BeckyD @ James Martin Chevy
Old 10-09-2011, 01:46 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Getting driveshaft bolts out.
I am removing the driveshaft bolts (3) 18mm to release driveshaft from differential but keeping the rubble flange on the driveshaft side. Well I am wondering how to turn the driveshaft to get the upper bolt out. And does anyone know the part number for these bolts as I have been told to replace them. Do I need to put loctite (blue) when putting new ones in?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-09-2011, 04:21 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
Turn driveshaft??? Put in neutral, release parking brake, turn wheels
Parag is offline   Reply With Quote
Old 10-09-2011, 04:54 PM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Like Parag said, block the front wheels if they are not already, put the trans in neutral, and spin the shaft or wheels...
As for the bolts, yes it is highly recommended that you replace them if you remove them... mandatory, not really, but mechanically it is good advice... To secure proper torque and strength, bolts are tightened to a specific torque... This actually stretches the bolts and creates tension that holds the bolts from backing off... This tension creats friction between thee flanges they are holding which helps prevent side loading of the bolts. Too little torque, they back off and are side loaded leading to breakage... too much torque, and they are over stretched and this also leads to breakage...
If you can get them, and I do not have the part number, sorry... then use new ones with loctite and torque them to the specified torque...
Old 10-09-2011, 06:29 PM   #4
jsharp
jsharp's Avatar
Any ideas on torque
Old 10-09-2011, 06:41 PM   #5
Synner
Drives: not stock
Its in the directions for the bushings.
Old 10-09-2011, 06:53 PM   #6
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Any ideas on torque
Don't quote me but I seem to remember it's 57 ft/lbs
Old 10-09-2011, 06:55 PM   #7
jsharp
jsharp's Avatar
Ok. Any gm part guys on here that can ship me some new driveshaft bolts 92139104 times 3
Old 10-09-2011, 11:11 PM   #8
blake-b
blake-b's Avatar
Drives: Black 2010
It is 85 lb/ft per Pfadt's subframe bushing tutorial.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
Driveshaft Shop 9inch conversion in LPE650 2010 BADSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 84 09-22-2011 11:48 AM
Part numbers for Driveshaft bolts & nuts? Russell James V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 09-20-2011 03:54 PM
Has anyone broke driveshaft bolts ? Turbobitt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 08-30-2011 01:41 PM
Driveshaft Bolts Ovenmitt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 04-26-2011 09:48 PM
