Old 09-27-2011, 02:59 PM   #1
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Question Trailing arm bushing removal tool
Hey everyone! Well look im in the middle of doing the whole suspension on my car. I know PFADT makes a tool to remove the trailing arm bushing but i really dont want to order and then wait like 4 days for me to receive it! I've heard that alot of u guys have made ur own tool and its worked! Any ideas on what i can use to make my own tool? Sizes and lenghts of stuff needed would really help. Any pictures???? Thats the last thing i need, everything else in the suspension is done! Thanks everyone!!!!!
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 09-27-2011, 03:16 PM   #2
Synner
Drives: not stock
Got a harbor freight nearby?
http://www.harborfreight.com/3-piece...-set-8832.html
Can't remember the socket size if you want to do it with a couple washers, bolt, and a nut.
Old 09-27-2011, 03:21 PM   #3
BAWLZ SS
BAWLZ SS's Avatar
Yeah theirs a Harbor Freight not to far from home. I checked out the link but how can i use tha puller to get that bushing out?
Old 09-27-2011, 03:40 PM   #4
Synner
Drives: not stock
You trim the lip off one side of the bushing with a razor, place a piece of metal on the bushing, then push it out in a push versus pull configuration. It will pop out fairly easily plus you now have extra tools. Everyone needs extra tools.
Old 09-27-2011, 04:22 PM   #5
BAWLZ SS
BAWLZ SS's Avatar
Yup extra tools Great im almost going to go buy them right now but where do u hook those arms to? Is there enough space to do it??
Old 09-27-2011, 04:26 PM   #6
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
I just went down to the hardware store and came up with this. Some threaded rod, some pipe that was just a bit bigger then the stock bushing and some sort of plate steel and some nuts to make jam nuts.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 09-27-2011, 05:22 PM   #7
Synner
Drives: not stock
The spindle that the bushing is mounted in. And yes.
Old 09-27-2011, 05:32 PM   #8
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
That's perfect Sealth! Here is a diagram with a little info on our removal tool. It's not rocket science here, mostly a trip to lowes would yield good results.
Old 09-27-2011, 05:46 PM   #9
BAWLZ SS
BAWLZ SS's Avatar
Thanks guys! greatly appreciated!!!!!
Old 09-27-2011, 05:48 PM   #10
BAWLZ SS
BAWLZ SS's Avatar
Im going to give it a try! Thanks!!!
Old 09-27-2011, 06:01 PM   #11
Stealth 2010 2SS/RS
Best of luck to you. cheap easy tool to make.
2010 LS3 2SS/RS M6
Old 09-27-2011, 06:56 PM   #12
rdblan2
Drives: 2SS RS
I've seen you guys post that a number of times. Good on you for telling folks to make their own instead of trying to sell something to them.
I must purchase something from you folks now!
rdblan2 is offline   Reply With Quote
Old 09-27-2011, 07:16 PM   #13
B-Rex
B-Rex's Avatar
Drives: 2011 2SS/RS
Blowtorch
B-Rex 2011 2SS/RS LS3
Hurst, LG, C.A.I., Flowmaster, Pfadt, Pedders, U.S. Gear/Axle Tech, LPW, SJM, Nitto, Nitrous Outlet, ZEX
B-Rex is offline   Reply With Quote
Old 09-27-2011, 07:46 PM   #14
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
I used a two prong puller. You can rent one at Autozone or Pepboys.
mhog is offline   Reply With Quote
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
