Emblempros
Old 10-01-2011, 04:30 AM   #1
Nasty1970
Nasty1970's Avatar
Drives: 2011 Red 2SS RS Convertible
Help????struts sticking up about 1 inch????
I just changed my oil, no biggy, jacked up from front crossmember, plenty of metal, put jack stands in appropriate places, lowered vehicle to start up, and noticed the car wasn't as low as before. It was physically lower to the ground before the oil change, I know because it was hard to get the jack under neath it! Then after letting the jack down after the oil change, it was noticeable higher off the ground, looking at it from above I noticed the strut towers rubber bushings were about 3/4 to and inch above the strut tower??? I tried jacking it back up and letting it back down, driving it and the bushings still are sticking up. The car seems to be lower again, but the strut tower rubber pieces are still not sitting flush anymore?
What in the he'll did I do?? I didn't do anything unusual, just jacked it up like you jack up a car, nothing is bent, or out of place, drives fine, no noises, do those struts move that much??? Anyone seen this??
[IMG]
<a href=http://i683.photobucket.com/albums/vv198/nacogdochesjaycees/20161112_121016.jpg target=_blank>http://i683.photobucket.com/albums/v...112_121016.jpg</a>
[/IMG]
1970 Camaro ,2011 Red Convertible 2SS,2008 Saturn Sky,2012 Jeep Wrangler
Nasty1970 is offline   Reply With Quote
Old 10-01-2011, 04:39 AM   #2
C586
Drives: 2011 Camaro LS
They do stick up quite a bit when the wheels are straight. it was high because of the independent front suspension. The car needed to roll a little bit to settle.
C586 is offline   Reply With Quote
Old 10-01-2011, 07:21 AM   #3
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The struts do stick up quite a bit. Get some Rhino ramps, much easier than jacking up the car for the oil changes. I think you should be good to go. Did you remember to reset the DIC after the oil change?
MMC is offline   Reply With Quote
Old 10-03-2011, 09:35 AM   #4
Nasty1970
Nasty1970's Avatar
yeppers!
[IMG]
[/IMG]
Old 10-03-2011, 09:41 AM   #5
Nasty1970
Nasty1970's Avatar
this just doesnt look right! Are you guys sure they are supposed to stick up like that?
[IMG]
[/IMG]
Old 10-03-2011, 09:41 AM   #6
IROCanSS
Drives: 89 IROC 350
They never sit flush... those pics are 100% correct. The shock tops are not actually attached to the car. If they were, it would ripe your car apart. Turn your wheel fuul right and look, then full left, they NEED to move!!! You're all good!! Happy motoring!
When you jacked up the car, the wheels hung and the shocks went to full extension... maybe the rubber came out of the perch, maybe it stuck... no big deal either way. When you re-weighted the car, the shocks/springs take a bit to settle back in.
Youre no losing your mind, it was likely higher but after a few miles, everything seats back into where it wants to be and all is good in the world again!
Old 10-03-2011, 10:13 AM   #7
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Absolutely normal.
BMR guy is offline   Reply With Quote
Old 10-03-2011, 04:21 PM   #8
Nasty1970
Nasty1970's Avatar
my paranoia got the better of me, so I stopped by a local dealership and had them pop the hood....the brand new camaro had the same gap!
I was freaking out, I swear they were flush the last time i noticed them!
Owell...I need to get some good ramps....lol
[IMG]
[/IMG]
Old 10-03-2011, 05:03 PM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Those look perfect... it really does throw you for a loop the first time you see it like that though.
Old 10-03-2011, 07:00 PM   #10
MMC
MMC's Avatar
Dress it up with some of these.
Old 10-03-2011, 08:37 PM   #11
rdblan2
Drives: 2SS RS
I hesitate to post this since it will be yet another mod I have to do, but did you paint that yourself or have a paint shop do it? You know d*mn well what I'm talking about mister! The strut tower.
rdblan2 is offline   Reply With Quote
Old 10-04-2011, 02:13 AM   #12
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
You already know the strut gaps are normal. So is your Camaro sitting higher after it has been lifted. The front wheels hang out when lifted. When set back down the camber is off creating a temporary increase in ride height. Roll her forward or backward a couple of feet and she'll sit back down to normal ride height.
Old 10-04-2011, 10:41 AM   #13
Nasty1970
Nasty1970's Avatar
ya, it sat back down after driving a few minutes....the funny thing was that I googled "strut tower popped up" and got some horrific story about struts coming completely off a car....lol
I know they travel, and I know there was nothing I could have done to screw them up, but when you see something like this, its pretty convincing!
[IMG]
[/IMG]
Old 10-04-2011, 10:42 AM   #14
Nasty1970
Nasty1970's Avatar
No, factory painted....are yours not painted?
[IMG]
[/IMG]
BMR "Split Drop": 1.4 inch front/1 inch rear Now Available At APEX Motorsports!!! Apex Motorsports Suspension / Chassis / Brakes 316 05-12-2016 07:00 PM
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 06:17 PM
Black SS with 1 inch drop coils Installed! Looks & handles Awesome! Info@PeddersUSA.com Suspension / Brakes / Chassis 6 05-16-2010 11:05 PM
Silver SS with 1 inch drop coils Installed! Looks & handles Awesome! Info@PeddersUSA.com Suspension / Brakes / Chassis 3 05-15-2010 03:42 PM
