| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
I don't understand
Drives: 2010 Camaro SS Join Date: Nov 2010
When are 2" headers necessary?
Just like the title says when do 2" headers out due the 1 7/8" headers?
Any back to back dyno numbers?
"JSick"
2010 Camaro 2SS |
They make more power everywhere even on a bone stock engine.
I used to be Stieger....
They are usually just used on FI cars
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
There was a test and the 2" did out perform the 1 7/8ths even on the stock tune. Not by much but when you go adding a cam ect. they are the way to go if you want to maximize what you have.
![]() ![]() ![]() Drives: 2010 silver SS Join Date: Apr 2011
2" are the way to go nomatter how you slice it... wish i would ahve gotten them
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
This is a myth. One shop two years ago posted results of a test they did. If I remember correct, it was just they posted the peak numbers, not like a chart that shows power throughout the whole powerband.
I have been selling LSX parts now for 8 years, and have sold as many headers as anyone. 2" headers only sell for cars making 750+ rwhp. This is not my opinion..you call any major header manufacturer, and they will tell you the same. If 2" headers were better everywhere, why would header manufactuers bother making 1 3/4" and 1 7/8"? It would make life alot easier for everyone. Everything you need to know about headers can be summed up in a garden hose. The idea of a header is the make the exhaust gas move faster. The faster the exhaust gas moves, the faster new air/fuel can replace it in the cylinder head, and the more efficiantly the engine can breathe. Going back to the garden hose..if you replace your garden hose with a bigger garden hose...what happens? The water comes out the end slower because it is not as pressurized. The water will only move the same speed as the smaller hose if you turn the water up real high. Same thing with a header. If you put a big header on, it does not pressurize the exhaust gas as much initially, which hurts exhaust velocity. If the exhaust does not move as fast initially, you lose lowend power and TQ. You may see a same, or higher peak HP number witha 2" header, but that is because ones the engine is really wound up over 5K RPM, the bigger primary can flow it better. Long and short is..you want the smallest diameter primary that can flow the maximum exhaust output of the engine efficiantly. if you go on LS1Tech, Corvette forums, or any of the other really technical LSX boards and say..I am gonan run 2" headers on my stock LS3, you will get laughed out the place. I think it is time for another test
#7 |
The stick man
Drives: 2004 GTO - C5 'vert - SRX Join Date: Jul 2006
About sums it up -
Matched parts always work better than some arbitrary dyno test. Ed
![]() PONY WARS |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: Black 2010 1SS M6 Join Date: Nov 2009
Jannetty did a comprehensive test showing the entire curve.
2 inch exactly matched the 1 7/8 all the way to 5-5500 and made 5 more rwhp peak. And this was on a stock ls3. 1 3/4 was down 10 rwhp peak and 5rwhp through most of the curve. 2 inch is the way to go regardless.
Performance Mods: PRC 250cc Aftermarket Casting Cylinder Heads, G6X3 Cam, Fast 102 Intake, Nick Williams 102 TB,Stainless Works 2" Long Tubes, Flowmaster AT Cat-Back, C.A.I. CAI/ADM Scoop, SLP UD Pulley, PFADT Springs/Sways/Rear Trailing Arms, Pedders Subframe Bushings, Energy Differential Mounts, Spohn Toe Links, BMR 2-Point STB, LSR Tunnel Brace, Hurst Short Throw, COR Velocity V3 Wheels, 305/35/20 Nitto NT555R's
Finishline Performance Install and Dyno Tune-505 RWHP 464 RWTQ |
#9 |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
There has been a Test of header tube sizes on here by jenetty. I know the old saying the better it breaths it more power.
IF you are looking at a stock or a cammed Car the 1 7/8 looks to be your best bet. If you have a pretty hot Forced induction car you can go with 2inch however I dont see that great amounts of hp coming out of 2inch. I would go with them if I had a F1 car with a larger Cam.
![]() ![]() Summer is never Far away when Zooming down the street in a '2010/1969 Camaro Youth is long and life is Sweeeeeeeet!!!!!! |
#10 |
I have 2" on my car, no tune and a home made cold air... I just ran 113mph sunday and pulls 112 about every pass, 12.60 on stock tires. I think they are working pretty well, they definitly wont hurt and if you have plans to make over 500rwhp they will be worth it.
#11 | |
Again..no one has answered my question...if 2" is better everywhere..why would the header companies makes 3 different sizes and only recommend 2" for the most extreme applications? Bigger is not better with exhaust.
#12 |
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
They make it because people buy it. If you think 2 s are better than jump On them. Not much of a difference, they are all better than stock.
I would like to think the big header companies have done their research, and thats what they have decided, but i do know better than that. They just posted what they thought and nobody has cared to disprove them. |
#13 |
Drives: Pro Streeted 1965 Buick Special Join Date: Dec 2010
so you guys saying the 2" headers are the best way to go, would you also say based on your experience that a carb sytle intake or fast 102mm would be the best intake for a 5.3L LSx?
#14 |
Like i said... 2" headers make more power. Period. They arent as commonly used because they fit worse,and cost more, along with being heavier. Come up with all the stupid analogy you want, but the reality stays the same. 2" make more power, and the more mods you have, the more power they will make. I have 2" stepped to 2 1/8 staring at me in the garage for the new motor...
#15 |
![]() Drives: 2010 2SS/RS Red Jewel L99 Join Date: Jun 2011
Why don't you get both 1 7/8" and 2".
I asked Kooks to make me a set.They sent me these signature series stepped headers 1 7/8" then it goes to 2". Best of both worlds. |
#16 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
#17 |
I Wanna Go Faster!!
#18 |
I don't understand
I guess I should of said that I am whippled and at 570rwhp stock everything else. Next step in my plan is full exhaust and cai. Then a cam. So I hope to break the 700 mark. Really looking at LG's full setup nocats $1900 shipped. Might have to wait for a 2" special to happen.
"JSick"
2010 Camaro 2SS |
#19 | |
Quit being a pu$$y
Your garden hose analogy isn't very good. If you go to a bigger hose, yes the water will come out slower, but it will also come out in a greater volume. Pressure does not equal volume. You can open the hose and look at how fast the water comes out, put your finger over the end, the pressure goes up, speed at which the water comes out goes up but the volume goes down. Companies make plenty of headers because people want choices. The same reason there are 100 different cold air intakes.
#20 | |
What should I name my car
Drives: 2010 Camaro 2SS RS IOM Join Date: Jul 2009
If you had the same volume of water in your mouth as a guy next to you. You both will attempt to squirt the water out as fast as possible. You both get to choose a straw. Will you choose the fat milk shake straw or the skinny coffee stirring straw? You choose the FAT straw to get the water out faster. Or think of a cup with a hole at the bottom, the one with the bigger hole lets it out faster.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat |
#21 | ||
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
![]() And yes, it is time for another test. Quote:
So fill your mouth full of water then aim up then get a huge straw and try to squirt the water out. Next try the same thing with a narrower straw then finally the smallest one. The best will be the one in the middle(milkshake) not the smallest(coffee) or the widest(paper towel). If 2" is better why stop there why not 3" or 4"? Every application is different. On a stock motor the 1 7/8 might be better but on a FI motor the 2" may be the best.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
#22 | |
Quit being a pu$$y
#23 |
I've always heard that, yes, unless you have a pretty radical set-up, you really don't need 2" headers. But I've also heard that they won't hurt your performance either. I'm never certain what direction my modifications may take down the road, so why limit yourself? In many cases (like Stainless Works) the 2" and 1-7/8" headers cost the same. Why buy something that may need upgraded at a later date? In my opinion, buy the 2" now, and never need to upgrade headers ever again!!! If someone could prove to me that 2" headers will hurt my performance (with something a little more substantial than hose analogies), then I may think differently.
#24 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
Maryland Speed, any chance we will see the 1 7/8-2" stepped Signature Series readily available from Kooks or are they going to be special order only?
#25 |
Big Nasty
Drives: Chevys lots of em Join Date: Jun 2010
2" look pretty killer sittin under the hood, I made 703hp on the motor naturally aspirated if I was makin that at the wheels I would have went with 2" but my tuner and the manufacture recommended 1 7/8" no regrets, Im makin 610hp to the wheels.
| Thread Tools | |
| JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! | AJ@ECSMotorsports | V8 Bolt-Ons & Tunes | 100 | 11-13-2010 03:51 PM |
| The truth about Shorty Headers | JoshJ81 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 33 | 02-20-2010 01:44 AM |
| 2010 Camaro American Racing Headers FREE Shipping | MoranoRacing | V8 Bolt-Ons & Tunes | 2 | 02-10-2010 08:45 PM |
| Doug Thorley headers and axle-back ROCKS! | SPANKT U | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 01-07-2010 10:36 AM |
| 2" Headers Vs 1 7/8" Headers...Your Opinions PLEASE!!!!! | Mr. Brownstone | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 11-18-2009 12:00 PM |
