SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 04-04-2009, 06:22 PM   #1
89iroc-z
Drives: 89 iroc candy apple red 305TPI
rebuilding my 89 iroc
Hey guys, I have a 305 TPI motor that i spun a bearing in and it needs a new crank, but other than that, it runs good. So i wanna rebuild it and make it where it will rech about 325HP give or take a few, but atleast 300HP. So ive got a few ideas of what i could do, but i would like to hear what other people should suggest. AGAIN, any suggestions are fine.
thanks Tim
89iroc-z is offline   Reply With Quote
Old 04-04-2009, 06:54 PM   #2
Iroczlover
The Krazzy bytch
Iroczlover's Avatar
Drives: Which car I have 9 vehicles?
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
lol drop a 350 in to it or bore out the 350 to a 355 & then stroke it. (every male strokes his engine)
My 87 Irocs 350 engine spun 3 main bearings 4yrs ago & I had it bored out to a 355 line honed it & also, had a LT1 crank & a Lingenfelter cam put in to it.
Heart breaks everyday when you cant take care of your family because you are unemployed, cant give your family what you want or what they need
I am not a man I have boobies.
Cars are like women, If you treat her rough shes going to complain & you will hear about it. If you treat her right she will purrrrrrrrrrrrr
Current cars owned , 72 Skylark vert,86 fiero GT Sold , 87 Iroc-z, 90 Vette Vert SOLD , 95 Z28, 99 Silverado K1500, 2010 CGM Camaro 2ss/rs (had to sell & I hate it ) ,2012 Cruze LT
Iroczlover is offline   Reply With Quote
Old 04-04-2009, 07:02 PM   #3
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
I always loved them irocs!....Lots of gear heads on here maybe some will
chime in.
and welcome!
NAHURRY is offline   Reply With Quote
Old 04-04-2009, 09:43 PM   #4
r.i.p.01slpss
r.i.p.01slpss's Avatar
Drives: 01 camaro ss (R.I.P) 92 RS
If you're gonna keep the 305 then you should think bigger cam, some head work and intake work and hope for the best power wise. I wouldn't get too carried away with flashy internals or over boreing in a 305.
r.i.p.01slpss is offline   Reply With Quote
Old 04-04-2009, 10:03 PM   #5
Vash
Drives: 00 Blazer
Better to get a crate or local rebuilt 350 long block IMO. That way you'll have now core and heads.
Rebuilding that 305 without bore and stroke and full parts rebuild in addition to your crankshaft as you said. Would be a waste of time and money IMO.
Old 04-05-2009, 03:50 PM   #6
99b4c
Drives: 89 RS/99 GTP/1SS soon
It really depends how many miles are on the motor, its a waste to put a crank kit in a 100K+ motor IMO. If it has high miles I say go with a 350 shortblock with Vortec heads, Vortec TPI intake and a mild cam for the TPI setup.
Or swap in a low mile LS motor/trans and have the hp you want with a stock motor.
Whats the budget on this project?
99b4c is offline   Reply With Quote
Old 04-30-2009, 10:16 AM   #7
BlueZee28
BlueZee28's Avatar
Drives: 1991 Z28 convertible
I think a lot of people forget that the power differences between the 305TPI and the 350TPI is extremely small.
If you're going to build a 305, and want impressionable power, you will want an aftermarket TPI system. Holley makes a great kit - Holley Stealth Ram. And since your motor is already set up for TPI, you won't need the whole kit. I do believe you can purchase everything YOU would need for around $800 and you can install it yourself.
I would recommend a moderate cam such has the LT4 Hot Cam. I have seen guys run this cam in 305's and it really wakes them up. But do remember that you will need to put new springs, lifters, pushrods, and get the heads ported to be able to use the extra lift and duration of the cam.
I would also highly recommend a stall for your transmission. (you didn't specify whether it was auto or manual, so I'm assuming auto). Something worth noting: TPI motors' power band is in a lower range than an LT1 or LS1, so keep that in mind when picking out a stall. Something around the 2,800rpm range would be beneficial, as you will still maintain a low lockup, and be able to use the low RPM torque.
Headers will be a personal preference. Some prefer shorty style, some prefer the long tubes. It is a general assumption that long tubes help more on the top end, and *may* decrease your torque/bottom end. It is also a general assumption for the opposite with shorty style headers. They will increase your bottom end, but will not give as big a benefit on the top end.
Also worth keeping in mind: If you were to drive an L98 equipped car (350TPI), back to back with a LB9 equipped car (305TPI), you would be hard pressed to find a difference between the two judging by the seat-of-your-pants feeling. And the trap times on the 1/4 mile won't be much different either. Around here a well running L98 may run a 14.7-14.9
LB9's run around the 15.2-15.5 range here....mine ran a 15.0 with sticky tires and some know-how behind the wheel.
Another assumption I'm going to presume is that you ARE on a budget which is why you're not looking into doing an LT1 or Gen III swap (LSX base). If I am right in my thinking, then you are on the right track, building a 305, as they can be done on a budget EASILY. They are much easier to modifty with less money than a newer block. I should know, I've invested about $1,500 in my 6.0 and necessary parts, and I haven't even bought my cam or had the heads ported yet, so the block isn't even put back together.
<>< Nick <><
LSX Powered
For More Pics Click:
http://www.omnipotent-goku.com/iroc/gallery/album140
BlueZee28 is offline   Reply With Quote
Old 04-30-2009, 02:34 PM   #8
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
The HP difference is small, you are correct. The 305's biggest problem is that it is so limited in Heads. Vortecs or World Products would be the way to go on that motor, if you don't want to do the 350.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
86 iroc rear louver The_Beast_ 3rd Generation Camaros 4 01-20-2009 12:30 AM
I want a new IROC :) seattlecamaroboy 5th Gen Camaro SS LS LT General Discussions 15 08-10-2008 09:49 AM
Ugh...decisions about my IROC MerF 3rd Generation Camaros 15 07-29-2008 07:29 PM
It’s All Over Now — For IROC swazworth General Automotive + Other Cars Discussion 20 03-14-2008 06:32 PM
