BeckyD @ James Martin Chevy
Old 04-02-2009, 06:54 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
500 hp with no cam?
is it possible with headers exhaust intake and programmer?
jordan 572 is offline   Reply With Quote
Old 04-02-2009, 07:06 PM   #2
Camaro509
Camaro509's Avatar
Drives: 2010 2SS/RS Black
Just off the top of my head, I would say no.
You'll free up a couple horses with a higher flowing inhale and exhaust,
but not 75 of them with just that.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure!
Folding@home Stanford's Research DC Program.
Camaro509 is offline   Reply With Quote
Old 04-02-2009, 07:08 PM   #3
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Headers, exhaust, and a CAI are typically good for about 30-35hp. A computer tune would help out too, but I still think you'd be a good bit shy of the 500hp mark.
nester7929 is offline   Reply With Quote
Old 04-02-2009, 07:24 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
stock cam.... full bolt ons. cnc'd heads... maaaaaaaaaaaaaaaaaaaaaaaaaybe. it would take a bit to get all of 500. this is at the crank right?
tho 500 is easy.... with nitrous or a super/turbo charger
I piss excellence
and fart awesomeness
Old 04-02-2009, 08:15 PM   #5
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
It will likely be possible full bolt-ons to achieve 500 HP @ the CRANK, but that is a whole different ballgame vs 500 RWHP.
LT headers, catless mid pipes, cutouts, CAI, pulley, Tune.
For the guys's not too concerned about warranty, adding heads, cam and FASTLSXR intake will put you at or over 500RWHP...or so it has been done on LS3 Vettes...
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 04-02-2009, 08:20 PM   #6
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
A full exhaust from somebody like ARH will net you 35HP at the rear, so lets say 40HP at the crank. You could do an intake manifold for 10, a Cold air for a couple, and an underdrive pulley for 10.
426
+35
+10
+10
Is a flywheel total of 481. If you did heads you would make it.
Add a ported throttle body and you coudl hit 485 Flywheel HP
ZZcamaro is offline   Reply With Quote
Old 04-02-2009, 10:50 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
No, no cam no 500 HP
Old 04-03-2009, 01:06 AM   #8
JMAN311
JMAN311's Avatar
Drives: 2013 F-150 Limited
My manual vette's LS1 boltons (LG Motorsport LT headers, x-pipe (w/o cats), Corsa Cat-back, Vararam Intake, reprogram) were good for 58 RWHP, which is about 68hp at the crank figuring 15% loss
The manual SS which was dyno'd ended up with 364rwhp which equates to about 14.5% loss from the 426 crank hp. The LS3 would probably respond even better to the same type of mods than the LS1, but even if it were a similar 58RWHP that's 422 hp to the wheels. w/ 14.5% loss that would put you at about 493hp at the crank. So IMO I think there could be plenty of people seeing close to 500hp at the crank w/o a cam.
There just might be a 2016 Camaro or Corvette in my future...
Previous Chevy's
2013 Camaro ZL1 A6|SIM
2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int
2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed
2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned
JMAN311 is offline   Reply With Quote
Old 04-03-2009, 02:02 AM   #9
The Boat
His seafaringness
The Boat's Avatar
Drives: yugo
wy not just cam it?
The Boat is offline   Reply With Quote
Old 04-03-2009, 09:11 AM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I'm assuming that you don't want to pull the engine, just bolt ons, correct? If thats the case, you'll never quite know how much power you have at the crank anyway. To know you have 500 hp at the crank, you need an engine dyno -which requires removing the engine. At any rate, you won't be disappointed if you make 'only' 490 at the crank vs the 500 you're aiming for. Besides, if anyone asks you'd still be able to say 'it makes about 500 at the crank'
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-03-2009, 09:15 AM   #11
blackedout010
Drives: on order black 2010 2ss
bolt on as these should get you 415-420rwhp
headers
pulley
cai
tune
if you need 500rwhp without a cam you will need an sc or a 75 shot of gas will get you there
blackedout010 is offline   Reply With Quote
Old 04-03-2009, 11:35 AM   #12
SS 376
SS 376's Avatar
Drives: IBM 1SS
Why no cam?
It's doable if you swap out the LS3 for an LS7. Otherwise, I just don't see how you would get to 500 rwhp just with the above.
SS 376 is offline   Reply With Quote
Old 04-03-2009, 11:37 AM   #13
jordan 572
jordan 572's Avatar
Drives: none
dont cams give ur a weird powerband and only that full power at a certain rpm
Old 04-03-2009, 11:38 AM   #14
jordan 572
jordan 572's Avatar
Drives: none
i meant 500 at the crank i know 500 at the wheel would barely be possibly if i got a cam and all the parts i listed
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 06:15 PM
Daytona 500 Sweepstakes: Win Tickets! TAG UR IT General Automotive + Other Cars Discussion 9 01-18-2010 12:15 AM
2010 Camaro Indy 500 Pacecar! roadie2991 Camaro Photos | Spyshots | Video | Media Gallery 129 05-24-2009 02:38 PM
Cyber Gray Camaro Daytona 500 Pace Car revealed!! heavyt100 Camaro Photos | Spyshots | Video | Media Gallery 378 02-26-2009 08:58 PM
Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 D-Unit Forced Induction - V8 12 07-29-2008 03:34 PM
