Emblempros
Old 10-05-2011, 11:50 PM   #1
DTony54
Drives: 2010 CYBER METTALIC GRAY V6 RS
Switched from 3.27 to 3.55 Gears
ballpark on a stock v6 swtiching from 3.27 to 3.55 richmond gear 0-60?
Considering the 6.0 stock 0-60...just a ballpark estimate how much do you think it will cut on the time?
DTony54 is offline   Reply With Quote
Old 10-05-2011, 11:51 PM   #2
DTony54
i know there is a mechanical toque gain of ten %(27.3 ld/ft torque) with this install
Old 10-05-2011, 11:58 PM   #3
Wesman
Wesman's Avatar
Drives: Trans Am
You can't actually gain torque from changing gears.
You can multiply the torque that you already have, but it will still not actually make the car faster. It will, however, get you off the line faster and into the powerband, which could improve your ET's. Horsepower is what actually accelerates the car, not torque.
Wesman is offline   Reply With Quote
Old 10-12-2011, 02:43 PM   #4
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Ditto.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 10-14-2011, 06:20 PM   #5
bmorecam
I give you an rough example.. an ss with 4.11 gears and axle upgrade in last c5 mag gained .17 in 1/4 mile. That should give you an idea of what you are working with.
but like the others have said, you don't gain anything by changing gears. You are just allowing for your car to hit the power band faster.
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Richmond 3.55 gears BLK2LT Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 101 07-09-2016 10:17 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
L99 guys that switched from the 3.27 to 3.45 gear 94guy Forced Induction - V8 18 04-02-2011 09:55 PM
3.55 Gears and LSD Dylanx USA - Southeast 10 01-23-2011 10:36 PM
