JDP Motorsports
Old 09-30-2011, 09:20 PM   #1
ccrognlie
ccrognlie's Avatar
Drives: 2011 Camaro 1SS Black on Black
How low can I go?
Running 22's and now its time to lower.. How low can I go for proper clearance?
Eibach is 1"
There some other kits that go 1.5" to 1.8"
Looking for guidance
ccrognlie is offline   Reply With Quote
Old 09-30-2011, 09:21 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
I wouldn't go more than an inch. You could probably get away with 1.5" but I'd be willing to bet you'd hit a curb or parking block eventually.
Click to view my build thread
Old 09-30-2011, 09:27 PM   #3
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i was running a little over 1 1/2 inch , but wore the crap out of my rear 315x25x22..seems that when you drop that far, you start to get into negative camber area...that will wear the crap out of inside tires...had to raise back up to 1/4 to get camber around -.02..my tires are like 30% tread in 3k miles on rear from the negative camber...really only would hit on driveways with sttep inclines or dips in front of driveways if i took to fast...biggest issue is trying to jack car up..get boards to drive on a good low profile jack
mikepage0007 is offline   Reply With Quote
Old 09-30-2011, 09:27 PM   #4
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
depending on the tire diameter and width of the wheels, you can do down about 1.5 inches...
send nine ball or one of the suspension guys a pm.
Old 09-30-2011, 11:16 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you have the proper offset on the rims and the tires aren't huge, you should be able drop as low as anyone else. Most people adjust their tire selection to mimic the overall size of the stock setup so tire height shouldn't change much. If you drop more than 1.25in in the back, you run the risk of not being able to get the camber within acceptable ranges to get good tire wear unless you have a aftermarket alignment solution.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-01-2011, 08:19 AM   #6
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
if you lower your car that much it is a good idea to get a set of alignment bolts to give you more camber. pedders makes a great set found here https://secure.merlinsoftware.com.au...Code=PDUSA5420
camaro4mybday is offline   Reply With Quote
Old 10-01-2011, 08:23 AM   #7
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
This is a 1.5" drop with factory tires and wheels. It does have an ACS front splitter so the ground clearance is really as low as you should go. There is not a lot of margin for error on the streets. Note the clearance when Nelson was going over the curb. Granted he is being overly cautious, but it is right there.
Old 10-01-2011, 09:24 AM   #8
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I have h@r 1.4 and 1.3 lowering springs. stance is great.
Old 10-01-2011, 11:13 AM   #9
mikepage0007
Drives: 2010 camaro
the alignment bolts are only so good ...i have full pedder setup...if you go anymore then 1 1/2 , you will not be able to adjust make to 0 camber...best you will get is approx-.04...i would run 1 1/4 so you can get camber around -.0--.02..otherwise as axis mention, inside tire wear...justicepete- pedders helped me correct this issue...car runs great @ -.05 and such, but at 350.00 tire every 4000 miles..:(
Old 10-01-2011, 11:16 AM   #10
mikepage0007
Drives: 2010 camaro
you could scrape the cig butts of the road.....lol...btw, the only issue you will have is tire wear at 1.5 drop...and won,t be real noticeable till its to late..
Old 10-01-2011, 11:43 AM   #11
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I'm pretty low but it's all about the alingment when going down to 1.5 or lower or it will eat the rear tires alive as mikepage0007 pointed out before!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-02-2011, 05:32 PM   #12
speedster
SST...
speedster's Avatar
Ha. Not overly worried about treadwear. It won't be from alignment.
Something about water burnouts and 1/4 mile passes has a tendency to wear the tires kinda fast...
Old 10-03-2011, 08:59 AM   #13
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Eibach is 1"
When developing our lowering springs, we found that 1.4" was the absolute lowest you could go while still allowing proper camber adjustment with the OE camber bolts. This is why we made our springs 1.4". If you want to go lower there are solutions like aftermarket camber bolts, shortened control arms, camber plates, etc to correct camber.
Here's our 1.4" lowering springs:
BMR guy is offline   Reply With Quote
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 04:11 PM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 07:27 PM
A6 low gear hesitation update abaucom21 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 08-25-2011 04:26 PM
Low Sound Quality IPOD Input To Head Unit WhereIsMyDog Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 08-21-2011 05:10 AM
Halloween Vortech Supercharger Sale - Prices so Low it's Scary!! BMC Performance Forced Induction 18 11-01-2009 07:44 PM
