Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-30-2011, 01:37 PM   #1
SS_MUSCLE's Avatar
Drives: 2010 1SS IBM LS3/M6
New possible fix for clutches that engage too high in the stroke
I know this is a somewhat old topic but I just had my 2010 ss in the dealer today to see what they had to say about mine. As it turns out in my case there was a piece of sound deadening material that got wedged between the clutch master cylinder and firewall when they were bolted together at the factory. This in a sense shimmed the clutch master cylinder in turn making my clutch pedal have to travel further to reach its point of engagement. They removed the clutch master cylinder, removed the material, reinstalled and bled the system and let me tell you....WHAT A DIFFERENCE Just thought I would throw this out there as another possible cause for some peoples issues with the engagement point.
SS_MUSCLE is offline   Reply With Quote
Old 09-30-2011, 02:53 PM   #2
Drives: 2010 camaro
this is good to know!!!!
toilets is offline   Reply With Quote
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2790 08-22-2017 12:28 AM
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! AJ@ECSMotorsports Transmission / Driveline 21 11-13-2010 03:58 PM
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 12:13 PM
The Comaro Betrayed Chevy djljm Off-topic Discussions 36 11-28-2009 08:38 PM
