Jason 98 TA
Old 09-30-2011, 10:21 AM   #1
jonmnorman
Drives: 2010 1ss
Lowering Springs
Hi all,
I'm going to lower my 2010 1SS but I have two questions.
1. What springs would you recommend for a 1.5-1.7" drop. Its more aesthetic than performance motivated.
2. Do I have to replace the factory struts or can I simply install the new springs?
Thanks for your input and keep up the good work!
jonmnorman is offline   Reply With Quote
Old 09-30-2011, 10:42 AM   #2
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
I'm sure you can just drop with the springs. Someone else will chime in. I have some Pfadt springs for 180 shipped. 1.25 drop though.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-30-2011, 10:46 AM   #3
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
Originally Posted by jonmnorman View Post
Hi all,
First off... Welcome to the forum...
The numbers you posted are a bit extreme for these cars. Most go 1 to 1.25" with drop springs and you won't need to change struts. There are a few vendors here that can help you with your selection. I know BMR has 1.25 drop in the front and 1" in the back that sets perfectly. Here's the link..http://www.bmrsuspension.com/?page=p...d=77&catid=224
Good luck...
Old 09-30-2011, 10:47 AM   #4
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
You may want to post this in the Suspension forum (I'm sure it'll get moved there anyway), but if you do a search you could probably find exactly what you're looking for. I'm thinking Pedders will give you a good drop, but to get that low you may need to go with coilovers.
Deke736 is offline   Reply With Quote
Old 09-30-2011, 10:51 AM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
H&R and DSE make 1.5" drop but when you start getting that low without a coilover then your going to get a horrible ride. You should really be looking into coilovers.
BTW: to lower by springs then you only replace the spring...not the whole strut. Plenty of DIY stuff on here. And if you want to stick with a spring, jump on Rogan's Pfadt springs. Good price and that's about as low as you want to go and still perform well.
Build Journal
Old 09-30-2011, 10:59 AM   #6
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
That is very low. You are turning your smooth riding Camaro into a Hardtail (Harley talk for rough as all hell).
I used Hotchkis springs and lowered car 1" to 1.25" for performance reasons. It greatly reduces the smooth ride to one much more bumpy- has to be a stiffer ride so your not hitting/bottoming out with every little pebble you run over.
Also, if you are planning on wider tires, you are limiting your options.
No way would I lower my car any further. Anything can be done, but there are consequences- not only for how much I lowered mine, but especially more so with what your asking to do. Good luck. You can always reverse it, but it is not a cheap option to take that lightly.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 09-30-2011, 01:14 PM   #7
jonmnorman
Drives: 2010 1ss
Good luck...
Thanks.
Old 09-30-2011, 03:17 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If you are going to be looking into going that low I would definitely check out a nice set of coil-overs or if you can stand to have the vehicle a little higher we have 1.4" drop springs. We have found that anything lower than 1.4" really puts a lot of strain on the factory struts/shocks so we don't recommend anything lower unless you do upgrade to the coil-overs. If there is anything I can help you out with let me know.
Old 09-30-2011, 06:07 PM   #9
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
180? Where did you get that deal if you don't mind me asking.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 10-01-2011, 12:18 AM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
He's selling HIS set for that amount.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-01-2011, 03:21 AM   #11
Speed Depot
Speed Depot's Avatar
Drives: 2010 Camaro
Send a message via AIM to Speed Depot
Hi all,
Welcome to the Forum.
I can offer you some Pfadt springs, you can change just the springs and keep your factory struts.
Speed Depot is offline   Reply With Quote
Old 10-05-2011, 09:35 AM   #12
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
As everyone mentioned above, that amount of drop is getting into coil-over territory. You can go a max of 1.4" before you start having valving concerns, bump stop issues and alignment problems. 1.4" looks great on these cars and is much more economical than the coil-over route.
BMR 1.4" springs:
BMR guy is offline   Reply With Quote
Old 10-05-2011, 09:52 AM   #13
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Hi all,
We can get springs for a 1-1.4" drop for you. If you want coil overs to get past that we have several options for you as well. Give us a call and we can go over some options.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is online now   Reply With Quote
Old 10-06-2011, 08:26 AM   #14
USMCSSGT-RET
USMCSSGT-RET's Avatar
Drives: '14 SIM 2LT/RS Vert
As others have said, going that low with just springs will hurt your ride quality. Low is nice, but you have to be able to stand the drive. I'm on the Eibach Pro-Kit....1.3" up front and 1" in the rear for the V6. I believe the V8 kit is 1" all the way around. Here's some pics of my set-up....wheels are 22X9 265/35/22 front and 22X10.5 295/30/22 in the rear.
USMCSSGT-RET is offline   Reply With Quote
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 06:17 PM
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. Apex Motorsports Suspension / Chassis / Brakes 341 02-02-2014 12:52 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
