Old 10-02-2011, 02:37 AM   #1
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Light-weight clutch and flywheel for LS3?
I've been researching clutches and flywheels and it's surprising that there's so little info out there on the weights of these things. Most marketing pieces just say "light-weight" without giving any specifics.
I've got a 2010 SS with a n/a build running less than 450 rwhp, M6 trans and I'm looking for a lighter clutch and flywheel than stock. Anybody have any recommendations along with the actual weights for the combo?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 10-02-2011, 08:04 AM   #2
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I would not want a lighter combo in the heavy camaro,we do have a twin with a aluminum fly wheel that would drop about 15lbs for you.Ill get the exact weight for you.
Hendrix-Engineering is offline   Reply With Quote
Old 10-03-2011, 07:48 PM   #3
Doc
Doc's Avatar
Thanks!
I've been reducing weight in mine. Right now with a full tank of gas it weighs in at 3,740 lbs. I'm working on getting it down under 3,700 without gutting it. A 15 lb drop would get me that much closer, but I am particularly interested in reducing unsprung and rotating weight. I know a lighter flywheel can save about 13-15 lbs but if I can also knock a few pounds off the clutch too that would be a bonus.
1SS/RS LS3 M6 IBM
Old 10-03-2011, 08:48 PM   #4
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Originally Posted by Doc View Post
Thanks!
How has your weight reduction campaign been working our for you. Does the car feel much different as it slims down?
Old 10-03-2011, 11:23 PM   #5
Doc
Doc's Avatar
Absolutely. But I haven't been just reducing weight; I've specifically been reducing mostly unsprung and unsprung rotational weight which has the most impact on performance.
You can read about what I've done in my project thread:
http://www.camaro5.com/forums/showthread.php?t=45165
1SS/RS LS3 M6 IBM
Old 10-06-2011, 04:58 PM   #6
Doc
Doc's Avatar
Sooo.... Hendrix.... you got that info?
1SS/RS LS3 M6 IBM
Old 10-06-2011, 05:20 PM   #7
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I have the Mantic dual disc clutch and flywheel set. It reduced the weight about 20 lbs from the stock clutch and flywheel.
Cam 427 is offline   Reply With Quote
Old 10-07-2011, 04:54 PM   #8
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
Our Lightweight Level 2 Clutch assembly weighs 42lbs total, so that would drop over 10lbs for you.
Chris@SPMC is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 07:00 PM
