JDP Motorsports
Old 10-07-2011, 12:59 PM   #1
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
Tunnel brace?
Have a question? I just installed a 3 inch exhaust. My tunnel brace will not fit anymore. Is it needed or is there one I can buy specifically for 3" or bigger exhaust.
I searched and could not find any info. So please keep the butthead comments to yourself.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 10-07-2011, 01:16 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
yes the brace is needed...Here's a thread with another option for you http://www.camaro5.com/forums/showthread.php?t=162297
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 10-07-2011, 01:17 PM   #3
toilets
Drives: 2010 camaro
LSR performance has an awesome tunnel brace for 3 inch exhaust. I have it and its really nice and was only like 90 bucks
toilets is offline   Reply With Quote
Old 10-07-2011, 01:19 PM   #4
toilets
Drives: 2010 camaro
http://www.lsrperformance.com/chassi...pan-brace.html
here is the link if you are interested
Old 10-07-2011, 02:59 PM   #5
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I believe BMR sells a stronger one that adds clearance. For mine, I just added a few washers to each bolt to give it enough clearance so that it doesn't make contact with the piping.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 10-07-2011, 03:23 PM   #6
CamaroCowboy
Mine is down way to far. I must have done something wrong. I am going to look at it again tomorrow. I will let yall know what infigure out.
Old 10-07-2011, 03:27 PM   #7
phdjent
Evan "FRESHAYR"
phdjent's Avatar
Drives: 2014 Stingray Z51, 2014 Jeep SRT
This what you need. American Racing Headers created this brace. It's awesome, rock solid, made for 3 inch exhaust:
http://www.camaro5.com/forums/showth...ight=arh+brace
phdjent is offline   Reply With Quote
Old 10-07-2011, 03:40 PM   #8
fldrummer
"Black Ace"
fldrummer's Avatar
Nice-looking brace! I can't believe I haven't seen/heard of that one 'til now. 'Might have to go on my to-do list.
(This thread should probably be moved to the suspension section of the forums.)
Old 10-07-2011, 03:47 PM   #9
phdjent
Evan "FRESHAYR"
phdjent's Avatar
My car is now lowered and still plenty of room to the ground.
Old 10-07-2011, 04:09 PM   #10
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I did an ass load of research on this and basically it is there to aid in rigidity of the chassis upon side impact! some will say its not needed, some will say it is. I couldnt stand it not being there. I ordered the elite engineering tunnel brace that has a built in 1/4 in drop also added the dogbone spacers that came with my SW catback system. a coule washers will work.
make sure the Xpipe is not in upside down. the ARH x pipe has a slight bend in it that allows it to tuck up nicely in the tunnel. if its upside down it will extend an inch below the tunnel. dont know whos xpipe your running but you may want to check on it.
The brace definitely adds rigidity to the chassis. As evidenced by jacking the car from the rear left side by the exhaust. with the brace in, i can get the car up high enough to slide the jackstands under both sides of the car. without it, the right side droops about 2 inches too low with the floor jack fully extended. cant get the jack stand under it.
Good luck with this, it kept me up at nights.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 10-07-2011, 04:11 PM   #11
BullF-16
BullF-16's Avatar
here is a thread i started as part of my solution to the problem.
http://www.camaro5.com/forums/showth...t=tunnel+brace
Old 10-07-2011, 04:26 PM   #12
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I installed this one, I had to add some longer bolts and 2 painted black aluminum block shims. My SLP resonators are right where this brace installs.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 10-07-2011, 05:57 PM   #13
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
Also, when you choose what brace you want, make sure the exhaust does not touch it and vibrate. I did a search and found a few people on here had the exhaust touching the brace, and the vibration was felt through the car, all the way to the knock sensors on the engine. The computer thought the car was having detonation, so it would retard the timing. So the car was actually losing power.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 10-08-2011, 07:11 PM   #14
CamaroCowboy
Ok. Yes the X pipe was upside down. However even after fixing that it is still to low for my aftermarket Barton tunnel brace even with 4 washers on each bolt. Any ideas?
Billet Aluminum Tunnel Brace southerncarparts Suspension / Chassis / Brakes 36 02-16-2018 09:28 AM
Exhaust rattle on tunnel brace fix your take? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 55 03-26-2016 10:18 AM
Running without tunnel brace BullF-16 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 08-30-2011 10:45 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 09:15 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 03:03 AM
