Old 09-30-2011, 05:57 PM   #1
davidbecker
Drives: 1998 camaro
Help Please
I have a 98 camaro base w/ 3.8. I will not run right. it seems to idle ok but has no power driving down the road. it seems like something is holding it back. i have replaced the plugs ,wires, crank sensor. the check engine light is throwing 3 codes 1 is for the egr valve the other 2 is for misfire. i did disconnect the egr valve and blocked of the holes. i was told that is why its has no power that i need the egr. is that true?
davidbecker is offline   Reply With Quote
Old 09-30-2011, 06:01 PM   #2
dmginc
dmginc's Avatar
Drives: 14 Camaro 1LS AGM
try reconnecting the EGR and see what happens? sounds like a clogged fuel filter or a bad fuel pump to me.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 09-30-2011, 06:06 PM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
My father had an EGR valve go bad on a car, and it only affected the idle. I don't think they can route enough exhaust back into the engine to effect it that much under a load.
There are a lot of reasons it could be down on power. Weak fuel pump, bad compression, weak coil/spark (you do have misfires), a plugged up catalytic converter, sensors, etc...
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 10-01-2011, 12:31 AM   #4
davidbecker
Drives: 1998 camaro
thanks for all the fast responces. I did not think the EGR valve would do that either. the car runs but not very well. even on very wet roads from a stop , flooring it will not spin the tires it just climbs speed slowly. also i have noticed today that my fuel economy is crap.im getting about 200-250 miles to a full tank of gas :(. could it be my TPS? im sorry im new to thesde and just trying to figure out what is what. as i dont want to get ride of it as the body has no rust at all. its very solid
Old 10-01-2011, 10:39 AM   #5
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Does it rev to high rpms and you are barley moving? That usually means a clogged cat.
also, have you changed the spark plugs yet?
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 10-01-2011, 12:47 PM   #6
davidbecker
Drives: 1998 camaro
i changed everything yes. and no it just seems like it has a 4 cylinder in it the rpms build with speed. just lacks the HP
Old 10-01-2011, 12:47 PM   #7
davidbecker
Drives: 1998 camaro
and it runs rough. shaking and seems like it wantes to stall but i dont.
Old 10-01-2011, 02:24 PM   #8
dmginc
dmginc's Avatar
sounds like a fuel issue...fuel filter is pretty cheap and easy to replace and is the first thing i would try.
Old 10-01-2011, 06:35 PM   #9
davidbecker
Drives: 1998 camaro
if the filter was pluged i would not be going through that much gas would I ?. not trying to argue just trying to figure out how this car works.
Old 10-02-2011, 07:07 AM   #10
fielderLS3
fielderLS3's Avatar
Does it run lousy at idle, or just under a load? Does it get worse as you give it more throttle?
Old 10-02-2011, 11:21 AM   #11
davidbecker
Drives: 1998 camaro
it runs rough at lower rpms. but even worse at idle and especialy when you put it in gear and hold the brake, it really shakes then
Old 10-02-2011, 11:24 AM   #12
davidbecker
Drives: 1998 camaro
also i just checked my gas as im on E now. i went from As full as i could get it to E in 188 miles.and i drive it highway and very easy.
Old 10-03-2011, 08:59 PM   #13
davidbecker
Drives: 1998 camaro
got it guys, i had to replace all 3 coils and she runs great
Old 10-06-2011, 10:09 PM   #14
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Glad to hear she runs good now lol.
