JDP Motorsports
Old 10-09-2011, 09:48 AM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Easier to do differential bushings before or after removing cradle
I am dropping rear cradle today for install of bmr pro bushings. Is it better to do the differential bushings while cradle is in or after i take it out. I dont want to have to drain fluid.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-09-2011, 10:10 AM   #2
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
its up to the tools that you have, and if you are working on a lift. for most people it is easier to pull everything out. for someone with the advanced tools to do the job it can stay in
camaro4mybday is offline   Reply With Quote
Old 10-09-2011, 12:02 PM   #3
jsharp
jsharp's Avatar
no lift. Car is equal height front to back on jack stands. I was just gonna drop the whole thing and then do the work. I will be using sawzaw for removal of all bushings.
Old 10-09-2011, 12:03 PM   #4
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Three bolts + the cvs drops the diff. Even faster if you have aftermarket axles with bolt together stubs.
Ovenmitt is offline   Reply With Quote
Old 10-09-2011, 12:14 PM   #5
jsharp
jsharp's Avatar
ok so ill do the differential bushings while the subframe is out for the cradle bushings that should be easy as I also have to install toe rods.
Pfadt Poly Differential Mounts Installed Blue70SS Suspension / Brakes / Chassis 80 03-21-2016 07:58 PM
Installed Energy Suspension full cradle bushings Synner Suspension / Brakes / Chassis 15 08-26-2011 08:59 AM
BMR Launches New Product - 2010+ Camaro Delrin Rear Cradle Bushings (BK027) BMR guy Suspension / Chassis / Brakes 4 07-20-2011 05:46 PM
Which cradle bushings to use? caverman Suspension / Brakes / Chassis 100 04-07-2011 02:41 PM
BMR Fabrication Reduces Prices for Differential Bushing Kits (BK001) BMR Suspension Suspension / Chassis / Brakes 1 07-30-2010 11:21 AM
