BORLA
Old 09-29-2011, 04:43 PM   #1
fiiggy
fiiggy's Avatar
Drives: 2014 SIM RS
Changing the 2ls gear ratio.
Ok so I have the 2ls camaro. I was wondering if I could switch to the regular gear ratio like the 1ls and lt models and keep the warranty. Would I have to get it from gm? And what all do I need?
fiiggy is offline   Reply With Quote
Old 09-29-2011, 05:58 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
it is possible to keep warranty if the dealer does the work but i doubt it. i was not aware that the ls has a different ratio, i thought all but the ss m6 was 3.23 ratio
Parag is offline   Reply With Quote
Old 09-29-2011, 06:01 PM   #3
ffrcobra_65
i wasnt aware there was a difference in gear ratios between the three V6 trims. Why do you wanna do that? Not worth it IMHO.
Old 09-29-2011, 06:26 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
This would make a noticeable differance. IMO the dealer would never know you had a gear in it unless you blew up the rear end. If thats the case you can take it back to whoever installed it and yell at them.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 09-29-2011, 06:27 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
The put different gears in the 2LS to get 30 mpg hwy
2.92 rear axle
Old 10-03-2011, 06:50 AM   #6
TankMorph
More Human Than Human
TankMorph's Avatar
Drives: 2011 1LT IOM M6
2.92 vs 3.27, I believe.
TankMorph is offline   Reply With Quote
Old 10-06-2011, 09:00 PM   #7
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
You could likely get a dealer to install the factory 3.27 for a price and I understand they can correct the speedo as well (it would read higher and accumulate mileage faster without computer recalibration) and keep your drivetrain warranty, I'm not sure the resulting performance improvement would justify the cost.
If you're going to spend the money, get the Richmond 3.55 aftermarket gears (they can confirm that its applicable to your trans), have a local reputable shop intall them and get the new Hypertech tuner to correct the speedo (and tune your shift points,etc..) I'm betting the overall cost would be about the same and it will drive like a different car!
Old 07-31-2012, 04:17 PM   #8
All Star
I'm an Engineer
All Star's Avatar
Drives: 2012 Camaro 2LS
Send a message via AIM to All Star
I want to do this...I'm thinking of going with an LSD down the road as well, how do the two work together? Are the gears independent of the differential?
I don't want to blow my warranty either...if I go with the 3.55's, I would need a tune and bye bye warranty.
All Star is offline   Reply With Quote
Old 07-31-2012, 10:27 PM   #9
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
If you have an auto trans, no posi available yet, the differential is a beast all by itself. 195mm ring gear is what I am told. Do the gears and posi ( when available) at the same time and save paying labor and setup twice.
etmx183 is offline   Reply With Quote
2ls, gear, ratio, warranty
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Why such small 3.27 gear on L99? Heavy car 1Camaro2SS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 03-06-2017 02:27 AM
Best gear ratio and locker for M6 ams450r V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 02-17-2011 09:14 PM
L99 A6 (D or M -always starts you out in 1st gear) SGOS252382 Dragstrip and Launch Techniques Discussion 3 04-20-2010 07:27 PM
Does any 6 speed owners see a need for a gear indicator? OHIOSS 5th Gen Camaro SS LS LT General Discussions 98 10-13-2009 09:36 PM
