Cold Air Inductions
Old 09-28-2011, 04:28 PM   #1
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
front end links ...opinions
Dear vendors i want a serious explano, opinions and reasoning about front endlinks, here are sum questions.
!. what material is best for street but can be raceable from time to time?
2. Are the lighter products really able to with stand the shock, and vibrational, torsional, fatigue forces better then stock? i.e steel parts.
3. are the teflon sperical beariings able to withstand the elements i.e dirt, water etc on the street as good as stock..since i live in nyc i need to know.
my fear is a piece that will bend or break with daily driving and under the streets that i live by .i.e potholes, snow, water, salt, etc.
ipimpthisc is offline   Reply With Quote
Old 09-28-2011, 05:29 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The stock ones will fail WAY before any of the aftermarket ones will. I will see if I can find a stock set and take a photo of them next to the new Pfadt end links we just got in. The difference is ridiculous.
Old 09-28-2011, 05:45 PM   #3
ipimpthisc
Banned
excellent chase...if possible can u give us real world values in tensile , shear, hot and cold points and effects between the 2...i love the chemistry and physic of it all,,, besides the simple this one works better explanos..i know ur the right man for this, btw send me an invoice for them like u did before, and thanks for the toe links, they look awesome
Old 09-28-2011, 06:06 PM   #4
Apex Motorsports
PM on the way.
Old 09-28-2011, 07:06 PM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey guys. A stock endlink installed on an aftermarket bar will fail much earlier than an aftermarket endlink. We designed our endlinks to withstand the abuse inflicted upon them by years of use with aftermarket sway bars.
With our engineering expertise you can rest assured that all bases have been covered for reliability and durability. We operate out of Salt Lake City, and our testing is done in conditions ranging from 100+ degrees in the summer to 15 degrees in the winter. Our roads aren't the greatest either, and during the winter it's expected to see a good amount of salt on the roads.
The teflon lined bearings have more than enough load carrying capacity to handle the work required of an aftermarket endlink. After lots of testing with the same bearings in our Corvette lineup we are sure that properly installed they will provide many miles of use in what ever environment you care to use them in.
If you have any questions let us know!
Old 09-28-2011, 08:29 PM   #6
ipimpthisc
Banned
ok great, sounds like i will be getting a set soon enough ...thanks chase, i am surprise pete hasnt signed in :?
Old 09-28-2011, 09:40 PM   #7
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
pete will be in, give him time, remember he is a few hours back from us. i know his explanation will be on point and very detailed so i will leave it to him on the position of pedders
camaro4mybday is offline   Reply With Quote
Old 09-28-2011, 10:10 PM   #8
ipimpthisc
Banned
ok thanx
Old 09-30-2011, 01:56 PM   #9
ipimpthisc
Banned
well mins up..so i pulled the trigger and got the pfadts
Old 09-30-2011, 05:08 PM   #10
Apex Motorsports
Thanks for your order. They just went on the truck.
Camaro5Fest III location nomination Atti2de 2012 Camaro5 Fest (III) 2717 05-31-2012 12:59 AM
PFADT FRONT AND REAR SWAY BAR END LINKS toonlovescheryl Suspension / Chassis / Brakes 15 10-15-2011 02:25 PM
2010 Camaro Heavy Duty Front and Rear End Links by Hotchkis Xplosive Performance Suspension / Chassis / Brakes 5 07-06-2011 10:19 AM
BMR Suspension End Links Available At APEX Motorsports: Camaro5's #1 Source For BMR!! Apex Motorsports Suspension / Chassis / Brakes 17 02-07-2011 08:53 PM
