Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 10-04-2011, 07:02 AM   #1
Solocus's Avatar
Drives: 87 Iroc 350, 2001 SS, 45th 2LT
Concerned about LFX Oil Pressure
I picked up my car last Thursday and only have 115 miles on it at this time, but at idle, according to the 4 pack cluster, I only have 15 psi. Oil level is fine and even at 700 rpm its back up to center, 30 psi. Should I be concerned? I'd like to hear what other LFX owners have for oil pressure at idle at operating temperature.
2012 2LT 45th Anniversary Edition ~ Solocus
Delivered 9-29-2011 exactly 45 years to the day from the
first 1967 Camaro showing up in dealer showrooms!
Solocus is offline   Reply With Quote
Old 11-07-2011, 08:58 AM   #2
wholloway6's Avatar
Drives: 2012 2LT RS M6
at idle my oil hangs around 15-30 ish... cruising 30+ getting on it pegged at 70.
wholloway6 is offline   Reply With Quote
Old 11-07-2011, 09:02 AM   #3
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Only need 10 psi per 1k rpm's to keep from hurting the bearings.
You're fine. It's acting normal.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 04:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
IPS turbo install ipimpthisc Forced Induction - V8 119 01-01-2013 04:23 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 09:33 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
