Jason 98 TA
Old 09-26-2011, 11:59 PM   #1
navyblueburnout
navyblueburnout
navyblueburnout's Avatar
Drives: 2010 Camaro 2SS
mastmotorsports cam and springs Q's
I just recently bought a stage 2 track package from mastmotorsports.com wich includes a new cam, Duration@ .050 225/231
Lift 602/607, and nitrided valve springs. now i have heard alot of good things from them, but my questions are. Has anyone bought this package before and what they think about it? And i have seen ALOT of people with dual valve springs and does anyone thinks it would be a better investment instead of the ones that it comes with? Im looking at more quality here so speak your mind.
Proud member of the Never going back to Moderncamaro.com club!
navyblueburnout is offline   Reply With Quote
Old 09-27-2011, 12:01 AM   #2
navyblueburnout
navyblueburnout
Btw once everything is installed im going to post A LOT of pics and vids to make you all happy!
Old 09-30-2011, 07:48 PM   #3
navyblueburnout
navyblueburnout
guess no one has it.
Old 10-01-2011, 04:56 PM   #4
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Not too sure, but just read this post on mast and a spring incident... This is in NO way a shot at Mast just an interesting read on a spring incident. BTW, the guy in this thread was under boost also..... http://www.camaro5.com/forums/showth...e+spring+broke
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 10-01-2011, 05:04 PM   #5
navyblueburnout
navyblueburnout
awesome. thanks for the input.
Old 10-01-2011, 05:20 PM   #6
Rage
Rage's Avatar
I just had the G6x3 cam installed.... Had Patriot Dual extreme gold springs installed, with titanium retainers and locks.... The second spring might save your engine should the larger fail. Thats why I went with them.
Old 10-01-2011, 07:25 PM   #7
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Are you replacing the 8 AFM lifters?
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 10-01-2011, 07:52 PM   #8
navyblueburnout
navyblueburnout
Old 10-02-2011, 11:40 AM   #9
kaler
kaler's Avatar
Originally Posted by navyblueburnout View Post
If you have a L99 (auto) I would not run dual high pressure springs unless you replace the 8 AFM lifters.The AFM lifters will fail in short order with dual springs. I would check with Mast before you do it,even if you replace the AFM lifters.
Old 10-02-2011, 12:11 PM   #10
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Nice of you to revive the thread.
OP. You need to get a DOD delete if you wish to run duals. Those VVT kits are designed with single*beehive* springs in mind. If you are set on running duals go ahead and do a full LS3 conversion.
A VVT cam and dual springs with stock DOD lifters are a recipe for disaster IMHO.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 10-02-2011, 12:25 PM   #11
Rage
Rage's Avatar
Sorry Lex, was just researching Cam stuff before I took the plunge.... Came across your thread. Hope all went well with the repairs
Old 10-02-2011, 01:11 PM   #12
lexlueger
lexlueger's Avatar
No problem, that was some time ago. Find a great install shop and tuner. GL
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 10-02-2011, 01:58 PM   #13
navyblueburnout
navyblueburnout
I have a LS3. so im kinda confused right now.
Old 10-02-2011, 02:03 PM   #14
lexlueger
lexlueger's Avatar
You can do duals with no issues. Thought it came with duals, maybe not.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
After market cam with stock springs? Bad70supreme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-31-2016 02:43 PM
LS3 cam, springs, and pushrods summitss/rsls3 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 04-10-2011 07:22 PM
Valve springs with cam - question marticus24 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 03-07-2011 10:01 AM
