Jason 98 TA
Old 09-29-2011, 12:20 AM   #1
Raptor626
Drives: 2011 Camaro SS Summit White
Oil Pump issue. Is the L99 just as prone?
Ok so over the summer a lot of members were reporting that their oil pumps would fail due to a stuck relief valve. Oil pressure would subsequently drop and some unfortunate members even suffered catastrophic failures. A solution to this problem was to "shimmy" the relief valve to prevent it from getting stuck. Originally I thought all 6.2's had this issue, but then a member in the thread below stated that L99's actually use a different pump, one with a "wider pump gear".
Does that therefore mean that L99's are immune to this oil pump failure or not?
See post #19 and 20.
http://www.camaro5.com/forums/showth...l+pump+failure
Raptor626 is offline   Reply With Quote
Old 09-29-2011, 12:29 AM   #2
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
i wouldnt chance it...get the moroso upgrade man...this happened to me...thank God i was sitting idle when it did...
ipimpthisc is offline   Reply With Quote
Old 09-29-2011, 12:31 AM   #3
Raptor626
Damn bro. That's a pretty huge job. How much do you estimate labor to be?
Old 09-29-2011, 12:40 AM   #4
ipimpthisc
Banned
the oil pump was about 150, i alsodid the belt tensioner, dunno how much was...but if ur gonna do this its about 800 labor,,,i would spend another 2k for a full cam swap, with upgraded springs, retainer etc.
Old 09-29-2011, 08:03 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I think of this as more of a "do it if you're already in there" kind of thing. It seems like a waste to spend $1k to change just the oil pump on your stock engine when it's covered under a warranty.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-29-2011, 11:01 AM   #6
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
I have the L99 and afte the lifter swap I have lots better oil pressure. Cold idle is 50lbs. Warmed up cruising is around 45psi if It quits I'm going to hold it to the floor. And let GM EAT IT
hunter1660 is offline   Reply With Quote
Old 09-29-2011, 11:03 AM   #7
LittleMT
user bann'd
LittleMT's Avatar
Drives: Chevy SS
I have yet to read about a l99 having this failure..
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6.
LittleMT is offline   Reply With Quote
Old 09-29-2011, 12:39 PM   #8
Raptor626
So you just have the LS3 conversion and the stock L99 oil pump?
Old 09-29-2011, 12:59 PM   #9
Raptor626
That makes me feel better, but I think it's one of those things where only time will tell.
Old 09-29-2011, 01:13 PM   #10
BLACK10
BLACK10's Avatar
$800 for an oil pump change? wow
Old 09-29-2011, 01:42 PM   #11
Raptor626
I know It seems that everything costs so much more in the North East.
Old 09-29-2011, 01:56 PM   #12
hunter1660
hunter1660's Avatar
No ls3 for me I'ma hold out for the warranty kinda guy good thing too...had afm lifters replaced under warranty after a year listened to it tick tick tick on startup after it set for a Couple hours .. The oil pressure improved greatly with the lifter swap..
Old 09-29-2011, 01:56 PM   #13
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
a LOT of work is involved with this though..pretty much the same amount of work as doing a cam swap minus having to pull a few parts.
plus the part is 1-200
Nvincent4708 is offline   Reply With Quote
Old 09-29-2011, 02:01 PM   #14
Raptor626
Right, it would definitely make sense to just cam it while you're at it.
failure, l99, oil, pump, valve
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 SQUALO Canada 56 04-21-2011 04:19 PM
