BeckyD@RodgersChevrolet
Old 10-07-2011, 04:24 AM   #1
Dennis SS
Always Lookin
Dennis SS's Avatar
Drives: 10 SS/RS 6M Blk/Blk Silver Stripes
Arrow Best springs for smooth ride.
Looking to lower my SS, what is the smoothest riding springs?
-Custom grind Crane Cam with 3 bolt conversion, Lunati springs, harden push rods, SLP oil pump, LS2 tensioner
- Kooks Custom Headers. X-pipe, mufflers, high flow cats,
-Tuned by National Speed in Wilmington N. Carolina, HP Tuner 490rwhp and 483rwtq
-Skip shift eliminator
-RX Catch Can
-CAI intake
-Hurst Shifter, with custom Speed Dawg
Dennis SS is offline   Reply With Quote
Old 10-07-2011, 06:06 AM   #2
garcmol
garcmol's Avatar
Hmmm, well I can only speak about Pfadt as that's what I have. It's a great smooth highway ride. It's stiff though. Bumps in the road are sharper now, if that makes sense. But it made the car handle so much better!
Old 10-07-2011, 08:05 AM   #3
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
The smoothest ride isn't going to come from any type of lowering spring. They all have higher spring rates which in turn make the ride stiffer.
Whiteside Customs is offline   Reply With Quote
Old 10-07-2011, 08:11 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
If you want a smooth ride while still being lowered I'd say coil overs are what you want.
Click to view my build thread
Old 10-07-2011, 11:06 AM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
More expensive but ulitmately a better deal. BC Coilovers are pretty affordable. Do a search on those and at least look at them as an option.
If you don't want to spend the money on coilovers and just do springs for looks, just realize most people are going to recommend whatever they have. Not many people have switched different brands of springs in order to feel the difference.
Build Journal
Old 10-07-2011, 11:22 AM   #6
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
I have Eibach springs and sways........................Get Coilovers.
I am changing them out after I get other mods taken care of. I love the lower look, not a fan of the harsh ride that goes with it. I'll be swapping all my bushings out shortly to see if it helps.
Good luck.
UNDER CONSTRUCTION. ETA 2017 ish...
Old 10-07-2011, 12:08 PM   #7
Dennis SS
Always Lookin
Dennis SS's Avatar
Thanks for the info! I will check out some coilovers!
-RX Catch Can
-CAI intake
Old 10-07-2011, 12:32 PM   #8
Dennis SS
Always Lookin
Dennis SS's Avatar
Now that you have BC's on, is the ride just as nice as stock? Have you hit bottom at all?
-RX Catch Can
-CAI intake
Old 10-07-2011, 12:43 PM   #9
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
Good luck.
wise words indeed..now when u say ur swapping bushings ...if u want a soft ride stick with stock...goin poly or even worst delrin or spherical will kill u for sure
ipimpthisc is offline   Reply With Quote
Old 10-07-2011, 12:45 PM   #10
ipimpthisc
Banned
coil overs is the only way to get a smooth ride and better handling if that even happens...trust me ..if u lower the springs....u mite hate the car...i know i will...i just bought coil overs last week, not installed yet
Old 10-07-2011, 01:35 PM   #11
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
For the ultimate in ride quality it's really hard to beat a good set of coilovers. Our drop springs were designed with rates that work well with the stock shocks, but best performance and ride quality are achieved with both damper and spring rate changes. The coilovers we sell feature spring and damper rates specifically selected for the Camaro and are equally at home on both the street and the track.
If you've got any questions please let us know!
Old 10-07-2011, 01:47 PM   #12
caverman
caverman's Avatar
With my current settings I would say it's as soft as stock if not a little softer. You'll still follow some dips in the road....it's not going to make it a smooth as a Lexus or anything but without a doubt my ride has been greatly improved over the drop springs I had.
I haven't bottomed out on anything yet.
Build Journal
Old 10-07-2011, 01:55 PM   #13
caverman
caverman's Avatar
Oh...you can also drop your car a little more with that better ride on coilovers.
Here are some pics. First one is with 1" drop springs. Second is lowered to around the 1.25" - 1.4" range (I never measured my stock height and haven't measured the new hieght).
Build Journal
Old 10-07-2011, 02:02 PM   #14
Whiteside Customs
I fyou want the smoothest ride without braking the bank then the most affordable option is going to be the BC Racing Coilovers that Caverman has. They give you that lowered look, perform on the track, and let you ride home with feeling like you're in a full blow race car.
Raising/Lowering the car Rocky918 Suspension / Brakes / Chassis 28 03-18-2011 11:03 PM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
Pedders XA Ride Quality with D2 Forged 22 VS1s foxman Suspension / Brakes / Chassis 45 04-21-2010 08:59 AM
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
Springs vs. Coilovers BLKnCHRME09Deluxe Suspension / Brakes / Chassis 30 12-29-2009 05:25 PM
