BeckyD@RodgersChevrolet
Old 10-04-2011, 11:36 PM   #1
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
Header Install Checklist...
Heres all the stuff that I have or have ordered for when we install my headers..
  • Headers, check
  • Y-Pipe, ordered check
  • TR55 Platinum Spark Plugs, ordered Check
  • Gaskets, reusing stock
  • Bolts, possibly reusing stock?
  • No clamps, welding ORY onto headers
  • o2 extensions, check
  • Tuner,check
  • Permagrin, In the making
  • Friend for manual labor/welding, check
I just don't want to get into it and be missing something...
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 10-05-2011, 01:16 AM   #2
JJ#48Racing
Drives: 1998 Camaro SS
I'm an aircraft maintainer and it's kind of engrained into my head to never reuse gaskets or seals. You're asking for leaks if you do that. I wouldn't reuse the header bolts either. I'm pretty sure those are designed to be one-time use items as well. Other than that I think you're ready.
JJ#48Racing is offline   Reply With Quote
Old 10-05-2011, 01:55 AM   #3
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
welding the ory is a mistake.. maybe a few tacks to hold it from slipping dont weld it soild or you will regret it
the oem gasket is MLS and is fine to re-use.. so are the bolts.. loctite them
CC Performance is offline   Reply With Quote
Old 10-05-2011, 10:06 AM   #4
Bulldogwinters
SS #2431
I've actually heard to either buy stock gaskets or reuse them, but I don't know about bolts.. mine seem to be in decent shape as they are now
Why shouldn't I weld? The guy I'm buying it from said he has it welded... But in all honesty, It's so tight that tacks are probably easier. I unhooked all the clamps on my catback to adjust it when it was vibrating, and it was a pain to move everything when it wasn't hooked up, so I'm not too worried about it moving after seeing how tight it fits in there
Old 10-05-2011, 10:33 AM   #5
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Id def get new header gaskets, Unless your gaskets look like new. Just my .02. Every time my dad and I took something apart from the motor, we always put new gaskets on just for peace of mind
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 10-05-2011, 11:26 AM   #6
adamgl
adamgl's Avatar
Drives: '98 Camaro Z28, '06 Z06
New motor mounts (poly) . Mine looked really worn out, car has 115,000 miles on it. It's a lot easier to do with no exhaust in the way.
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con.,
shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's
'06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles,
Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP
http://www.camaro5.com/forums/showthread.php?t=235911
adamgl is offline   Reply With Quote
Old 10-05-2011, 11:34 AM   #7
Bulldogwinters
SS #2431
I might try to find some used poly mounts, but I don't really have the money to do it right now. my car only has 89K miles on it
Old 10-05-2011, 12:10 PM   #8
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
I got Stage 8 locking bolts, and new GM gaskets. I know you can reuse the stock ones and mine didn't look too bad but I didn't want to risk a leak. Not sure why you want to weld the Y, I don't see an advantage. Clamps work fine on mine.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 10-05-2011, 12:17 PM   #9
dmginc
dmginc's Avatar
Drives: 14 Camaro 1LS AGM
cause he puts clamps on upside down so they are practically dragging on the ground
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 10-05-2011, 01:06 PM   #10
dmginc
dmginc's Avatar
buy new exhaust gaskets...25 bucks. why risk it leaking and sounding like poo!
Old 10-05-2011, 03:51 PM   #11
insidethreat07
2001 Camaro V6
2016 Camaro 2SS
Old 10-06-2011, 02:37 PM   #12
Bulldogwinters
SS #2431
No new gaskets, I don't have 25 bucks.. The guy I'm buying my y from says it needs to be welded for some reason.. I guess I'll find out when I get it next week!
Oh and damage, my clamps are sideways not upside down..
Old 10-06-2011, 03:26 PM   #13
dmginc
dmginc's Avatar
then wait a week before installing them...wouldnt you be ticked if you had to pull them off in a couple of weeks cause the gaskets leak?
as for your clamps...i just like to pick on ya
Old 10-06-2011, 07:29 PM   #14
Bulldogwinters
SS #2431
I've not heard a case of the stock ones failing.. I asked around LS1tech and nobody here has had any personal experience, so I'm probably just going to reuse them .
you may like to pick on me..but my car's louder than yours now and it's gonna be even Louder very soon
How much is header install? metthem Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 09-18-2011 07:30 PM
Header install?? vafinest25 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-06-2011 03:52 AM
BBK header Install question Brand new 2011 2LT RS willyd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 03-14-2011 10:13 PM
MTI Racing Header Shifter Install MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 05-20-2010 04:02 PM
Header install in Central Florida found great place. Ltdodge USA - Southeast 0 02-25-2010 01:32 PM
