Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 10-06-2011, 06:33 PM   #1
Jarvin
Jarvin's Avatar
Drives: 2011/2LT/RS
Trickle Charger
Hello,
my Camaro is the first car which I will not drive in the wintertime.
I have read, in an other treat, that there are Trickle Charger. I have never heard from a Trickle Charger or needed something like that. Because till now I drove all my cars over the whole year.
Can somebody recommend me a good Trickle Charger?
At Amazone I have found a Trickle Charger for the cigarette lighter:
http://www.amazon.com/Schumacher-SP-...941479&sr=1-87
Can I use a device like that for my Camaro?
Thank you very much in advance for your answers.
Life is too short to drive ugly cars!
http://i1232.photobucket.com/albums/ff362/camaro5fan/camaropics/sig.jpg
Jarvin is offline   Reply With Quote
Old 10-06-2011, 07:43 PM   #2
Mr Twisty
Mr Twisty's Avatar
Trickle charger should plug into a wall outlet. El-cheapo works fine... Walmart or parts store is a good place to look, shouldn't be over $30.
[edit] I see you're in Germany, just make sure it's good with your household current.
-- Benjamin Franklin
Old 10-06-2011, 09:42 PM   #3
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Don't use a charger on the camaro but I use battery tenders on my bikes. Never had a problem with them in years.
bajamoon is offline   Reply With Quote
Old 10-07-2011, 08:06 AM   #4
Jarvin
Jarvin's Avatar
Drives: 2011/2LT/RS
Thank you for your advice. I have totally forgot to think on our household current.
Old 10-07-2011, 08:13 AM   #5
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
+1 Battery Tender FTW... I have them on both bikes AND the Camaro.... you can hook to the + post under the hood and to the stud that holds the airbox right next to the + post.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 10-07-2011, 08:44 AM   #6
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
I use a battery tender as well. It permanently attaches directly to the battery and latches underneath with a L hook. You basically run an extension, and plug it in and that's it. There are small ports (holes) on the trunk floor with plastic grommets. You just pull out the grommet and run the extension cord through the port hole.
http://batterytender.com/automotive.html
calbert1999 is offline   Reply With Quote
Old 10-11-2011, 09:30 AM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I have several Shumacher battery tenders. They work great.
-Mark.
Old 10-11-2011, 11:13 AM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
Battery Tender makes a great product. Most electrical devices are 50hz(Europe)/60 hz compatible. Although, you need to check the household voltage (usually 220V Europe) and plug layout.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 10-13-2011, 09:00 AM   #9
Jarvin
Jarvin's Avatar
Drives: 2011/2LT/RS
very much for all your replies.
I have decided me for a Battery Tender product and have ordered it a few minutes ago.:
http://batterytender.com/automotive/...emisphere.html
I think an american product is the best for my american car.
Old 10-13-2011, 12:44 PM   #10
calbert1999
Camaro SS Lover
Lucky guy you can drive that car as fast and as hard as you want. We have to drive under 100kph most of the time.
I know you have some awesome tracks out there. Do you take it on tracks often?
Old 10-13-2011, 04:32 PM   #11
Jarvin
Jarvin's Avatar
Drives: 2011/2LT/RS
Yes, that's true but high speed is not so important for me (I bought the car due to its appearance.) and the tracks are far away. If I drive on a highway/Autobahn then I mostly drive between 130kph - 150kph. Gas is not exactly cheap in Germany.
The higher the speed the higher is the risk to get rock chips or worse something breaks. And a big problem what I have is, that I have no garage till now and it is quite difficult to get replacement parts. Before I had the car, I told to myself - no problem if I need a replacement parts, then I order it in the US. But unfortunately it is not so easy as I thought.
By the way, you are the lucky guy. I would trade high speed for a life in Canada or the USA if I could.
Old 10-18-2011, 01:56 PM   #12
Jarvin
Jarvin's Avatar
Drives: 2011/2LT/RS
Today I have received my Battery Charger.
And now I need your help again.
Can I mount the charging cable as it is shown in the picture?
Or do I have to attach the cable direct to the battery?
I'm sure that is a stupid question. Sorry.
Old 10-18-2011, 01:58 PM   #13
bajamoon
bajamoon's Avatar
^^^ I think you should connect it straight to the battery. Not sure it will work that way
Old 10-18-2011, 02:25 PM   #14
hypurone
hypurone's Avatar
Yes. I have mine done in a similar way. I used the + post in your pic and the stud that held the rear of the stock airbox which is right next to the + post. Has worked perfectly for 2 years now...
trickle charger Hollywood2010 5th Gen Camaro SS LS LT General Discussions 9 09-14-2011 08:54 AM
Rule The Streets! Magna Charger Camaro ZLs™ BlownChevy Forced Induction - V8 41 02-23-2011 02:40 PM
Schumacher SE-1-12S Automatic Battery Charger / Maintainer Installation PAUL SS Camaro DIY & HOW-TO instructions & discussions 3 11-28-2010 12:53 PM
Battery Trickle Charger Fishdadddy Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 10-22-2010 03:41 PM
Trickle Charger Badger Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 16 12-13-2009 12:02 PM
