sjm autoprod
Old 09-30-2011, 09:53 PM   #1
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
At what point do you need different plugs?
So I see a several posts about NGK plugs and other brands and wondering what the benefit is over stock plugs and at what point in your mods do you need to swap the plugs. I can see it necessary for SCs and radical builds, but at what point do these come into play?
bannonm is offline   Reply With Quote
Old 09-30-2011, 10:14 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
NEVER. The stock plugs work just fine for well over 600whp.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-30-2011, 10:15 PM   #3
oldfriend
Drives: Fiat 500 E
At the moment that the ads that one is bombarded with every time you open the paper/magazine or tv ad , that's the time you need to get them , in another words IT IS IN EVERY ONES HEAD , if it is not broken do not fix it !
Old 09-30-2011, 10:27 PM   #4
bannonm
bannonm's Avatar
Ha, I'll file this one with CAIs that give you15 HP gain. Thanks figured it was not worth it.
Old 09-30-2011, 10:42 PM   #5
axis
Search Ninja
axis's Avatar
That's not entirely true. There are two independently tested CAI's that have just about hit that. One is the CAI and the other is the Halltech Yellowjacket. Both hit the 13-14whp mark on their own. Add the ADM scoop to those and they gain even more than 15whp.
Halltech CF 102 fed
Old 09-30-2011, 11:49 PM   #6
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
there may be a legitimate reason to change plugs, but the 5th gen is a bit different than the 4th gen in that there isn't really anything to be gained by switching to a different plug. Forced induction, nitrous, or some other changes could make a call for different plugs, but for many applications I would save the money rather than switch plugs.
Apex Paul is offline   Reply With Quote
Old 09-30-2011, 11:57 PM   #7
siriusdish
Drives: 2010 Camaro L99
Or if the tips burn off..
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 10-01-2011, 04:24 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
That orange color on the plugs - octane booster?
-Mark.
Old 10-01-2011, 07:58 AM   #9
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
yes you do need different plugs for blowers/turbos
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 10-01-2011, 08:05 AM   #10
bannonm
bannonm's Avatar
I have the CAI Inc intake, and I have Dyno sheets to show otherwise. More like 4RWHP. So unless you can provide before and after dyno sheets, I stand by my statement.
Old 10-01-2011, 11:31 AM   #11
jtzako
Drives: 2010 IBM Camaro SS
I believe I have seen just such a sheet on this forum someplace... Also, unless you installed the CAI at the dyno shop right after your 'before' run there is no way to know if you got a truly comparable run on each end.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 10-01-2011, 11:39 AM   #12
Stay Marine
Finally home!!
Stay Marine's Avatar
Drives: IBM 2SS/RS; in transformation
Yep, there are two shown by Jannetty; 13 with just CAI, 15 with race scoop.
At C5F I ran the quarter all day bone stock. Ran 13.5-13.7 consistently. Added CAI and immediately ran 13.2. Don't think ~5hp is going to do that.
Stay Marine is offline   Reply With Quote
Old 10-01-2011, 11:42 AM   #13
Stay Marine
Finally home!!
Sorry to highjack thread...to the plugs...several builders/tuners on here showing stock A/C Delco doing well up to 800hp; even on some FI mods. Some have gone to stock ZR-1 plug for FI builds with success (up to 1,000hp). Guess colder plugs aren't critical, even on FI builds, unless its run that under stress/load for endurance. At the track or around town; not critical.
Old 10-01-2011, 12:30 PM   #14
siriusdish
-Mark.
Yes
2010 L99
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 09:10 AM
Car not idling properly after tune KapsSS Tuning / Diagnostics -- engine and transmission 34 08-10-2011 12:57 AM
BMR Front 2 and 4 Point Strut Tower Braces! FREE SHIPPING! AJ@ECSMotorsports Suspension / Chassis / Brakes 8 11-13-2010 03:45 PM
dealer messed up bad on my plugs...afraid there's damage carguy_z28 1st & 2nd Generation Camaros 9 05-29-2008 12:10 AM
