Old 10-07-2011, 11:27 AM   #1
toilets
Drives: 2010 camaro
How to convert LS3-427
Hello,
Ok, Im weighing all options here, I have inquired about a TT set up, single T set up and now would like to know what might all be involved with converting my LS3 to a 415 or 427?
Having said that, What is done to convert my standard LS3 motor to a 415 or 427?
What all needs to be done? do i have to change out my rearend?
Does anyone know roughly what the cost maybe do have this completed?
just trying to explore my options as I need a road course/autox type set up and so far I have been steered away from F/I due to the sudden power increase which I cannot have obviously. I need a smooth steady throttle and N/A seems to be the direction people are leading me too.
Thanks so much for any input
toilets is offline   Reply With Quote
Old 10-07-2011, 12:35 PM   #2
toilets
Drives: 2010 camaro
Also,
I see, for example that SLP has a LS7 block for sale for 7G with no core... Is this honeslty all these LS7 motors run?
Old 10-07-2011, 07:33 PM   #3
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
If You are sure your going to stay N/a then go with the 427 if not sure then going with a 416. You need to buy a 427 or 416 stroker kit and have your stock block set up for the kit. You not going to be able to get a crazy amount of power staying N/a with out speeding a good of money and losing alot of driveability not that you care just throwing it out there. I say go buy a procharger like the one for sale in the "parts for sell section" and hammer down.
JLE58 is offline   Reply With Quote
Old 10-13-2011, 10:53 AM   #4
Jason 98 TA
Drives: Camaro
We have 427 LS3 short-blocks in stock. You can buy a short-block & move your parts over, or we can build you a complete 427 LS3 long block to meet your power goals. We typically see street LS3 427s go in the 670 flywheel horsepower range!
Jason 98 TA is offline   Reply With Quote
Old 10-13-2011, 11:19 AM   #5
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
Originally Posted by toilets View Post
Hello,
You have two different things here...
First the block comes as a 4.065 bore ..
Now for the 416 you clean the bore up .005 and go with a 4" stroke crank.. the 4.070 bore x 4" stroke gives you 416 cubic inches
for the 427 you do the same bore 4.070 but go with a 4.100 stroke...
This gives you 427 cubic inches BUT the added stroke means you need to move the rings upward on the piston and this compromises the piston and as such we dont recommend it for a power add applications
So for your TT you want a 416... forged internals and built to the proper compression for the fuel your going to use.. the lowest amount of octane it will see if what you set you compression for...
CC Performance is offline   Reply With Quote
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 01:30 PM
427 KILLER74Z28 General Automotive + Other Cars Discussion 5 06-18-2010 12:55 AM
Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 10-01-2009 01:55 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
