Old 09-27-2011, 02:22 PM   #1
CyberPredator
50 Shades of Prey
Drives: TT/SS
clutch sticking solution
Is this a better solution to the clutch sticking issue? Anyone have it? http://www.ramclutches.com/zen-cart/...roducts_id=677
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 09-27-2011, 02:27 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Next time you're in the car, after you've been driving it for about 10-15 minutes. Pump the clutch pedal 6-7 times. That will cycle all of the fluid through the system. So if you had anything built up it hopefully will be fixed. I know it's not a "real" fix but it's worked for a few members who've had this issue.
Click to view my build thread
Old 09-27-2011, 09:18 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
that might make it worse as the travel is reduced
Parag is offline   Reply With Quote
ACT twin disk clutch install by Mike Norris Motorsports ducatisl V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 09-06-2016 08:38 PM
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 05:11 PM
clutch sticking halfway fix? GQ4Life V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 10-13-2010 01:20 AM
deleted post Kubi V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-21-2010 06:35 PM
clutch sticking to floor BatmanX Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-21-2009 04:39 PM
