Solo Performance
Old 04-08-2012, 06:30 PM   #295
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
With headers you're gonna have to remove the stock cat or get a high flow cat cuz as soon as it hits the stock cat it will slow it right back down and loose all the power it had
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 04-08-2012, 11:28 PM   #296
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Ill prob just remove the stock cat. Would it be best if I let a muffler shop to install the headers and y pipe, or if I install the headers and let them do the rest?
Should the headers and y-pipe bolt directly into the exhaust system?
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 04-09-2012, 12:11 AM   #297
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Yeah, you can install it all yourself but you will need somebody to weld it up to the old exhaust system when you're done so you don't have leaks. It should bolt right up to the stock system but you're gonna need some more pipe for where the cat was
Old 04-09-2012, 02:32 AM   #298
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
pacesetter y-pipe 3in out stock or most aftermarket is 2.25 and 2.5 for v6
fbodyrs96 is offline   Reply With Quote
Old 04-09-2012, 11:09 AM   #299
demonspeed
demonspeed's Avatar
Drives: Ordering 2017 SS
I'm partial to UMI products. If you're going to spend the money to overhaul your suspension, go with the body-mount torque arm with drive shaft loop. Otherwise, do not bother getting the DS loop.
I'd also suggest the adjustable LCA's along with an adjustable PHB so that you can center the rear correctly due to wheel changes, lowering, etc.
demonspeed is offline   Reply With Quote
Old 04-15-2012, 10:24 PM   #300
insidethreat07
Ive been debating:
Fill and paint the holes in the stock grille. Gloss black with Red CAMARO inserts
OR
Just removing the stock grille all together.
The reason I like the 1st option is because then it will at least match the back end of my car.
Thoughts?
2001 Camaro V6
2016 Camaro 2SS
Old 04-15-2012, 11:00 PM   #301
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Is getting a new stock grille an option?
Old 04-15-2012, 11:19 PM   #302
demonspeed
demonspeed's Avatar
The second -- for the same reason you stated. Maybe paint it gloss black and use the same color insert that you used for the rear.
Old 04-16-2012, 12:39 AM   #303
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
I'd remove it and just have the holes filled. Cleanest look IMO.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 04-18-2012, 06:28 PM   #304
insidethreat07
Bought some SFCs
http://www.herronperformance.com/sto...d&productId=46
2001 Camaro V6
2016 Camaro 2SS
Old 04-18-2012, 08:07 PM   #305
demonspeed
demonspeed's Avatar
Great choice with the UMI.
Old 04-18-2012, 08:49 PM   #306
insidethreat07
Thanks. I was debating between 3pt and 2pt
2001 Camaro V6
2016 Camaro 2SS
Old 04-18-2012, 11:34 PM   #307
OffseT
Maroboy2001 AKA Offset
OffseT's Avatar
Drives: Boosted Trans Am
Should really make a difference!
OffseT is offline   Reply With Quote
Old 04-20-2012, 08:01 PM   #308
insidethreat07
Hope so, Cant wait to get them and install them
2001 Camaro V6
2016 Camaro 2SS
2LT exhaust options Guardian1816 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 01-12-2010 10:28 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 11:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 02:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 07:47 PM
