JDP Motorsports
Old 09-27-2011, 06:42 PM   #1
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
Cai QUESTION
After driving for about 30 min is it normal for the intake tube to be extremly hot?
dshep214 is offline   Reply With Quote
Old 09-27-2011, 06:50 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes (ish), it is normal for the outside of the tube to get hot. But how hot are you talking?
Click to view my build thread
Old 09-27-2011, 06:56 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I run a scangauge II plugged into my OBD port and can monitor a bunch of stuff to include inlet air temps. if the outside temp is 100 deg for example the temp of the inlet air will climb into the 120's and 130's while at a traffic light. Then after a minute or two of running at speeds above 30 the inlet temp falls to within 5 deg of outside air temp. and at highway speeds the inlet temp is 2 degrees above outside air temp. So yes, it will get hot on a hot summer day.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 09-27-2011, 09:16 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
the fan pulls heat from radiator right onto the CAI, thats why i hate metal ones
Parag is offline   Reply With Quote
Old 09-28-2011, 01:47 AM   #5
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Unfortunately many do, even too hot to touch after sitting, engine off, for 15 minutes or more.
Having a heat sink metal pipe as a cold air intake seems contradictory IMO.
JDP Tech is offline   Reply With Quote
Old 09-28-2011, 09:10 AM   #6
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
We get this question all the time, allow me to explain. Your engine gets very hot, therefore it puts off heat and transfers that heat to everything around it. Our job is to keep the intake air as cool as possible and is what you are paying for when you buy our system. We don't care if the outside of our system or any other componet under the hood is hot, we care about the intake air. That is why we ceramic coat our intake tubes inside and out, to keep the heat on the outside of the tube rather than soaking through to the intake air. So when your intake tube is hot the ceramic is actually doing its job of keeping the heat on the outside. If the tube was not hot to the touch ask your self a common sense question, where did the heat transfer to....answer...the intake air! I hope this helps answer your concern.
Read above, if it was contradictory it would not keep the intake air within 2 degrees of ambient at cruising. We don't manufacture cold "tube" intakes, we manufacture cold "air" intakes. Judging from his IAT our system is performing exactly how it is designed to perform.
Sales @ CAI Inc is offline   Reply With Quote
Old 09-28-2011, 11:18 AM   #7
BullF-16
BullF-16's Avatar
This is true and verified by my Scangauge II. I run it with MAP, inlet air temps, rpms, and fuel pressure displayed. its obvious the system works very well here in texas. This past summer the ambient temps were about 110 every day. While driving, the intake air temp was always about 2 deg more that outside air temps. While stopped idling at a light it would climb to the 130's but once moving again it would drop to withing 5 deg of outside temps within a minute or 2. That tells me it works.
Before i put the CAI on the stock box would never get with 15 deg of outside air temps.
Old 09-28-2011, 11:29 AM   #8
DINGO
DINGO's Avatar
Drives: 2010 CGM 2SS/RS M6
Should have bought the CAI cold air kit. I have it and wouldn't trade it for anything.
DINGO is offline   Reply With Quote
Old 09-28-2011, 11:50 AM   #9
Sales @ CAI Inc
Exactly!!
Noob Question: Cat-Back And CAI Powhusku Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 08-25-2011 10:01 PM
question about CAI & Relocation of the washer Bottle luis nunez Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 07-28-2011 11:48 PM
CAI question... mikester0612 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 04-27-2011 09:05 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Made my own CAI (Now with pictures)! I have a question though BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 01-26-2010 09:30 PM
