JUICEDMOTORSPORTS
Old 09-27-2011, 02:34 AM   #1
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
slight surging @ idle
was just wondering if anyone else has this or noticed this.
when im sitting @ idle (at all time from start up to an hour after driving) i noticed a slight surging, enough for the rpm needle look like it boucing.
is this normal? or should i get this checked out.
OH and i have a ROTO-Fab intake and did a muffler delete if that matters, and i already did a fuse pull reset
622RWHP/512FTLBS on 91 octane
2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned
My build thread
DCC1464 is offline   Reply With Quote
Old 09-27-2011, 06:53 AM   #2
catalan
Drives: -
I experienced it when the car had only 2000Km and i had a hard brake stop before a traffic light .. i freaked out as the car was new and was vibrating and the rpm needle was going up and down a bit .. but then it stopped when driving ... still don't know why it happens ..
catalan is offline   Reply With Quote
Old 09-27-2011, 07:42 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Yes, I have this too!!! Just a slight variation in RPM while at idle. My tachometer bounces around 200-300 RPM. I was wondering the same thing...should I get it checked out??? My car has about 4100 miles on it.
blazzin1 is online now   Reply With Quote
Old 09-27-2011, 10:26 AM   #4
imperfectutopia
imperfectutopia's Avatar
Drives: 2010 Camaro 1SS M6, RJT
Normal guys, I asked the same thing when i first got mine.. The LS3 has a little bit of an aggressive cam in it and that causes a little lope at idle. Should be searchable "LS3 cam" for confirmation if ya need it.
imperfectutopia is offline   Reply With Quote
Old 09-27-2011, 12:23 PM   #5
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
You need a tune to correct this.
Everyone comments on how smooth my tunes run at Idle.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 09-27-2011, 12:25 PM   #6
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
it's normal. Everybody with the LS3 experiences this somewhat. But if your needle is jumping more than a couple hundred RPM, you may have another problem.
cab2g is offline   Reply With Quote
Old 09-27-2011, 12:35 PM   #7
DCC1464
COTW 5/27/13
DCC1464's Avatar
word thanks guys, i figured it was normal with how small the bounce was but just didnt remember ever seeing it before i left.
My build thread
Old 09-27-2011, 12:40 PM   #8
Synner
Drives: not stock
A lot of people have also said it goes away with aftermarket plug wires. Its on my to do list this fall after I figure out what I'm doing with my valve covers.
Old 09-27-2011, 07:09 PM   #9
Parag
Drives: 2010 camaro 2SS LS3
its actually mostly the stock throttle body, if you look at it closely, it has to pivot really far to actually increase throttle. so its the computer jumping throttle alot accounting for the delay in rpm rise. a better tune, or ported throttle body will almost stop it.
Parag is offline   Reply With Quote
Old 09-27-2011, 08:34 PM   #10
navyblueburnout
navyblueburnout
navyblueburnout's Avatar
Drives: 2010 Camaro 2SS
I experienced the same thing with mine then got a tune and it went away.
Proud member of the Never going back to Moderncamaro.com club!
navyblueburnout is offline   Reply With Quote
Old 10-02-2011, 02:32 AM   #11
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Did you get a tune when you did the intake?
JLE58 is offline   Reply With Quote
Why did GM program the LS3 to idle so dam low? MikeOD Tuning / Diagnostics -- engine and transmission 22 04-18-2016 11:44 PM
Looking for an LS3 cam suggestion - mild, slight idle lope, great driveability... Russell James Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 06-13-2013 01:48 PM
Vararam and Surging RickyTheStorm Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 09-08-2010 09:20 PM
Car has slight stumble at idle? 6DEAN9 USA - California 15 02-18-2010 08:33 PM
High Performance Exhaust AntmanZ28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 94 08-22-2009 03:16 PM
