HeadlightArmor
Old 10-09-2011, 04:57 PM   #1
RedRocketSS
BSHU
RedRocketSS's Avatar
Drives: 2011 Red Jewel SS
Installed Pfadt Springs, minor creaking noise..
I had them installed (and aligned) yesterday by Grunion Customs, pretty reputable shop around here. The car drives fine and doesnt make any noises until the front end goes over a speed bump or other bump in the road. Should I have the shop check them out or might it take a little time for them to "settle in"?
Yes Ive used the search function and looked around at the different threads about some creaking/squeeking people experience after installing lowering springs. It seems as though everyone has a different answer in each thread.
I sent a PM to Pfadt Raching but figured I wont hear anything back until tomorrow. Anybody have any input on this....
CAI and Ported TB,Loud Pedal Motorsports Tune, Pfadt Lowering Springs, and more.
RedRocketSS is offline   Reply With Quote
Old 10-10-2011, 12:24 PM   #2
RedRocketSS
BSHU
Bumpity bump...I also noticed a creak with sharp turning after driving a little more.... Anybody???
Old 10-10-2011, 02:03 PM   #3
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I have the 1.4 drop and get some squeaking over smaller bumps. Never thought much about it. Car rides great and I don't hear anything when Im driving down the road.
chevy 3 is offline   Reply With Quote
Old 10-10-2011, 02:50 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey guys. It's not normal to hear creaks or groans after installing a set of our drop springs. A couple things to look for though -
If you've installed sway bars make sure the bushings are properly lubricated with the grease that we supply.
Make sure that the spring and rubber isolator are clocked correctly and securely into the upper spring perch.
Make sure endlinks are properly torqued. If you reused your stock endlinks this will require a T5 Torx bit and an open ended wrench.
Run through and do a general bolt check on all parts that were disassembled... the upper strut mounts, endlinks, wheel lugs etc.
Pfadt Stage 2 Performance Handling Package Is Now $600 Shipped At APEX Motorsports!! Apex Motorsports Suspension / Chassis / Brakes 167 08-09-2012 06:05 PM
Pfadt solid subframe mounts, diff bushings, sways and trailing arms installed! AdamCzap Suspension / Brakes / Chassis 14 01-04-2011 06:54 PM
Installed Pfadt sways and end links, now hear noise? BaylorCamaro Suspension / Brakes / Chassis 18 12-08-2010 07:02 PM
