signal Intermittent Low P1108 MAP to BARO Correlation P1109 Secondary Port Throttle System P1110 Engine High Intake Air Temperature Condition P1111 Intake Air Temperature Circuit Intermittent High P1112 Intake Air Temperature Circuit Intermittent Low P1114 Engine Coolant Temperature - Circuit Low Input Intermittent P1115 Engine Coolant Temperature - Circuit High Input intermittent P1116 Engine Coolant Temperature Signal Unstable or Intermittent P1117 Engine Coolant Temperature Signal Out-Of-Range Low P1118 Engine Coolant Temperature Signal Out-Of-Range High P1119 Engine Coolant Temperature Signal Out-Of-Range with Transmission Temperature P1120 Throttle Position Sensor "A" Circuit P1121 Throttle Position Circuit Signal Intermittent High P1122 Throttle Position Circuit Signal Intermittent Low P1125 Multiple Throttle/Pedal Position Sensor P1127 Open Loop CO Adjust Circuit P1130 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 1) P1131 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 2) P1132 Oxygen Sensor Low Signal Variance (Bank 2 - Sensor 1) P1133 Oxygen Sensor System - Too Few O2S R/L and L/R Switches . (Bank 1 - Sensor 1) P1134 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 1) P1135 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 1) P1136 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 1) P1137 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 2) P1138 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 2) P1139 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 2) P1140 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 2) P1141 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 2) P1142 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 2) P1143 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 3) P1144 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 3) P1145 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 3) P1153 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 1) P1154 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 2 - Sensor 1) P1155 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 2 - Sensor 1) P1156 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 2 - Sensor 1) P1157 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 2) P1158 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 2) P1159 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 2) P1163 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 3) P1164 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 3) P1165 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 3) P1166 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 1 - Sensor 1) P1167 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 1 - Sensor 1) P1168 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 2 - Sensor 1) P1169 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 2 - Sensor 1) P1170 Bank to Bank Fuel Trim Offset P1171 Primary Fuel Pump Insufficient / No Fuel Flow P1172 Secondary Fuel Pump Insufficient / No Fuel Flow P1173 Limitation of Injection Quantity P1180 Engine High Fuel Temperature Condition P1190 Engine Vacuum Leak P1191 Intake Air Duct Air Leak P1195 Engine Low Oil Pressure Condition P1200 Injector Circuit P1201 Secondary Mass Air Flow Range/Performance P1202 Secondary Mass or Volume Air Flow Circuit Low Input P1203 Secondary Mass or Volume Air Flow Circuit High Input P1211 Mass Air Flow Circuit Intermittent High P1212 Mass Air Flow Circuit Intermittent Low P1214 Injection Pump Timing Offset Error P1215 GFD Indication P1216 Fuel Solenoid Response Time Too Short P1217 Fuel Solenoid Response Time Too Long P1218 Injection Pump Calibration Resistor Error P1219 Throttle Position Sensor Reference Voltage Error P1220 Throttle Position Sensor "B" Circuit P1221 Throttle Position Sensor "A/B" Range/Performance P1222 Injector Circuit Intermittent - Cylinder 1 P1225 Injector Circuit Intermittent - Cylinder 2 P1228 Injector Circuit Intermittent - Cylinder 3 P1231 Injector Circuit Intermittent - Cylinder 4 P1234 Injector Circuit Intermittent - Cylinder 5 P1237 Injector Circuit Intermittent - Cylinder 6 P1240 Injector Circuit Intermittent - Cylinder 7 P1243 Injector Circuit Intermittent - Cylinder 8 P1245 Intake Plenum Switchover Valve Circuit P1246 Intake Resonance Switchover Valve Circuit P1257 Supercharger - Overboost P1258 Engine Coolant Over - Temperature Protection P1260 Fuel Pump Speed Control Circuit P1270 Accelerator Pedal Position Sensor A/D Converter Error P1271 Accelerator Pedal Position Sensors 1 & 2 Correlation Error P1272 Accelerator Pedal Position Sensors 2 & 3 Correlation Error P1273 Accelerator Pedal Position Sensors 1 & 3 Correlation Error P1274 Injectors Wired Incorrectly P1275 Accelerator Pedal Position Sensor 1 Circuit P1276 Accelerator Pedal Position Sensor 1 Circuit Performance P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage P1279 Accelerator Pedal Position Sensor 1 Circuit Intermittent P1280 Accelerator Pedal Position Sensor 2 Circuit P1281 Accelerator Pedal Position Sensor 2 Circuit Performance P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage P1284 Accelerator Pedal Position Sensor 2 Circuit Intermittent P1285 Accelerator Pedal Position Sensor 3 Circuit P1286 Accelerator Pedal Position Sensor 3 Circuit Performance P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage P1289 Accelerator Pedal Position Sensor 3 Circuit Intermittent P1310 Ignition Coil Primary/Secondary Current Sense System P1311 Ignition Coil "A" Primary/Secondary Circuit P1312 Ignition Coil "B" Primary/Secondary Circuit P1313 Ignition Coil "C" Primary/Secondary Circuit P1314 Ignition Coil "D" Primary/Secondary Circuit P1315 Ignition Coil "E" Primary/Secondary Circuit P1316 Ignition Coil "F" Primary/Secondary Circuit P1317 Ignition Coil "G" Primary/Secondary Circuit P1318 Ignition Coil "H" Primary/Secondary Circuit P1320 Distributor Signal Interrupt P1321 DIS Fault Line P1322 DIS EST (Extra or Missing) P1323 Loss of High Resolution RPM Information P1324 Crank RPM Too Low P1326 Combustion Quality Circuit P1336 Crankshaft Position System Variation Not Learned P1340 Ignition System Cylinder Identifier P1345 Crankshaft/Camshaft Correlation Error P1350 Bypass Line Monitor P1351 EST Output High or Pulses Detected when Grounded - Cylinder 1 P1352 EST Output High or Pulses Detected when Grounded - Cylinder 2 P1353 EST Output High or Pulses Detected when Grounded - Cylinder 3 P1354 EST Output High or Pulses Detected when Grounded - Cylinder 4 P1355 EST Output High or Pulses Detected when Grounded - Cylinder 5 P1356 EST Output High or Pulses Detected when Grounded - Cylinder 6 P1357 EST Output High or Pulses Detected when Grounded - Cylinder 7 P1358 EST Output High or Pulses Detected when Grounded - Cylinder 8 P1359 Ignition Control Circuit Group A (cylinders N, N, N, N ) P1360 Ignition Control Circuit Group B (cylinders N, N, N, N ) P1361 EST Not Toggling After Enabled - Cylinder 1 P1362 EST Not Toggling After Enabled - Cylinder 2 P1363 EST Not Toggling After Enabled - Cylinder 3 P1364 EST Not Toggling After Enabled - Cylinder 4 P1365 EST Not Toggling After Enabled - Cylinder 5 P1366 EST Not Toggling After Enabled - Cylinder 6 P1367 EST Not Toggling After Enabled - Cylinder 7 P1368 EST Not Toggling After Enabled - Cylinder 8 P1370 Too Many Low Resolution Pulses P1371 Too Few Low Resolution Pulses P1372 Crankshaft Position Sensor Circuits Performance P1374 Crank to Low Resolution Correlation P1375 No Crank Sensor A or B P1376 Reference Low Voltage Out of Range P1377 CAM To Reference Correlation P1380 ABS Preventing Rough Road/Misfire Diagnostic P1381 Serial Communication Preventing Rough Road/Misfire Diagnostic P1382 ABS Control Module Performance (Used for 1997 Model Year only) P1390 Wheel Speed Sensor "A" / G-Sensor Circuit P1391 Wheel Speed Sensor "A" / G-Sensor Circuit Range/Performance P1392 Wheel Speed Sensor "A" / G-Sensor Circuit Low Input P1393 Wheel Speed Sensor "A" / G-Sensor Circuit High Input P1394 Wheel Speed Sensor "A" / G-Sensor Circuit Intermittent P1395 Wheel Speed Sensor "B" / G-Sensor Circuit P1396 Wheel Speed Sensor "B" / G-Sensor Circuit Range/Performance P1397 Wheel Speed Sensor "B" / G-Sensor Circuit Low Input P1398 Wheel Speed Sensor "B" / G-Sensor Circuit High Input P1399 Wheel Speed Sensor "B" / G-Sensor Circuit Intermittent P1403 Exhaust Gas Recirculation Solenoid Low P1404 EGR Closed Valve Pintle Error P1404 Exhaust Gas Recirculation System - Closed Valve Pintle Error P1405 Exhaust Gas Recirculation Solenoid High P1406 EGR Pintle Position Error P1406 Exhaust Gas Recirculation System Pintle Position Error P1407 P1408 Exhaust Gas Recirculation Vacuum System P1409 Exhaust Gas Recirculation Vacuum System Leak/Low Supply P1410 Exhaust Gas Recirculation Vacuum System Restriction P1415 Secondary Air Injection - Bank 1 P1416 Secondary Air Injection - Bank 2 P1420 Intake Air Low Pressure Switch Circuit Low Voltage P1421 Intake Air Low Pressure Switch Circuit High Voltage P1422 Intake Air High Pressure Switch Circuit Low Voltage P1423 Intake Air High Pressure Switch Circuit High Voltage P1431 Fuel Level Sensor Circuit Range/Performance (Secondary Tank) P1432 Fuel Level Sensor Circuit Low Input (Secondary Tank) P1433 Fuel Level Sensor Circuit High Input (Secondary Tank) P1441 Evaporative Emission Control System Continuous Open Purge Flow P1442 Purge Solenoid Diagnostic Vacuum Switch P1443 Evaporative Emission Control System Purge Control Valve 2 Circuit P1445 Fuel Heated Catalyst System Bank 1 P1450 Catalyst Heater Diagnostic P1451 Catalyst Heater Diagnostic P1452 Catalyst Heater Diagnostic P1453 Catalyst Heater Diagnostic P1454 Catalyst Heater Diagnostic P1455 Catalyst Heater Diagnostic P1456 Catalyst Heater Diagnostic P1457 Catalyst Heater Diagnostic P1458 Catalyst Heater Diagnostic P1459 Catalyst Heater Diagnostic P1483 Engine Cooling System Performance P1501 Vehicle Speed Sensor Intermittent P1504 Aux Vehicle Speed Output Circuit P1505 Starter Relay Circuit P1506 Starter Relay Circuit Low P1507 Starter Relay Circuit High P1508 Idle Control System Low/Closed P1509 Idle Control System High/Open P1510 Throttle Control System - In Limitation P1511 Throttle Control System - Backup System Performance P1512 Throttle Control System - Minimum Throttle Position P1513 EBTCM to PCM Drag Reduction Request Input Circuit P1514 Throttle Actuator Control (TAC) System MAF Correlation Error P1515 Command vs. Actual Throttle Position Correlation (PCM) Error P1516 Command vs. Actual Throttle Position Correlation (TAC Module) Error P1517 Throttle Actuator Control (TAC) Module Processor P1518 PCM to TAC Module Serial Data Circuit P1519 Throttle Actuator Control (TAC) Module P1520 Park/Neutral Discrete Error P1521 P/N to D/R at High Throttle Angle P1522 P/N to D/R at High RPM P1523 Throttle Actuator Control Return Performance P1524 Throttle Position Sensor Out of Adjustment P1525 Throttle Body Service Required P1526 TPS Learn Not Done After Reprogramming P1527 Transaxle Range/Pressure Switch Comparison P1528 Governor P1529 Heated Windshield Request P1530 Throttle Control System - Amplifier Adjustment P1531 A/C Temperature Sensor Circuit P1532 A/C Low Side Temperature Sensor Low Input P1533 A/C Low Side Temperature Sensor High Input P1534 A/C High Side Temperature Sensor Low Input P1535 A/C High Side Temperature Sensor High Input P1536 A/C Coolant Over Temperature P1537 Very Low Refrigerant Pressure P1538 A/C Request Shorted High P1539 High Side Pressure Switch or A/C Relay Shorted P1540 A/C High Pressure Condition P1541 A/C High Side Over Temperature P1542 A/C High Discharge Temperature/Pressure P1543 Low Refrigerant Condition P1544 Very Low Refrigerant Condition P1545 A/C High Pressure Switch or A/C Clutch Relay Circuit P1546 A/C Clutch Status Circuit Open P1547 A/C System Performance Degraded P1548 A/C "Mode" Circuit Low P1549 A/C "Mode" Circuit High P1554 Stepper Motor Cruise P1555 Electronic Variable Orifice Output P1558 Cruise Control - Servo Indicates Low P1559 Cruise Control - Power Management Mode P1560 Cruise Control - Transmission not in Drive P1561 Cruise Control - Vent Solenoid Failure P1562 Cruise Control - Vacuum Solenoid Failure P1563 Cruise Control - Vehicle Speed and Set Speed Difference Too High P1564 Cruise Control - Vehicle Acceleration Too High P1565 Cruise Control - Servo Position Sensor Failure P1566 Cruise Control - Engine RPM Too High P1567 Cruise Control - Auto Brake Control Disengage P1568 Cruise Control Servo Stroke Greater than Commanded in Cruise P1569 Cruise Control Servo Stroke High While not in Cruise Control P1570 Traction Control Active While in Cruise P1571 Traction Control PWM Link P1572 Traction Control Active Too Long P1573 Loss of ABS Serial Data P1574 Brake Pedal Position Switch P1575 Additional Brake Input Diagnostic P1576 Shorted Brake Booster Vacuum Sensor Circuit P1577 Open Brake Booster Vacuum Sensor Circuit P1578 Brake Booster Vacuum Too Low P1579 High Throttle Angle on P/N to D/R Transition P1580 Cruise Control Move Circuit – Low P1581 Cruise Control Move Circuit - High P1582 Cruise Control Direction Circuit - Low P1583 Cruise Control Direction Circuit - High P1584 Cruise Control Disabled P1585 Cruise Inhibit Control Circuit P1586 Brake Switch Circuit Number 3 P1599 Engine Stall Detected P1601 Serial Communication with Device 1 (PCM, Powertrain Control Module) P1602 Serial Communication with Device 2 (ABS, Antilock Brake System) P1603 Serial Communication with Device 3 (SIR, Supplemental Inflatable Restraint) P1604 Serial Communication with Device 4 (IPC, Instrument Panel Cluster) P1605 Serial Communication with Device 5 (HVAC, Heating Ventilation and Air Conditioning) P1606 Serial Communication with Device 6 (E&C BUSS, Entertainment and Comfort) P1607 Serial Communication with Device 7 (MRD, Magnetic Rotation Device) P1608 Serial Communication with Device 8 (CCM, Central Control Module) P1609 Serial Communication with Device 9 (TCS, Traction Control System) P1610 Serial Communication with Device 10 (PZM, Platform Zone Module) P1611 Serial Communication with Device 11 (CVRTD, Continuously Variable Real Time Dampening) P1612 Serial Communication with Device 12 (IPM, Instrument Panel Module) P1613 Serial Communication with Device 13 (DIM, Driver Information Module) P1614 Serial Communication with Device 14 (RIM, Radio Interface Module) P1615 Serial Communication with Device 15 (VTD, Vehicle Theft Deterrent) P1617 Engine Oil Level Switch Circuit P1618 Serial Peripheral Interface (SPI) PCM Internal Communication Error P1619 Oil Change - Input P1620 Low Coolant Circuit P1621 Total EEPROM Failure P1622 Cylinder Select Error (OBD1 was code 41) P1623 Transmission Temp Pull-up Resistor P1624 Customer Snapshot Requested P1625 PCM System Reset P1626 Anti-Theft Failure P1627 A/D Failure P1628 Engine Coolant Temperature Pull-Up Resistor Failed P1629 Anti-Theft Device - Cranking Signal P1630 PCM in Theft Learn Mode P1631 Anti-Theft Device - PCM/IPC Password Error P1632 Anti-Theft Device - Fuel Disabled P1633 PCM Ignition Input "A" P1634 PCM Ignition Input "B" P1635 5 Volt Reference "A" Low P1636 PCM Stack Overrun P1637 Generator "L" Terminal Control Circuit P1638 Generator "F" Terminal Control Circuit P1639 5 Volt Reference "B" Low P1640 Add on heater, Circuit (Circuit 1) P1641 Add on heater, Circuit (Circuit 2) P1642 QDM / ODM "A" - Output 2 P1643 Wait to Start Lamp Control Circuit P1644 QDM / ODM "A" - Output 4 P1645 QDM / ODM "A" - Output 5 P1646 5Volt Reference "C" Circuit P1647 QDM / ODM "A" - Output 7 P1648 Anti-Theft Device - Wrong Security Code P1649 Anti-Theft Device - No Key/Security Code Programmed P1650 QDM / ODM "B" P1651 QDM / ODM "B" - Output 1 P1652 Chassis Pitch Status Control Circuit P1653 Engine Oil Level "Low" Lamp Control Circuit P1654 Service Throttle Soon Lamp Control Circuit P1656 Second Gear Start Lamp Control Circuit P1657 QDM / ODM "B" - Output 7 P1659 Engine Over speed Lamp Control Circuit P1660 High Idle Lamp Control Circuit P1661 Check Gages Lamp Control Circuit P1662 Cruise Control Lamp Control Circuit P1663 Engine Oil Life/Change Lamp Control Circuit P1664 Service Vehicle Soon Lamp Control Circuit P1665 Engine Oil Pressure Gage Output Circuit P1666 Engine Shutdown Alarm Control Circuit P1667 QDM / ODM "C" - Output 7 P1670 QDM / ODM "D" P1671 QDM / ODM "D" - Output 1 P1672 QDM / ODM "D" - Output 2 P1673 QDM / ODM "D" - Output 3 P1674 QDM / ODM "D" - Output 4 P1675 QDM / ODM "D" - Output 5 P1676 QDM / ODM "D" - Output 6 P1677 QDM / ODM "D" - Output 7 P1680 Control Module Performance - APP system P1681 Control Module Performance - TP system P1682 Control Module Performance - Ignition Circuit P1689 Delivered Torque Output Circuit P1690 ECM Loop Overrun P1691 Coolant Gage Circuit - Low P1692 Coolant Gage Circuit - High P1693 Tachometer Circuit - Low P1694 Tachometer Circuit - High P1695 Remote Keyless Entry Circuit - Low P1696 Remote Keyless Entry Circuit - High P1697 PZM Disabled Fuel P1698 Class II Down Disabled Fuel P1699 In Fail Enable Mode P1701 Pressure Switch "C" Circuit P1702 Pressure Switch "C" Stuck Open / Performance P1703 Pressure Switch "C" Circuit Low / Stuck Closed P1704 Pressure Switch "C" Circuit High P1705 Pressure Switch "D" Circuit P1706 Pressure Switch "D" Stuck Open / Performance P1707 Pressure Switch "D" Circuit Low / Stuck Closed P1708 Pressure Switch "D" Circuit High P1709 Pressure Switch "E" Circuit P1710 Pressure Switch "E" Stuck Open / Performance P1711 Pressure Switch "E" Circuit Low / Stuck Closed P1712 Pressure Switch "E" Circuit High P1713 Pressure Switch "Reverse" Circuit P1714 Pressure Switch "Reverse" Stuck Open / Performance P1715 Pressure Switch "Reverse" Circuit Low / Stuck Closed P1716 Pressure Switch "Reverse" Circuit High P1717 Incorrect 6th Gear Ratio P1718 Incorrect Neutral Gear Ratio P1720 Solenoid "A" Controlled Clutch Not Engaged P1721 Solenoid "B" Controlled Clutch Not Engaged P1722 Manual Selector Valve Controlled Clutch Not Engaged P1723 Solenoid "A" Controlled Clutch Engaged P1724 Solenoid "B" Controlled Clutch Engaged P1725 Manual Selector Valve Controlled Clutch Not Engaged P1730 Retarder Circuit P1731 Retarder Circuit Low P1732 Retarder Circuit High P1733 Retarder Temperature Sensor Low P1734 Retarder Temperature Sensor High P1735 Retarder Over Temperature P1736 Service Brake Input "ON" With VSS Indicated P1737 Kick Down Circuit P1740 NSBU Mode "A" Circuit P1741 NSBU Mode "A" Circuit Low P1742 NSBU Mode "A" Circuit High P1743 NSBU Mode "B" Circuit P1744 NSBU Mode "B" Circuit Low P1745 NSBU Mode "B" Circuit High P1746 NSBU Mode "P" Circuit P1747 NSBU Mode "P" Circuit Low P1748 NSBU Mode "P" Circuit High P1749 NSBU Park/Neutral Switch Compare P1760 TCM Supply Voltage P1780 MIL Requested By TCM P1781 TCM MIL Request Control Circuit P1782 MIL Requested By TCM - Data Invalid P1785 Shift Lock Solenoid Circuit - Low Voltage P1786 Shift Lock Solenoid Circuit - High Voltage P1790 TCM Checksum Error P1791 TCM Loop Error P1792 TCM Reprogrammable Memory Error P1793 TCM Stack Overrun P1800 Transmission Power Relay Control Circuit P1801 Performance Selector Switch (MLP) Failure P1804 Ground Control Relay P1810 Pressure Switch Manifold P1811 Maximum Adapt and Long Shift P1813 Torque Control P1814 Torque Converter Overstressed P1815 Transmission Range Switch Start in Wrong Range P1816 Transmission Range Switch P/N W/Drive Ratio P1817 Transmission Range Switch Rev W/Drive Ratio P1818 Transmission Range Switch Drive W/Rev Ratio P1820 Transmission Range Internal Mode Switch "A" Circuit Low P1821 Internal Mode Switch Mode "B" Circuit Low P1822 Internal Mode Switch Mode "A" Circuit High Voltage P1823 Internal Mode Switch Mode "P" Circuit Low Voltage P1824 Internal Mode Switch Mode "P" Circuit High Voltage P1825 Internal Mode Switch Illegal Range P1826 Serial Communication - DKI Failure P1827 Serial Communication - DKP Short to Ground P1828 Serial Communication - DKP Shorted High P1829 Serial Communication - TI Signal Line Open P1831 Pressure Control/Shift Lock Solenoids Power Control Circuit - Low Voltage P1832 Pressure Control/Shift Lock Solenoids Power Control Circuit - High Voltage P1833 TCC/Shift Solenoid Power Control Circuit - Low Voltage P1834 TCC/Shift Solenoid Power Control Circuit - High Voltage P1835 Kick-Down Switch P1836 Kick-Down Switch - Failed Open P1837 Kick-Down Switch - Failed Short P1842 1-2 Shift Solenoid Circuit - Low Voltage P1843 1-2 Shift Solenoid Circuit - High Voltage P1844 TCS Torque Reduction Request Circuit P1845 Torque Limiter P1846 2-3 Shift Solenoid Circuit - Low Voltage P1847 2-3 Shift Solenoid Circuit - High Voltage P1850 Brake Band Apply Solenoid P1851 Brake Band Apply Solenoid Range/Performance P1852 Brake Band Apply Solenoid Low P1853 Brake Band Apply Solenoid High P1857 3-2 Solenoid Circuit Low Voltage P1858 3-2 Solenoid Circuit High Voltage P1860 Torque Converter Clutch PWM Solenoid Circuit P1862 TCC Enable Solenoid Circuit Low Voltage P1863 TCC Enable Solenoid Circuit High Voltage P1864 Shift Solenoid 4-5 Circuit Low Voltage P1865 Shift Solenoid 4-5 Circuit High Voltage P1868 Transmission Fluid Life P1870 Transmission Component Slipping P1873 Torque Converter Stator Temperature Switch Circuit Low P1874 Torque Converter Stator Temperature Switch Circuit High P1875 4 Wheel Drive Lo Switch Circuit P1887 Torque Clutch Converter Release Switch Circuit P1890 P1891 Throttle Position Sensor PWM Signal Low Input P1892 Throttle Position Sensor PWM Signal High Input P1893 Engine Torque Signal Low Input P1894 Engine Torque Signal High Input P1895 TCM to ECM Torque Reduction Circuit P1896 Transmission Downshift Switch Circuit P1897 Transmission Upshift Switch Circuit P1898 Manual Shift Mode Switch Circuit
MODS,please make this a sticky!!
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
I used to be Dragoneye...
Awesome!
Where did you pull that information from? |
Tried to find something since I had seen a few requests. It took some time but I found this one site with it in PDF. Had to reformat it to show correctly on here.
westersgarage.eidnet.org/OBD2%20Trouble%20Codes.pdf It contains PCM - TCM - BCM - DDM - IPC - EBCM (ABS) - CANBUS Messaging. I still have to reformat the rest but all the pcodes are done and posted.
#6 |
WOW! Thanx for your work! I'm sure alot of members will appreciate this and benefit from it.
2010 2SS/RS/A6/RJT/Black Leather/Sunroof/Barton pistol grip shifter/Vitesse paddle shifters/CTS-V Ambient Footwell Lighting//ROTO-FAB CAI/XS Power 1 7/8 LT headers/Kooks HF cats/GMPP axle back/LSR swaybars/RX catch can/B&M tranny supercooler/ VMAX CNC ported throttlebody/VMS HSRK, etc.
#7 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
how do you know what dtc is. I have a livernois calibrator and on dtc it just say DTC RAW ,1,0,19,0 what are these
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Nitto 555R@25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
#8 |
![]() Drives: 2013 Inferno Orange Join Date: Jan 2013
Thank you!
Thanks for the codes!
| Thread Tools | |
| Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
| Diablosport Predator *In Stock* $369 Shipped | BMC Performance | V8 Bolt-Ons & Tunes | 36 | 11-16-2009 12:53 PM |
| GM January Sales Down 48.8%... | FenwickHockey65 | General Automotive + Other Cars Discussion | 13 | 02-05-2009 10:26 PM |
| GM DECEMBER SALES DOWN 31%, BETTER THAN LAST MONTH | FenwickHockey65 | General Automotive + Other Cars Discussion | 18 | 01-07-2009 01:09 AM |
| Twinned Vehicles: Same Cars, Different Brands | TRIXXTERR | General Automotive + Other Cars Discussion | 31 | 10-02-2008 06:33 PM |
