HeadlightArmor
Old 04-02-2009, 10:55 AM   #1
Gib
Gib's Avatar
Drives: 2010 2SS/RS, RJT 04 Silverado
Transmission Cooler
Does anyone know if the SS with automatic tranny comes with an external transmission fluid cooler? I have tried several searches, but have not found any info on this. Thanks,
GIBS SS
Gib is offline   Reply With Quote
Old 04-02-2009, 11:01 AM   #2
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Why yes it does, it also has an oil cooler
Kyle2k is offline   Reply With Quote
Old 04-02-2009, 11:04 AM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
All SS's come standard with both transmission and oil coolers.
Sterling is offline   Reply With Quote
Old 04-02-2009, 12:30 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you're worried about it, you could probably add a B&M Supercooler (or similar) in-line too. I have a pair of 24Ks on my '02 and they work great. My car has never gotten above 180*, even after passes on the track.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-02-2009, 01:40 PM   #5
Vash
Drives: 00 Blazer
I am waiting for the service manuals to be released to public but I think it's just the integrated coolers in the radiator. There is a main and aux electric fan. Will have to look at manual or if someone else knows if there is another cooler.
If it's like I said above then the key is just keeping the coolant cool. Else all 3 get hot.
An important note is that in the future past 100,000 miles NEVER use any other replacment radiator than Delphi original. otherwise the coolers blow, the lines don't line up etc, (corvette lessons learned).
Old 04-02-2009, 02:38 PM   #6
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
I would say that is good advise for any repairs. I am a firm believer in using OEM replacement parts even if they are more expensive. I've been burned before trying to save a buck by getting "compatible" parts that don't have good QA practices at the Mfg. or just don't last as long. Since I have been using OEM parts, my repairs have been solid. I learned my lesson on my wife's Envoy that needed struts and shocks. I went to Merchant's Tire close by and failed to tell them I wanted OEM equipment installed and instead they put on this popular branded stuff telling me it was a step up and better quality. Now it rides like a damn truck when it used to ride like a Cadillac the whole time we've had it. My kidneys feel every bump in the road now. Should have had them put on the same parts the car was engineered to use in the first place. Say what you want but it's OEM for my vehicles from now on.
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 04-02-2009, 02:57 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
with the new stall i have i will be adding a large trans cooler to mine also.
Old 04-02-2009, 03:13 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've had good luck and bad luck with both while working at a dealer and bodyshop for ten-plus years. I'll say that most of the time, OEM parts were superior, but there were times when aftermarket were just as good, and even had a better written warranty. Shocks are those funny things where unless you get specific OEM shocks for your suspension (a lot of vehicles have more than one set-up - i.e. trucks have Z66, Z71, etc.) and I totally agree that aftermarket shocks can completely change the ride of a given car. However, GM doesn't make these shocks. I've seen Bilsteins on GM cars, Ranchos on Ford trucks, Tokicos on Toyotas, so there are specific tuning that manufacturers use in getting the ride in the vehicle the way they think it should be. Not all aftermarket parts are bad though
That's the best thing to do. I'll tell you, that it took me almost a month to control my tranny temps' to a range I was comfortable with. I used to be able to get the temperature to 200* in traffic and when I was done finalizing placement of the coolers, it wouldn't go more that about 175* in the same conditions. An external cooler would be ideal for this car, stock, and if in conjunction with an internal cooler should probably prove to be good for a stock stall. Like you, though, with a bigger stall, a bigger cooler wouldn't hurt at all. I'd keep that internal cooler in the loop though. A lot of racers say the 4L60s shouldn't be raced when the temps' go above 200* or-so; I'm not sure about these 6L80s, but I'd play it safe and make sure it has an external cooler, with a gauge, just for safety.
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 05:40 AM
No remote start with Manual Transmission? 2Muchmark 5th Gen Camaro SS LS LT General Discussions 26 03-30-2009 09:24 AM
Which transmission will the L99 have? mega V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 01-08-2009 07:53 PM
Dual clutch transmission (DCT)? Bruno Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-08-2008 03:47 PM
