Old 09-28-2011, 02:35 PM   #1
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Question Driveshaft queation!?
Ok everyone hopefully u guys can help me out! I am ready to bring back up the cradle on the car after dropping it to change out the cradle bush, differential bush, toe rods, trailing arms, sways... But my question is... I forgot to mark the driveshaft so that i can put it back together exactly the way it came off. Does it matter if it doesnt go back on in the exact same holes? It should be balanced and shouldnt matter right? Also are those 3 bolts that u remove... Are they reusable? Do i have to get new ones? Someone on here thought they werent thats why im asking? Any tips?? Thanks everyone!!
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 09-28-2011, 02:50 PM   #2
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I've had my driveshaft out three times already, i reused my old bolts just put a little locktite on them. they originally use lock nuts but after they are taken off they become a little weaker so the locktite will fix that. as for marking the shaft before taking it out - its always best to do that. i marked mine the first time and wouldnt you know it the marks rubbed off (because i used a shitty piece of chalk to make my mark) so i couldnt tell where it was . i installed the shaft in a different spot both times and had no problems so i think you'll be fine.
IDEALG is offline   Reply With Quote
Old 09-28-2011, 04:32 PM   #3
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
dont worry about balance with this style shaft, the shaft is balanced separately from the ends.
Driveshaftshop is offline   Reply With Quote
Old 09-28-2011, 06:32 PM   #4
BAWLZ SS
BAWLZ SS's Avatar
Ok so im good!!!! I can use the same bolts just need a lil locktite (blue) ?? And it dont matter in which holes i bolt it to right??
Old 09-28-2011, 06:38 PM   #5
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Speaking of drive shafts... I have a question for you guys. I spoke to a local performance shop and the guy on the phone was unsure, but he said he thought the LS3's come with aluminum driveshafts and the L99's do not. Is that true because I have never heard that or looked under my car to verify.
newagemuscle is offline   Reply With Quote
Old 09-28-2011, 06:43 PM   #6
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
@ the OP: Blue loctite will be fine.
@ newagemuscle: The stock DS on the LS3 car is 2 piece steel.
Squintz Palladoris is offline   Reply With Quote
Old 09-28-2011, 07:24 PM   #7
BAWLZ SS
BAWLZ SS's Avatar
Old 09-28-2011, 07:26 PM   #8
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
New bolts would not hurt but if u cant get them i wouldnt let it put a time constraint on me
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 09-28-2011, 07:29 PM   #9
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
As is the auto as well.
Old 09-28-2011, 07:39 PM   #10
Squintz Palladoris
He was told the LS3s were aluminum and the L99 was steel
Old 09-28-2011, 07:58 PM   #11
PQ
Booooosted.
PQ's Avatar
Right, I was just adding to what you said so nobody thought it was different.
V6 to V8 Driveshaft Question Amenti V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 09-05-2011 11:32 AM
Problems with Driveshaft after Coil-overs install..PLEASE HELP!! danrc28 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 04-16-2011 05:55 AM
2010 Camaro BMR Driveshaft Safety Loop pics!!! BMR Sales Dragstrip and Launch Techniques Discussion 29 12-13-2009 12:45 AM
2010 Camaro BMR Driveshaft Safety Loop Pics!!! BMR Sales Wheels and Tires Talk Sponsored by The Tire Rack 3 10-21-2009 12:21 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 09:15 AM
