sjm autoprod
Old 10-02-2011, 09:08 PM   #1
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Rear Clunking Sound after new gears and Driveshaft
Car is making a weird clunking noise (metal) after new diff with 3.91 gears, diff bushings and DSS aluminum shaft.
it happens mostly on 1st and 2nd gear also when pressing and releasing the gas pedal.
I know M6s have a "normal" slack in gears, but this sound is way more louder...:(
Help please
Video:
http://youtu.be/-thkw1qO0PE
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 10-02-2011, 10:15 PM   #2
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Check to see if the flange bolts at the rear of the driveshaft are hitting the top of the cradle frame just above them. With the amount of horsepower you're pumping out the rear moves quite a bit when you apply power. You may need different bolts/nuts if they're making contact and/or heavy duty differential bushings to cut down the amount of flex and movement.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 10-02-2011, 11:02 PM   #3
JM10
Se habla espaņol
JM10's Avatar
It sounds like there is a play somewhere between the driveshaft and the differential. It only happens when the trans is not under load.
Even when slowly taking off from a stop you can hear the "clunk" ...
In the video I was short shifting on purpose ..
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 10-02-2011, 11:47 PM   #4
Doc
Doc's Avatar
Again, check the bolts. If they're sticking out too far the clearance is VERY small so even a small amount of flex can cause the bolts to contact the top of the crossmember. I've been one of Frank's testers when he's been developing these driveshafts and this was a problem.
If there's contact you'll see it on the bolts and the top of the crossmember will be shiny where they've been contacting. The sound is tricky because it transmits through the shaft and makes it hard to isolate where it's coming from but the video sure sounds like bolt contact. It's not constant; it's on and off like the sound on your video.
Look for contact marks of any kind on the driveshaft and the bolts near the differential.
1SS/RS LS3 M6 IBM
Old 10-03-2011, 12:12 AM   #5
JM10
Se habla espaņol
JM10's Avatar
Thanks,
I will follow your advice and let you know.
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 10-03-2011, 10:53 PM   #6
JM10
Se habla espaņol
JM10's Avatar
You were right!
The bolts were loose (not touching the cradle) ......one of them I was able to move it with my hand
Now after tightening all of them everything is perfect, thank you very much!
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 10-03-2011, 11:19 PM   #7
Doc
Doc's Avatar
Originally Posted by JM10 View Post
You were right!
JM
Cool, glad to hear the problem is fixed.
1SS/RS LS3 M6 IBM
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
Thinking About Swappin' Gears? Here are the numbers! Apex Motorsports V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 32 04-24-2017 02:12 AM
ratios midlife V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 08-17-2013 03:27 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
